Question about Astar LTV-19BG TV
Vertical colored lines scrolling across the screen. unable to turn on or off
    Sergeant:
  • 309 Answers
Call the repair guy. If you can't turn the unit off, there are problems that you probably can't repair yourself.
Posted on Nov 19, 2009
Samsung LED TV, Model# UN55B6000VFXZA turns on to black screen then displays large blocks of colored vertical lines?
check every flat cable main boerd to t-con t-con to display if dont help display is a problem
Feb 24, 2017 | Samsung Televison & Video
What part is needed to fix colored vertical lines across entire screen of Samsung tv
If you wish to get some details; check the site linked here. Pull up older posts.
Line faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent. Faults to all LCD & Plasma screen are similar, irrespective of its brand and screen size.
Oct 06, 2016 | Samsung UN60ES8000 60" 1080p LED 3D TV...
Line across middle of screen.
The line of color is due to a failure in the vertical circuit. The main suspects are the vertical Ic AN15525A and/or capacitor c308 220uf@35volts
If you have the capacity to do so, you should check the other electrolytic capacitors in the vertical circuit which are USUALLY located near the vertical IC in most cases
you can purchase the part at
https://www.encompassparts.com/webwiz/wwiz.asp?wwizmstr=WEB.SEE&partnumber=5760279&smodel=CT32SL15N
or mcm electronics
Mar 13, 2009 | Panasonic CT-32SL15 32" TV
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Mar 08, 2009 | JVC Televison & Video
RCA r56wh78 scrolling vertical bands
it is going to need to be tested to find the component that is causing the problem
Oct 21, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Vertical color lines
I had the same thing happen to me this morning. I turned on the TV and it had colored vertical lines through the whole screen. I called Sony and they had me unplug the TV for about 15 minutes. This solved the problem. They said the boards just needed to be reset. It fixed the problem and I am happy with my Sony once again.
May 22, 2008 | Sony KDF-E50A10 50 in. LCD HDTV
Mag innovision LT716s monitor
When I turn on my computer the monitor takes a long time to warm up and colors change and vertical lines flash across the screen from right to left before the screen becomes normal again. Now the power light even goes out upon turning on my computer and I have to unplug the video cord and plug it back in to start the screen back up which even takes longer.
Feb 19, 2008 | Mag Innovision LT782S 17" Flat Panel LCD...
Astar LTV-19BG TV Logo
93 people viewed this question
Top Astar Televison & Video Experts
Jaime Hernandez
ted dux
Are you an Astar Televison and Video Expert? Answer questions, earn points and help others
