My 55313 wont turn on the green led wont even lite up im geting power to the board dont smell any thing burning.
    Sergeant:
  • 295 Answers
Okay - Make of the unit then the Model # please so that I can be more helpful!
Blessings,
A/V Media Guy
Posted on Nov 23, 2009
My samsung ml-1666 printer problem is while i'm push the power on button the printer LED (RED & Green) lite goes on and its consist continue. what couse this problem.....
Two reasons I could think of
Low toner.
Pre-set counter on cartridge reaches limit.
Try removing the toner cartridge and powering the unit on.
While unit is plugged in, re-install cartridge.
Not knowing how old the printer is a the amount of use, it is had to answer
Apr 30, 2014 | Samsung ML 2010 Laser Printer
Acer one aspire d270
you need a new board
Mar 24, 2014 | Computers & Internet
Flashing green led light in back of tower
hi, okay you got to be careful here, it's sounds like the power supply has called it a day, disconnect from the mains take the side panel off and get sniffling can you smell a burn smell , no , now pull the power leads from the hard disk and DVD drive if fitted now removing anything that could cause a short on the board , turn it on, do you get video display ?
Please be careful of static shock and mains shock so only look inside once it disconnected from the mains.
Keep me updated please.
Regards
Dec 21, 2012 | Computers & Internet
WONT POST AND HAVE LIGHTS ON THE TOP RIGHT THAT
Remove all cards and all memory. Only use a video card, if needed or the on-board video.
Plug in the power, turn on note the screen messages, if any.
A message should show on the screen something like... no memory, no ... (maybe some thing else).
Test the cpu to see if it is good. You can borrow another, or get some one to test it for you. If the cpu is good, then the mother board is suspect.
At this point if you should be able to tell which is bad.
The kind of things you mentioned could be caused by: bad mother board, bad bios, bad cpu, and even possibly bad memory. (one of those).
A board which hangs like this can also have problems with a daughter card.
Oct 17, 2009 | Gigabyte GA-EX58-UD4P Motherboard
I have a 60 inch crt RCA that will not turn on the green lite come on and then goes off about 3 or 4 trys and the off for good I could smell electronics type burn odor also. I have had this similar...
The most likliest thing is the flyback needing replacement its 259296 flyback if you have a D52W19 you can get one at the following link which includes detailed instructions on the repair.
http://servicemanuals.vstore.ca/
Jun 24, 2009 | RCA D52W19 52" Rear Projection Television
Dell dimension 8300 no power
Bad news:
In my experiance you have a fried mother board.
Question are you getting any display from your monitor - if you are there is hope - if not the same thing that took out the power suply has probably fried the motherboard.
The only other thing I would sugest is to flash the BIOS - either locate JP1 or remove the battery (looks like a whatch battery) and cross the terminals with a screwdriver - re-install the battery and see how it goes.
Point: No display = no motherboard.
Good news is that the RAM, Procesor and other components are probably good.
Nov 11, 2008 | Sunon (16-02-006) Fan Kit
Nintendo ds lite
Well one things for sure if you dont play with it the ds wouldnt just refuse to play, have u dropped it on has any water been splashed on it? If you have then thats what has caused the problem so go and get it fixed, if you havnt got any water on it or dropped it then your DS must be broken im sure you can get it fixed, if not get a new one.
Hope this helps!!!!
Oct 21, 2008 | Nintendo DS Lite Console
GREEN LED WILL NOT LIGHT
the ps2 connectors are shorted so the mobo out highly recommend replacing mobo
Nov 26, 2007 | EliteGroup P4M800PRO-M Motherboard
Televison & Video Logo
16 people viewed this question
Top Televison & Video Experts
Electro Med Services...
