Question about Sony KLV-32M1 32 in. HD-Ready LCD Television
Is the sony klv-l32m1 32in capable of working with sky hd box. i would like to know this before going ahead and purchasing also where could i find instruction manual for this model of tv many thanks
melnavz
  • 1226 Answers
SOURCE: Dark horizontal lines on Sony KLV-26HG2 LCD TV screen
If you can fix it by yourself, there is a problem in horizontal circuit panel, you need to check that in series because the part appear visbly good but when tested by the exact tester you register busted. that should be replaced immediately. Check also the vertical panel parts of the circuit. but if hard you do the job you may consult the service center of your TV or the vendor of the TV.
ps. please don't rate me if you are not convince of my suggestion.
best regards, melnavz
Posted on Apr 08, 2008
RFICKES
  • 51 Answers
SOURCE: Want external speakers for Sony TV Model KLV-S32A10
This is really easy. A pair of simple bookshelf speakers will do nicely. Simple speaker wire can be run to them, to extend whatever cable they have. If it's only screw terminals they have, so much the better.
You'll have to attach RCA plugs to the ends going to the TV, but that's easy.
Posted on Jan 04, 2009
  • 54 Answers
SOURCE: How to set SONY TV # KLV-S32A10 to receive HDTV channels?
the new lcd tv you have will pick up hd channels. run the autoprogramming for the channels for sd and hd. be prepared for about a 20 minute wait
Posted on Jan 24, 2009
welcomejee
  • 10594 Answers
SOURCE: 8 blinks from a sony bravia model klv-32s400a tv
8 blinks in KLV-32S400A shows Audio Error
Check audio voltage supply from power supply board, if OK, replace GP Board (main board)
and if audio volts are not available, check/ replace power supply board.
Posted on Feb 09, 2010
leusnerdus
  • 54 Answers
SOURCE: looking for a sony bravia klv-46x350a lcd spare
Usually the LCD panel cost is around 80% of total TV price. Look for it in a center of service.
Posted on Apr 20, 2010
How to connect antenna to klv 40u100m
Correct. You have to connect the antenna to another box and then take the output of that box to the TV. An old VCR is ideal as this box.
Dec 20, 2013 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Getting sky and the lady said my TV would be HD but there's no evidence of this - any way to "make" it HD with cables etc? Its a Sony KLV30HR3.
You only can get,what is in air broadcasting shows signals,u can't changes the signal modes format.You getting those shows in modes 1080i or 1080p.The shows have a display said HD logo on right side or left side of the tv.U are getting a HD air broadcasting signal.
Oct 03, 2010 | Sony KLV-30HR3 30 in. LCD Television
SKY DIGIBOX 2nd RF frequency
your in luck, I work for sky as an Engineer.
Firstly go to the main telly where your sky box is.
Using the sky remote press the following buttons.
SERVICES
0,1,SELECT
go to RF
In this menu I would set the RF channel to 38 and turn the power ON and then down to save.
now leave it on the blue menu screen (sky menu)
go to the other room where you link from your sky box is connected to.
press the tv button on that remote and then select channel 6 on the remote
Then go into the menu for the tv and then to setup. go to MANUAL TUNE/SEARCH with most new tv you can scroll down to were it says C _ _ you can then input your channel number as 38 the same as you setup on your sky box.
Dont forget to save the settings and that should be you. You should be able to see the sky menu on the telly with the link on. (that is why I asked you to leave the sky menu on that way you know you havent just tuned it into your normal terrestrial channels.
The reason I told you to turn the power onto the link was so that you can purchase a Magic eye. This will allow you to turn your sky box over from the 2nd room without having to keeping going to the main tv to change over.
here is a link to a random site with a picture of a magic eye on. you can purchase these from many places or even Ebay. here is the link anyway.
http://www.aerialshack.com/commtel-digital-link-magic-p-815.html
hope this sort you out. If so please leave a thumbs up
Cheers Little Dish Fitter
Sep 26, 2009 | Televison & Video
New sky hd remote will not operate sky+ box
Dont think so
Try resetting it by this method,it might work
To perform a RESET press [TV] and then hold [select] and [red button] together for around two seconds (until the red light blinks twice). Now press 999 (red light blinks once for a long time and then twice quickly).
Please let me know if this helps
JonnieC
Jan 18, 2009 | Directed 434MHZ Remote Control
Sony bravia 40" hd lcd gets picture but no sound from cable box
You will have to go into the settings of the hd box by pressing the settings button twice and then scroll down to "audio digital out". chances are that it is set to Dolby Digital. If you right arrow over you can then set it to HDMI. this should bring your volume back. Hope this helps.
Jan 15, 2009 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Jan 03, 2009 | Sony KLV-S32A10 32 in. HD-Ready LCD...
Sony kdl40v200
I work for sky as an Engineer (not a subby)
HDCP is the encryption sent down when a program is transmitted. Over the years I have had several jobs where this is the case.
What you can do to fix the problem is Download update for your sony bravia telly this will fix the problem. There is another solution, if you get another engineer out ask him to put a different manufacturers box in..... Sky HD is made by Thomson, samsung, pace, Amstrad,
both solutions have worked for me when coming across theses faults whilest installing sky... The first one is going to be your best option... for example at the minute all I am getting when i go to pick my HD stock up is Amstrad. No other manufacturers so you may find it hard for the engineer to source you a different make.
If neither work. Force a download to your HD box (they have been updating the software recently so this may also work for you.)
Take the power out the back of the HD box. hold down the Standby button then reinsert the power. hold Standby button in until all light are lit on the front of the box... Then wait 10 minutes (better off making yourself a cuppa) give that one a try.
Hope ive been of some help to you
Little Dish Fitter
Sep 17, 2008 | Sony BRAVIA KDL-40V2000 40 in. LCD...
TV CABEL SETUP
Not legally no...
I used to install cable for the cable company and no, each region has there own converter box, and cables hq needs to know about the code on the back of the box in order for it to work.
Digital cable only works when the cable company activates your converter box, so you have to pay for it one way or another.
Aug 27, 2008 | Sony BRAVIA KLV-40U100M 40 in. HD-Ready...
Sony Bravia
I have purchased KLV-40W400A Full HD but I am not satisfied with the picture quality. When the issue was raised sony is putting blame on Tata Sky and vise versa.
Kindly suggest.
Jun 19, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
Sony KLV-32M1 32 in. HD-Ready LCD Television Logo
137 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
