Question about Xerox DocuColor 12 Color Copier
Docucolor 12 I need to find the connector for my docucolor 12 it connects the fuser housing to the inside back of the machine it is located on the actual fuser housing I am not sure what it is called but has all the wiring harness to it and it looks like I can change out the plastic piece? thanks for your help
    President:
  • 2,072 Answers
Do you need a part number for that? Is that what your asking?
You can go to a site
https://www.partsdrop.com/store/
And see what they have under Doc 12s. If you cant find it on the site, call them at the number on the site and talk to Britt.
Or Joe.
They most likely can help you.
I just am not 100 percent sure what your asking for.
try this site ok. I deal with them several times a month and they will help you out.
Posted on Jan 11, 2008
Docucolor 12
check scanner unit which hit the opc drum, may be hide by something
Dec 27, 2013 | Xerox DocuColor 12 Color Copier
My xerox xc830 prints bout 1/2 page and then stops and the paper light comes on. The paper is not stuck in the machine it is just laying there. How can I fix this problem? I have looked for someone to...
The jamming with the copy half way thru is almost always a broken fuser drive gear. The fuser unit is the part that gets hot as the paper exits the machine. Check the back side of this unit. You will see a gear, or part of a gear that is about 1.5 inches across. Either that gear breaks or the cog inside of it shears off and this causes the fuser not to turn. Very inexpensive part at less than $15 and pretty easy to change.
Part number for the gear if you need it is NGERH0540FCZ3
If you had the part I am sure you could find someone to install it if you don't feel comfortable with doing it.
Good Luck
Oct 29, 2009 | Xerox DocuColor 12 Color Copier
Xerox docucolor 12 system fault 15-362
Fault Code 15-362 - CAUTION: The Fuser Roll remains in a cammed-up position if power to the copier is interrupted while the copier is in use. The Fuser Roll will not be released from its position until the power is restored, the Power Switch is in the On position, and the Start button is pressed again. If the Fuser Roll remains in the cammed-up position for a prolonged period of time, copy quality defects will occur. To prevent damage to the Fuser Roll, switch the Power On as soon as possible after the power is restored, and make a copy of a document. If the machine is a DC 12LP send a print job from a workstation to prevent damage to the Fuser Roll.
Apr 15, 2009 | Xerox DocuColor 12 Printer
Docucolor 12 Power problem
Check the fuse in the plug, 13 amp, the trip switch on the back of the machine, if not then its probably a power supply problem on the machine. you dont actually state the docucolour which has this problem.
Also as for the waste containers, why do you want to know about something that is a given. The answer is they work differently, if you really want to know about the inside workings i will tell you but you will be bored
Dec 28, 2008 | Xerox DocuColor 12 Color Copier
Fow to you change a fuser nip clutch on DC12
With extreme difficulty if you don't know your way around the back of a dc12. Whats wrong with your machine?
Sep 04, 2008 | Xerox DocuColor 12 Printer
Xerox Docucolor 12
Error in the Fuser. The description for this fault code is: External Heat Roll Contact Failure. Generally the external heat roll retract motor is defective. The xerox part number of this motor: 127K21350
Aug 20, 2008 | Xerox DocuColor 12 Color Copier
Error 10186 docucolor 12
10-186 is a fuser problem.Check for jammed paper in fuser or low fuser oil.Might have bad fuser lamp or fuser thermal fuse.
Apr 23, 2008 | Xerox DocuColor 12 Color Copier
Docucolor 12 spills fuser oil
Pretty much all you can do is rebuild the fuser, either the meterins blade or wick are work out.
Mar 19, 2008 | Xerox DocuColor 12 Color Copier
10-359
make sure all the connections are in good shape. Look for a broken or slightly burnt connector.
A pinched wire may be the problem.
And the over heat thermistor may have blown.
Its a fuser sensing code. You may have to replace the fuser itself.
Feb 28, 2008 | Xerox DocuColor 12 Printer
How to clear a Machine Error 76
Error 76 is fuser error, you need to change the fuser but first just in case try to reset settings to factory defaults.
Nov 29, 2007 | Brother MFC 9600 All-In-One Laser Printer
Xerox DocuColor 12 Color Copier Logo
60 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
