Question about Haier HDN655E 65 Pint Dehumidifier Dehumidifier
It turns on but won't start,do I need to fill tank w/water?
    President:
  • 3,433 Answers
If it's on humidifier, It has to have water. Dehumidify, no
Posted on Nov 20, 2009
Water does not fill in the Aprilaire humidifier on my furnance
It sounds like the feed has been shut off or pluged. Be sure the feed is off, remove the feed from the humidifier. open the fill valve slowly and run water into a bucket or whatever. If it does not run you found the problem, if it does then it is probably the fill solenoid valve on the humidifier.
Mar 21, 2014 | Edison 40 Pint Dehumidifier
Do I have a filter I need to change in my dehumidifier MHDW
i assume you have a humidifier and not a DEhumidifier? putting water in a dehumidifier defeats the purpose. it should remove the water from the air. don't fill the tank on the bottom. empty it. as for the filter, just use a vacuum across the front fins to remove the dust.
May 10, 2012 | Windchaser MDH-W Dehumidifier
My Kenmore Dehumidifier wont turn on. There is power to it ,all the indicator lights are on, it just wont start. What's wrong?
Check the over fill switch in the tank. If this is stuck it thinks the tank is full and won't come on. After that your compressor may be bad or the starter for the compressor. The Dehumidifier is basically a small air conditioner that condenses moisture in the air then it drains into the tank.
Jul 13, 2011 | Kenmore Dehumidifiers
I have a sunbeam 1387 warm mist humidifier. I need to know how to clean scale from the filter. It looks like it can be taken apart. Can it?
Actually, Carol, it shouldn't be necessary to take the unit apart. Mix a 50/50 solution of White Distilled Vinegar and Bottled Distilled Water (enough to fill the tank). Pour the solution in and allow it to sit overnight. Then empty the solution and fill the tank with Bottled Distilled Water. Turn the unit ON and allow it to run for 1 hour. Then empty any remaining Distilled Water. Doing all the aforementioned, should have not only cleaned the filter, but also the unit itself. If you use Bottled Distilled Water in the future, rater than tap water, the filter and the plumbing of the unit will stay clean longer and will require less maintenance.
Hope this helped you. Please let me know. Thanks.
Jun 26, 2011 | Sunbeam Warm Mist Humidifier Dehumidifier
Water overflows when filled how do I adjust?
Remove the tank and locate the switch and 'teeter' (that the tank sits on). Make sure the tank is able to move when filled. You will have to adjust the position of the switch to allow the filled (teetered) tank to shut the device off.
Is it possible for you to drain the water into a nearby floor drain using a hose?
Thanks for your question @ FixYa.com
Jun 26, 2011 | Goldstar DH2510A Dehumidifier
I have an ebac dehumidifier i think 6000 model and it appears to work fine. the fan runs ok the compressor seems to kick in ok but the tank will not fill. i had it on in my room for approx 30 mins and...
If the room temperature is close to 60, the coils may be frozen (completely encased in ice). If this is the case, move it where the water can drain off - about 1 gallon which may NOT run into the drain bucket.
I out mine over the floor drain.
Turn off and it will defrost over night.
Only specially made dehumidifiers work below a room temp of 60 degrees (the temp of a basement in winter).
Does it need to be running? A digital humidity sensor from Radio Shack is cheap and may tell you the humidity is OK - only 50% or less.
Dec 19, 2009 | Ebac HD880 Dehumidifier
Attached a pump to drain collected water. The
the water should still collect into the tank. the dehumidifier had a float switch that shut the unit off when the tank is full. In turn it should have a second switch, probably a float switch that turns the pump on and off so that the pump doesnt continue to run when there is no moisture in the tank
Nov 26, 2009 | Frigidaire FDL50R1 Dehumidifier
The water fills the tank but does not go out of the hose and drain to the sump pump as designed
Check the hose for clog up as well as your sump pump. Have your hose unclogged and let it run. Check the sump pump if this is running. And if it is, and still no water goes out. Open the sump, and check the impeller for defect. Impeller is the one that turns around to push the water out. If it is defective, you must replace it to make it run.
Once you are done, power it up and start it.
Sep 27, 2009 | Haier HDN655E Dehumidifier
Help! Water keeps filling the tank instead of going out the hose
Had the same problem. Make sure you tighten the house a little with pliers. Also, make sure the dehumidifier is up a lot higher than where you're draining it into. Mine drains into a utility sink. But I have the dehumidifier propped up onto a dresser. I cut a small piece of hose to run into the sink. Seems to be working now.
It will take 5 min or so to establish a water flow, so be patient after you hook everything up. Good luck.
Jul 07, 2009 | Danby DDR586R Dehumidifier - 58 Pints...
No water filling in tank (whirlpool Gold AD70USS 70 Pint Per Day)
the unit has a sealed system leak that need to be repaired by sears 1-800-905-9505 for service
Apr 13, 2008 | Whirlpool Gold AD70USS 70 Pint Per Day...
Dehumidifiers Logo
37 people viewed this question
Top Haier Dehumidifiers Experts
Steve
Shawn DuRee
Michael Youngman
Michael Youngman
Are you a Haier Dehumidifier Expert? Answer questions, earn points and help others
