SOURCE: Electrolux tumble dryer
Power it down and then restart. Turn breaker off
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
SOURCE: electrolux edc77570w dryer is locked and
the only way i know of this is pull the plug out the wall socket then take the lid off the dryer and look down inside to were the door lock is fitted you should see a pull cable that unlocks the door give it a tug and the door should pop open? we hope???
SOURCE: AEG Electrolux Lavatherm 57800:
try cleaning the drum contact on the rear of the machine. It is a carbon brush that contacts the drum spindle. It can get covered in carbon from the brush.Remove the plastic cover containing the contact brush, clean out all carbon dust and lightly sand the drum spindle to remove any surface build-up and ensure a good electrical contact then reassemble.
SOURCE: Electrolux edc77570w dryer. No power problem-
It can be the control panel that is not switching the main motor to spin or the functions to start off. But it is most required that you MUST trace and check the main power line to confirm if this is related to the program unit.
Check this link for tips:
http://www.espares.co.uk/advice/tumble-dryers/a/9
Good Morning friend, thanks for your inquiry!
Based off the information you have provided your Electrolux frontload washer the door will not open and the timer is stuck. I would recommend performing a reset on your washer and you can do that by unplugging the power cord or flipping the household circuit off for ten minutes. If that does not help to resolve your issue I would suggest consulting with a professional technician for an accurate diagnosis. It could be a potential problem with your control panel or door latch assembly. I hope this information is helpful. -Matt
Hello Serban Alexandru - Typically error code E22 indicates that the water is not pumping out fast enough. Does the drain pump make a humming noise? If so, there may be a restriction in the drain line or siphoning. Otherwise since it is such a complex unit I would recommend contacting a professional to have the pump, timer or main control board diagnose.
