Question about Compaq Refurbished SYSTEM BOARD 810E CHIPSET FOR DESKPRO Motherboard
I'm using compaq deskpro board. pentium III 1ghz. i cannot enter bios due to keyboard error (code=304). Test the keyboard on other pc, working well. Pls, help me
  • mrprosperous May 11, 2010
    What type of keyboard are U using is it Serial or USB?
  • Don Matthews May 11, 2010
    Since you have posted under a "Refurbished" heading, it sounds like you may have problems that were not resolved by the last refurbishment by the HP/Compaq folks - or if you bought the unit used...that may have been why the previous owner got rid of it..... The error code 304 is a Compaq POST error that indicates a Keyboard or System Unit error. You have confirmed that the problem is not with the keyboard, so the problem is with the system board itself, and probably NOT repairable.
    Sergeant:
  • 309 Answers
Code 304 = Keyboard or system unit error. Not repairable. You will have to replace the system board.
Posted on Nov 19, 2009
510-splash scree is corroupt
Repairing through recovery console:
Boot form cd
Enter recovery console
Enter your password for windows
Type and enter copy F:\i386\ntdetect.com c:\ assuming f is your cd drive letter
Type and enter copy F:\i386\ntldr c:\
Type and enter fixmbr, yes to agree
Type and agree to fixboot
Type exit to get out of the console and exit the installation and reboot. The above should fix files needed to boot.
Hope this helps
Nov 11, 2011 | Intel Compaq Deskpro EN Pentium 3 1Ghz /...
Bios
what information do you need on bios
May 15, 2011 | Intel Compaq Deskpro EN Pentium 3 1Ghz /...
Compaq Deskpro EN 1GHz. power supply is ok. But not start with power on button. Green LED on mother board is on. How can I start this with start button (I think motherboard board problem.
Unplug it from the wall. Remove the side panel. Look for a small circular battery (similar to watch battery). Remove the battery for 30 seconds. Replace the battery, plug it back in. This should reset the bios. Green light on the board does not necessarily say good power supply as well. Very likely motherboard or power supply.
Dec 11, 2010 | Intel Compaq Deskpro EN Pentium 3 1Ghz /...
Hard disk supported by pentium iii 1ghz compaq deskpro
well it is 160 gigabytes in IDE but you need maximum RAM so as to ensure proper balance
Dec 06, 2010 | Compaq Computers & Internet
Please I need the media player for compaq deskpro pentium 3 what type of media player is required????
Try Windows Media player that comes with your Windows operation system. For Real media, try Real player. Also you can try Media player classic.
Aug 24, 2010 | Intel Compaq Deskpro EN Pentium 3 1Ghz /...
Compaq deskpro en pentium iii no video
Sounds like the video card has quit. It may also have onboard video. I would try a new video card or try onboard video (if equipped). Good Luck
Nov 23, 2009 | Intel Compaq Deskpro EN Pentium 3 1Ghz /...
Tried swapping pIII 550 mhz slot one processor for Pentium III P3 1GHz Slot 1 CPU 1000MHz /256/133 SL4BS in deskpro en p550.It wont do anything, screen is blank.Compaq told me i could go as high as...
This isn't a sure fix by any means, but...
You could try unplugging the unit from the wall socket and opening the case. Touch a metal component inside the case for a few seconds to equalize static charge between yourself and your machine.
Next, remove the battery on the motherboard, and wait 5-15 minutes before reinstalling it. What this will accomplish is to reset the computers' BIOS (Basic Input Output System) settings to the defaults for the motherboard, which may let the machine figure out what processor you installed.
If it works, your machine will boot up, and you'll get an error message telling you that there is a checksum error or simply that a BIOS setting is wrong. You'll have to read the message and press the appropriate key to get into BIOS, then reset the date and time.
I hope this helps in some small way- It's rough attempting to set up a machine if you have no visual output to let you know what's going on.
If my solution gets you up and running, please let everyone know by writing a testimonial.
Oct 18, 2009 | Compaq Deskpro EN PC Desktop
System unit error in pentium 3 compaq presario
304 error reffers to keyboard error. Verify if your keyborad is properly plugged in, also verify if it's working (pressing Num Lock will turn on the led, pressing again will turn off).
If you plugged in an USB keyboard it won't work, it is necessary to be present an PS/2 keyboard.
Sep 02, 2009 | R.A.M. Computers Compaq Presario 1075,...
Computers & Internet Logo
212 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Abhinandan  Patil
Abhinandan Patil
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
