Setting jumper foe slave
Where do you set the jumper on Toshiba SH-S182 for slave.
The answer is eched into case of player at rear, centre pins are for slave, SL.
Posted on Nov 20, 2009
I require the driver for Samsung SH-S182 DVD±RW for my Home -System since my device manager is reporting the same was missing or corrupted.
You can find you driver here :
http://www.opendrivers.com/driver/240991/samsung-sh-s182m-dvd-writer-firmware-sb06-windows-98se-me-2000-xp-free-download.html
Oct 29, 2010 | Samsung SH-S182 DVD±RW Dual Layer Burner
POSITION OF SLAVE/MASTER JUMPER on rear of unit Toshiba-Samsung SH-M522 Combo
You'll find jumper instructions in the user manual which is available on Samsungs website (http://www.samsung.com/us/support/detail/supportPrdDetail.do?menu=SP08&prd_mdl_cd=SH-M522C%2FBEBN&prd_mdl_name=SH-M522C&prd_ia_sub_class_cd=P ). However, most drives have jumper setting key on the drive label. The choices are usually master or slave or cable select.
Oct 25, 2009 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Hello my samsung sh-s182 dvd -+rw doual very slow burn nor456@yahoo.com
First look and see the write speed of the drive. 1x to 4x is slow but recommended by all programs and this is initially the default settings for most programs. You must goto the settings of your dvd burning program and set the burn rate to 16x or higher.
Sep 25, 2009 | Samsung SH-S182 DVD±RW Dual Layer Burner
Burns at a very slow speed no matter what i set it to. cds or dvd same problem. samsung sh-s182
Okay, first, are you using an older 40 pin ide cable? If so, get an 80 pin.Also check that the drive is jumpered properly. Cable select is for squids...set it right. If the drive is connected to the end of the ide cable, set it as a master. If it is connected to the middle connector, set it as a slave.Also, check the properties of your hard drive controllers (not the drives themselves) in device manager. If the advanced properties show any controller as being in PIO mode, set it to dma, and reboot. If you are unable to get it out of pio mode, run the script here:
http://winhlp.com/node/10
If this doesn't help, get back to me and I'll try to help more :)
Aug 27, 2009 | Samsung SH-S182D DVD RW Dual Layer Burner
I/O Magic drive is really Toshiba SH-S182 - I need jumper help
The jumper settings are located in the manual. You can download it here (it takes a few minutes to download). I have tested it and it does work and has the jumper settings for you.
I would be most grateful if you would rate my answer for me. Thank you.
Aug 01, 2009 | Samsung SH-S182 DVD±RW Dual Layer Burner
How to set a Toshiba MK8064GSX hard drive as a slave? The web site shows a group of 4 pins (2 over 2) This drive has 4 pins in a row.
u have to set the jumper to the set of 2 pins that are after the power cable socket
suppose this is the powercable socket 0000 then the jumper will be set to the 2nd row of the folling pins assembly that will be 0000 :[:]:: jumper position -> [ ] look in to the pic and u need to set the jumper on the pins that says slave
Jul 08, 2009 | Toshiba MK8034GSX 80 GB SATA Hard Drive
Cdw dvd sh-m522c
please have a look to your jumper setting...
if you didn't got your dvd driver after jumper sittings then reply to this thread.
Nov 21, 2008 | Samsung (SH-M522C/BEBN) CD-RW/DVD-ROM...
Unable to detect second
Check the jumpers on the back of the drive to ensure you have no conflicts. There are 3 settings M, S, CS which mean master, slave and cable select.
Cable select requires a special cable in your computer with fine pitch 80 wires, usually with one blue connector at the motherboard, one black for the master drive and one grey for the slave. This colour code is not used by all computer manufacturers, though and they may all just be grey.
If you have this cable, make sure the jumper on your drives is set to CS. Otherwise, on each cable (there should be 2 in your computer and the hard drive should definately be master on one) you can have only one master device and one slave.
Jul 17, 2008 | Samsung (SH-S162L/BEBN) DVD RW Burner
If the drive is "Master" (the first drive in cable line installed) then the jumper goes to "MA", if it is a "SLAVE" connected drive then the jumper goes to "SL".
May 06, 2008 | Samsung SH-S182 DVD±RW Dual Layer Burner
SH-S182 installation
before anything else.. your computer must not be plugged in
have some screw drivers ready
open the case
remove the connections of your old cd/dvd-rom
remove the screws
remove the drive from the bay
replace it with your new dvd writer
replace the connections and the screws
put everything else back
then turn on your system :D
Nov 02, 2007 | Samsung SH-S182 DVD±RW Dual Layer Burner
Televison & Video Logo
57 people viewed this question
Top Televison & Video Experts
