Question about Vacuums
Power cuts maybe after 10 mins use, then after switching off for an hour or so, it works again! repeat.
  • 576 Answers
I would think that it is probably a motor going bad and tripping the overload switch. After the overload resets, it will run again. Is there a chance that the motor is still under warranty? Some vacuum maker warranty the motor for longer than the rest of the vacuum (Dirt Devil is 6 years on the motor) so hopefully they will fix it for free. One other thing, should be obvious, but I'll ask anyway -- the brush is turning properly and the vacuum has suction when it is working, right? if something is jammed that could overload the motor as well.
Posted on Nov 19, 2009
    Genius:
  • Vacuums Master
  • 1,474 Answers
Sounds like motor overheating clean all filters , Should cure....
How do I program a Micronta programmable timer--I set the time to have it go on, but how do I set it to go off?
LCD Programmable Timer (630-0892) Operation Faxback Doc. # 17153 Setting The Time and Day Follow these steps to set the current time and day. 1. Slide RUN/PROG/TIME SET to TIME SET. 2. Press HOUR to set the hour digits. Pressing and holding down HOUR rapid- ly advances the hour digits. NOTE: P appears to the left of the hour digits to indicate P.M. hours. 3. Press MIN (minute) to set the minutes digits. Pressing and holding down MIN rapidly advances the minute digits. 4. Press DAY until the correct day abbreviation appears. 5. Slide the RUN/PROG/TIME SET switch to RUN. The colon flashes to show the clock is running. NOTE: Keep this switch set to RUN to prevent accidentally changing the time. Setting The Timer The timer has 14 settings (1-14). Odd numbered settings specify a time to turn on the appliance and even numbered settings specify a time to turn off the appliance. Follow these steps to set your timer. 1. Slide the RUN/PROG/TIME SET switch to PROG. The display shows the first setting. If you have not entered any setting, the display appears as shown in the illustration. 2. Press Event to select a setting to enter or change. 3. Press Hour to set the HOUR digits and press MIN to set minute digits to the correct time. NOTE: Be sure P appears to the left of the hour digits when you want to set a P.M. hour. 4. Press Day to select the day of the week for this setting. If you want the setting to apply to every day of the week, repeatedly press DAY until all day indicators appear on the display. 5. When you finish entering the setting, press EVENT. The timer advances to the next setting. 6. Repeat Steps 3 through 5 to enter additional settings. NOTES: Be sure to set the timer to turn off the appliance. The appli- ance remains on as long as there is power if you do not set a time for the appliance to turn off. To replace an existing event, select its setting number and set the new event time. To clear an event, select its setting number and press CLEAR twice. Be sure to clear both the on time and the off time for an event. If you set the timer to turn on the appliance every day, be sure to also set the timer to turn off the appliance every day. 7. Set the RUN/PROG/TIME SET switch to RUN. NOTE: You must set this switch to RUN to turn on or off the appliance either automatically or manually. When the timer automatically turns on the appliance, ON appears on the display and the indicator lights red. When the appliance turns off, the indicator turns off. Reviewing The Settings To review the settings in your timer, set RUN/PROG/TIME SET to PROG. Setting 1 appears on the display. Repeatedly press EVENT to view the other settings. NOTE: To determine event being programmed, pull the power for a period of 5 minutes. Then re-power the unit. The first event will be "ON" and the next will be "OFF", etc. There will be a number to the side of the display that tells you which event you are programming, The even numbers are "OFF" and the odd numbers are "ON" events. (EB 3/17/97) (EB 7/16/97)
Privacy Policy
Sep 10, 2010 | Vacuums
Stop working. brush was cloged. It there a reset button?
i had a similar thing happen and just got off the phone with dyson. there is a resettable switch on the handle. they told me to start the vacuum in the upright position, put it in the non upright position, then push and hold in the beater bar switch which is located next to the on/off button for 10 seconds and the beater bar should start to function once again
Jul 15, 2010 | Dyson DC07 Animal Bagless Upright Cyclonic...
I have a DC04 and when i switch it on it works for 10-15 mins thens stops working for about 20 mins then starts working again.
Your vacuum is overheating - that's why it cuts out. You need to check everywhere possible for blockages and also make sure the washable filter is clean and dry. If the machine has been run without the washable filter in place, then the exhaust filter will be clogged and will have to be changed too.
Feb 17, 2010 | Vacuums
My dco7 quits running after 10 min I wait 15 min to start again
This is a sure sign of a blockage. The motor cuts out because it gets too hot and will start again when it has cooled. Follow the instructions in your user manual for clearing blockages (you can download a copy from the Dyson website if necessary). Make sure the washable filter is clean too (and completely dry before you use it).
Jan 13, 2010 | Dyson DC07 Bagless Upright Cyclonic Vacuum
Just stopped mid hoovering and now won't switch on!
It is probably a thermal cut-off which is caused by a blockage. The machine will turn itself off before it overheats if it is a thermal cut-off. Once it has cooled down, you will be able to turn it back on again (usually 30 mins - 1 hour).
If the machine doesn't turn on at all anymore, you may need to replace the power switch. Call the Dyson helpline, they will do a blockage troubleshoot and if it's not that, they will tell you where you can find an authorized Dyson repair dealer in your area.
Jul 07, 2009 | Dyson DC07 Bagless Upright Cyclonic Vacuum
THE VACUUM CLEANER WORKS FOR 6-7 MINS THEN CUTS OUT, THEN AFTER A WHILE STARTS AGAIN FOR A FURTHER 6-7 MINS THEN KEEPS REPEATING THIS PROBLEM
What you describe is typical of a machine that's overheating. This is almost always caused by a blockage. Check the machine thoroughly for any blockages, including any filters, and my bet is that you will find something that shouldn't be there that needs removing (or possibly replacing). I hope this helps.  Good luck!
Mar 02, 2009 | Electrolux UltraLux 2000 Bagged Canister...
Over heated hover
http://geeksquad.fixya.com/ThreadView.aspx?prdid=0&thid=632385
Generic problem for all Vacuums
Over heated hover
Posted by blade123 on May 29, 2008
Hi there, I’ve got a upright Hoover and it cuts out after about 5 mins I think it’s over heated but if i leave it for 5 mins it works again but cuts of again how can i fix it?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. It is possible that you my have a heat sensor, but as far as what you described you need to change both belts, the brushroll belt and the power drive belt as well and @ the same time. The average belt change is every 4 to 6 months on the vacuum. Does it stop completely or is it just the belt problem. Or #2 is the vacuum giving off a burning smell other than the belts and if it does it could be the motor. Other wise , please call the factory or a local Hoover warranty station in your area. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 29, 2008 | Vacuums
Why does my dyson dc04 work for about 5 mins then cut out
I spent 4 years working on Dyson v/ceaners in the Uk
So, heres what to;
Check your filters - and for blokages in the hose and brush comparments,you have one in at top of the bucket called pre motor filter and one on top of the motor where the bucket sits called post motor filter. If these are worn and mucky wash them or replace.
Switch on your Dyson with no filters in and leave running to see if it cuts out. (in side on the motor their a liitle device called a TOC thermal over load cut out device. when the motor runs too warm - the TOC with cut power to the motor and will work again when cooled down.
Good luck.
Mar 18, 2008 | Vacuums
MY CLEANER CUTS OFF
My Hoover S3639 on/off switch stopped working. I don't hear the 'click' any more. I removed the top of the vacuum but can't determine how to replace the switch.
Aug 18, 2007 | Hoover S3639 WindTunnel Bagged Canister...
Vacuums Logo
338 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
