Help Hi! after i've read the solutions from some experts, I did what they advised, I "rebooted" ,"deleted some unwanted files /recent programs" I installed in it, tried "msconfig", "run", "CHKDSK " and "cleaned up" my laptop with MacAfee anti virus and Webroot antispyware all done in safe mode but still cant open my normal mode. Monitor turns to white, loading is to slow and sometimes stops, not responding, gets blurred, LCD blinks in the task bar part, BSOD appears and keeps restarting... Wwaaaaaahhhh!!! I just bought my Sony vaio with PCG-3G9P model last couple of months and why my laptop goes like this? Do I need to reformat it? Does my LCD have defect? or is the quality of SONY gets low? I'm expecting from the "SONY laptop experts" out there to send me the possible solutions immediately cuz I'm a "SONY PATRONIZER" and hoping that it could resolve the issues. thnx and morepower!
This will take you to the program list for the uninstall function.
Then just follow the uninstall instruction on the top of the program list page. This is basically just selecting the program you wish to get rid of and hitting the uninstall function. Just double check you have selected the correct program before hitting the uninstall function.
Sometimes you can have problems uninstalling aftermarket software because the programmers of some of this software deliberately make it near impossible for the uninstall function to remove the program. When that happens you have to use other means to get rid of it or at least completely prevent it from working. When this happens I go into the registry and delete every item attached to the program name and then delete every folder and file with that program name that will delete by selecting it and hitting the delete key.
Hope this is clear enough.
seems like an issue of junk files and infection in the computer.
remove the unwanted programs
clean the startup from msconfig (expert advised)
clean the junk, prefetch, temp, etc
clean the registry
update the version.
reboot and see if it works.
if this does not help, then call 1-877-805-1027 for expert help
Generally there are many recent files,catch files, tempt files etc and hidden files.Actually we need to delete all this items after use and after storing of these unwanted files the programming size is too low.So, my advise is to check all this unnecessary items.Moreover, you need to check the items of bookmarks etc and if possible remove/ make back up messages and contacts and the files which is stored in phone memory.Good luck
1. Clear the temp files in the temp folder,recent files.
Click on Start and then Run.
In the text box in the Run window, type %Temp% and click OK. A folder full of files and other folders will appear.
All of the folders and files you see in this Temp folder are no longer being used by Windows XP and can safely be deleted.
2. Scan your machine with good anti virus every week with the updated definitions 3. Remove unwanted programs installed in the machine, as it uses unwanted memory.
well i would say alone with the unwanted software and programs it probably deleted shared files also. files that various programs use no matter what they are. that is why if you ever see when your deleting files a screen asking do you want this shared file to be deleted. My suggestion is to remove skype fully using there uninstaller and then download a new one this way you have all the right files
there are many reasons for getting your system slow.
1) virus
2) unwanted programs
3)unwanted files
4)temperory files
5)cache files
Etc
To resolve this issue you can do a scanning with a good antivirus programs, uninstall all un necessary prorams and delet all unwanted files like temp, cache etc. and later increase your system virtual memory and restart your system
Now you can see the system runs faster
Check the below links for step by step instructions : remove unwanted fiels
Given all the steps you've tried thus far, it may just save you time and frustration to just wipe the machine and start over. Given you can get into safe mode you might be able to copy any of your important files off to a usb thumb drive or usb hard disk before you wipe it.
If the laptop still has problems on a fresh install of windows, then its time to call in warranty repair.
