Question about Archos AV 700 160-Hours Video Recorder
Hi there, i have an archos av700 100gb series 1 mobile dvr which has died. The charger blew and it will not switch on anymore. i have checked the battery and that is displaying a charge and teh repplacement charger is delivering power to the battery charger terminals. is there a way of resetting the av700 or is it a repair item/expensive ornament
  • 3 more comments
  • jimmygallagh Nov 21, 2009
    thank you for the suggestion, the cost of repair not more than the unit? what level of cost would you anticipate
    can you tell me who i should send it too? would you mean archos?
    who do you recommend sending it too, archos or some independent
    hi again,
    i received anothr archos charger and when i plugged that into av700 it lite up the on button
    unfortuneately it went off shortly afterwards when it was sort of powering up. on this basis do you think it may be a damaged dc input?
    good solution but i was hoping to sort it myself without going to the dealer
    Genius:
  • 1,112 Answers
Hello: When the charger blew it may of blown a surface mount protection fuse in the unit itself. I suggest you send the unit in for repair. Servicing this unit yourself will be difficult to do as you will need the exact type fuse to replace on the main board of this unit. The cost to repair should not exceed the cost of the unit itself.
Posted on Nov 19, 2009
  • Lavell Turner
    Lavell Turner Nov 21, 2009
    I would think this type of repair should not run you no more then $60.00 to$75.00 for the repair, this does not include shipping and handling though. This unit still sells for around $210.00 dollars so I would say spending close to $100.00 might dem worth the repair.
    Good Luck, HAppy ThanksGiving!!
  • Lavell Turner
    Lavell Turner Nov 22, 2009
    Hello: I recommend you sent it to the manufacture as they will have the correct parts for this unit. If the power button lit up then you may have a bad DC to DC converter IC on the main board assembly gone bad..
Having problems gettin sky channels through archos i get to setting infrared settings and can not get code.dont know wether to connect dvr t the tv or the sky box
Remove the DVR station from the box, and attach the DVR adapter plate (found in the
DEVICE box); it is correctly attached when it clicks on.
-Take the Black Audio/video Marked "output" cable, and insert the connections into the corresponding coloured sockets, yellow>yellow, green> green etc. Make sure they are
inserted into the TOP row on the back of the DVR Station "Marked Out". The remaining
black connector should be plugged into the SW socket, which can be found underneath
the orange socket on the back of the DVR station. (If after setting up your ARCHOS the
picture is very green remove the black cable from the SW socket)
-Plug the SCART connector into the SCART socket on your TV set. These are usually
marked AV1, AV2, or Ext 1, Ext 2, L1, L2, Line in 1, Line in 2, Aux 1, Aux 2, make sure you
select the corresponding channel above (ie AV1 AV2 etc) on your TV set when you turn on
the TV.
-Attach the UK plug adapter to the Mains charger, and plug the charger into the DC-In
socket on the back right of the DVR station. Turn the mains on at the socket.
-Insert the powered off ARCHOS unit onto the DVR station, the unit will now power on,
and ask if you want to 'Switch to TV out', select 'Okay'. The 'TV output configuration' set
up will load up. Select 'Okay'.
-TV connection: When your DEVICE is connected to the optional DVR Station you need to
select the type of video output (Composite, S-video, component, RGB, HDMI etc), based
on how you have connected the DVR Station to your TV and what possibilities your TV will
allow. For the cables supplied and the instructions aboce you will need to select either
RGB or Composite. Use the arrows to go through the options and select either RGB or
Composite.
-TV Standard: this should be set to PAL (Europe). Select 'Next'.
-Now you need to test the settings, select 'Okay', the ARCHOS home screen should now
be visible on your TV set. If you have nothing showing on your TV, scroll through the
AV/Ext channels, the channel will correspond to the AV/Ext socket you connected the
cable to on your TV set. Use the ARCHOS remote to select 'Okay'; you have now set up
the output connection settings for your DVR station.
-You may need to adjust your output from the ARCHOS to match your TV, from the "TV
Format" options. Use the arrows on the ARCHOS remote to select the format of your TV
screen, so the ARCHOS unit outputs the correct picture size (ie 4:3 / 16:9 etc). Use the
arrows on the remote to select 'Next'.
Dec 24, 2010 | Archos 605 WiFi Digital Media Player
Record xbox to archos 604
The dvr station must sit in the middle of the signal transfer from the box to the tv, so connect the Xbox to the dvr station and then connect the dvr station to the tv. You will have to enaure that the DVR station is always powered on so that the signal will pass through it. to record simply select the record option on the 604
Apr 09, 2010 | Archos 604 Digital Media Player
My Archos 604 wifi only play a few minutes after charging.. I have used the dvr, usb and wall charger and nothing helps.. is my battery kaput? also since messing with it the touchscreen isn't working......
it must be the battery..While charging is pilot lamp lightning ?
To verify,just plug the USB cable to see if device battery charging circuit is working..Device should work normally..
If it does,either your battery is dead or its charger needs to be changed.
Kazim
Sep 13, 2009 | Archos 604 WiFi Digital Media Player
Archos 604(Gen 4), Remote(Archos DVR Station Gen 5) Work or not?
If you mean will the Gen 5 DVR Station Remote work with a Gen 4 DVR Station, I believe it will for at least the basic player controls on your 604 (except for the alpha keyoard entry because the Gen 4 players did not have this feature enabled).
If you mean, will the Gen 5 DVR Station Remote control your Archos 604 directly (without a dvr dock), the answer is no, you must have a DVR Station for the remote to work on any Archos player.
Hope this helps.
Jun 21, 2009 | Archos 605 WiFi Digital Media Player
How to set up Archos DVR Station but unsure how
Hi awillis98 this is Mike Houston of DISH Network, with the Archos DVRstation there will be a USB connection from the device to the DISH Networkreceiver, one the DISH receiver has recognized the external hard drive you willsee pop-ups on the screen that will walk you through the steps to configureyour Archos device. I will send a link to help with the setup for the externalhard drive. http://www.dishnetwork.com/SupportSection/setup-ehd
Apr 21, 2009 | DISH Network ViP622 DVR DTV Receiver /...
My Archos 705 is not turing on.
704/705 will not power up at all without a bettery that has a little charge. If these batteries are not used they have a tendancy to die. you could try charging it on a DVR for a few days. then when you disconnect it from the DVR immediatly connect it to a DC charger and your lights should then work. Either way I would consider id a warranty claim.
Jan 20, 2009 | Archos 704 WiFi Digital Media Player
DVR to Archos
That's what the DVR does. All you need to do is play whatever program you would like on your cablebox/DVR and hit record on your archos. It will record it like any program.
DamPinou
Mar 25, 2008 | Archos 605 WiFi Digital Media Player
Archos 604 not recognizing DVR Station
Check the power pack for the DVR station and see if theres a green light still lit. I've had two power packs for the DVR station fail. This will cause the syptoms your seeing.
Oct 29, 2007 | Archos 604 Digital Media Player
Archos AV 700 160-Hours Video Recorder Logo
87 people viewed this question
Top Archos Televison & Video Experts
Steve Sweetleaf
Steve Sweetleaf
Jaime Hernandez
JonSnell Electronic
JonSnell Electronic
Are you an Archos Televison and Video Expert? Answer questions, earn points and help others
