Question about Samsung Smooth SCH-u350 Cell Phone
How do I get my remaining minuts on main display?
Kenmore elite washer
hi
unfortunately the programmer is faulty
Dec 31, 2017 | Kenmore Washing Machines
Equity Wireless thermometer Outside temp never registers
From their instructions:
RESTART:
  • RESTART DISTANCE: For best results please bring the outdoor sensor in the house and place 5 feet from the display unit.
  • REMOVE POWER: Remove batteries from the sensor. Next remove batteries (and/or a/c cord) from the display.
  • DISCHARGE ELECTRICITY: With the power source removed, press one of the buttons on the display at least 20 times to clear all stored power. Please do this even if the display is blank to remove any remaining power. Verify the display is blank.
  • UNPOWERED FOR 15 MINUTES: It is important with most of our displays to remain without power for at least 15 minutes.
  • NOTE: Failure to allow a display to rest for 15 minutes can result in failure to connect with the outdoor sensor or missing segment on the display. The instruction manual describes a setup for a new unit that has not had time to build up stored power.
  • BATTERIES: Please be sure you are using fresh batteries tested to a minimum of 1.48, on a voltmeter that reads in numbers.
  • SENSOR FIRST: Place batteries into the outdoor sensor first. Make sure they are installed according to the polarity diagrams in the battery compartment.
  • DISPLAY NEXT: Install batteries (or a/c cord) into the display according to the diagram in the battery compartment.
  • CONNECTION: Allow the sensor and display to remain 5 feet apart for 15 minutes to establish a strong connection. Do not press buttons at this time. You should see a reading on the outdoor temperature area in the first minute.
Gary
Jan 07, 2011 | Garden
I have a Fujitsu Lifebook LBS6120 notebook
Turn on as you did before and leave on for 10 minutes. Then, try turning OFF the computer by keeoing the POWER button pressed for 7 secons. If the computer goes off, then your screen is fried and the computer is actually booting up normally... you just can't see it ;)
Mar 17, 2010 | Fujitsu LifeBook E8010 Notebook
Hi - I have a 47" LCD and just a minute ago I heard a very high pitched noise coming from it. I was unable to turn it off so I unplugged it. I can turn it back on but the touch keys remain lit up and the...
Ur Main turner signal board is dead.Replaced this Tuner board will solved this problems.Tries Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board. to replacement.
Mar 10, 2010 | Vizio VO47L 47 in. LCD TV
Westinghouse LTV-32W1 Plays for awhile then no sound or picture
could be two thing the new ps board you put in was defective or the inverter board is failing
Dec 07, 2009 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
My DELL laptop display goes off after few minutes of working. But the system remains working and you can switch off the system by pressing the off button. But when you on the system the display appears but...
read up on your manual on how to shut off the monitor (so that you can use an external one). it may be toggling on. other options are to make sure you have the newest driver and also to shut off the screen saver function. does this happen when you are plugged into the mains or just when you use battery ?
robert
Sep 02, 2009 | Dell Latitude D505 Notebook
Hiya, I've got a samsung u900 and when the phone has been idle (slider down and keys locked) even for just a minute when some one rings me the keys light up but the screen remains blank no light or...
Adjusting the duration of the backlight
To adjust the duration, perform the following steps:
1. At the main screen, select Menu.
2. Scroll to and select Settings.
3. Scroll to and select Display settings.
4. Scroll to and select Light settings.
5. Scroll to and select Backlight time.
6. At On, press the OK key.
7. Scroll to one of the following options, and then select OK:
  • 10 seconds
  • 30 seconds
  • 1 minute
  • 3 minutes
  • 10 minutes
8. Scroll to Dim and press the OK key.
9. Scroll to one of the following options, and then select OK:
  • Off
  • 5 seconds
  • 30 seconds
  • 1 minute
  • 3 minutes
10. Select Save.
Aug 07, 2008 | Samsung Cell Phones
Display panel (cont.)
hi there try pressing and holding the start button for about eight seconds
Oct 10, 2007 | Hotpoint Aquarius WD640 Front Load...
Display panel
Check to see if any water remains in the machine . SOME MACHINES IF They DO NOT DRAIN OUT ALL THE WATER WILL CONTINUE TO run until all water is drained. Also check for suds in machine if machine senses suds it will try to re rinse the clothes.If your machine has a filter at the bottom clean it out .
Oct 09, 2007 | Hotpoint Aquarius WD640 Front Load...
Samsung Smooth SCH-u350 Cell Phone Logo
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
