Question about Epson TM T88 Thermal Printer
Printer showing error and paper out lights even
My tmt70 printer showing error and paper out lights even when changed roll??? anyone any ideas really driving me bonkers agaggg!!
    Scholar:
  • 83 Answers
Cancel all the pending print commands from printer buffer that will be there in the bottom right hand side with an icon of small printer. And right click on the printer properties by going in Control Panel->Printers check the printer icon and do the right click and check whether it is offline or online. It should be Online.Click on the properties and click on Roll Back Driver option. Or either uninstall or reinstall the drivers either by Driver CD or by online. Restart the computer and then try to take the print.
Posted on Nov 19, 2009
Show the error light
Hi Karthik,
Try this:-
  • Check the paper roll and probably re load it.
  • Turn the printer off.
  • Press and hold the power button and then switch the printer on.
  • Release after the first flash of LED light.
  • The printer prints a test page.
  • Turn it off and then on again and then try printing.
Hope this helps.Thanks!
Please rate this answer.
Dec 11, 2011 | Citizen CTS651 Thermal Printer
Ink ribbon or paper roll error. the in ribbon is broken, or the paper roll is jammed. Clear the problem. I put new roll and ink cartridge in and still showing error
Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the paper feed. Clear that out, and all is good.. Change the paper every time u change the ink.
Jan 16, 2011 | Sony SnapLab UP-CR10L Digital Photo...
Printer is saying paper jam and I have cleared out all paper and clippings that were stuck how can I get it to stop saying paper jam?
Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the inside top paper feed. Clear that out, and all is good.. Change the paper every time u change the ink. Even if its not finished. They give you extra. And clear out all the paper from the cutter traay before you move the printer.
You must open up the front where the roll goes. Lay the printer back, and look up top where the paper ejects. you should see some of the paper in the feed. Pull that out with a tweezers.
Beware. I sent my printer to Sony and they tried to get me for a new cutter and thermal head. Close to $500. I then realized the problem because it happened on another unit I own. I told them to ship it back unrepaired and I fixed it myself.
Hope this helps
Oct 19, 2010 | Sony SnapLab UP-CR10L Digital Photo...
Paper jammed message and alarm light remain on even though there is no paper jammed
To fix this kind of error, remove the ink cartridge and turn the printer upside down and gently shake it.Check if anything comes out.If nothing goes, or you can't hear anything rattling around, get a piece of card stock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there. Open up the printer and clean the insides with a soft cloth and a brush. That should remove all the bits of paper inside.The teeth on the roller sides may have some dirt stuck on them which does not allow the rollers to roll freely and hence is as bad as paper jam. The idea is that the rollers do not roll whether because of paper or some dirt on the roller teeth. They have to be cleaned.
Thank you !!
Jul 09, 2010 | Canon PIXMA MX310 All-In-One Printer
Reload Paper constantly shows up
This printer is very finicky about paper loading. I see this error most commonly when using auto-cut roll paper. If the paper edge is not cut perfectly straight, and it is not inserted into the printer perfectly strait, it will give you an error. When it does this, you can simply load the paper and press "cut" instead of "pause" when it says "press pause" and it will cut the paper straight. You can also set it to "Roll Paper Manual Cut" and load the paper, then set it back to "Roll Paper Auto Cut."
Jun 30, 2009 | Epson Stylus Pro 10000 InkJet Printer
Paper at the output slot
Its a jam. On the Bottom tray and its wound around the roller. You can feel it but really cant see it. Have to have really small hands to get it out.
Mar 28, 2009 | Canon MP520 All-In-One InkJet Photo...
I have the canon w8400 and when i try to print it comes up error E0200D Size undetected. Pleas explain i have the same problem! it says ERROR EO2OOD. WTF?
Could be that the button for Sheet / Roll has been pressed. This is a popular error caused by the machine expecting a sheet when you are loading a roll. Make sure the light is located on the roll option rather than the sheet.
If this is the problem, you must first remove all media, then lower the covers and lower the media release lever before the printer will allow you to change between roll & sheet.
Oct 15, 2008 | Canon imagePROGRAF W6400 InkJet Printer
Epson u220b printer
service for that unit - call the manufacturers tech line and they'll give u service center nfo - it it's still under 2 years - repair will be free of charge
Apr 08, 2008 | Epson TM-U220 Matrix Printer
Epson TM T88 Thermal Printer Logo
611 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
