Question about Toshiba Satellite A100-S8111TD Notebook
Toshiba A200 - 1YO running Vista - bluetooth does not function?
  • 56 Answers
Goto control panal you will see bluetooth setting you can change the setting from there
Posted on Nov 19, 2009
I have a toshiba satellite L655-171 system unit and i can't find the bluetooth.Is it possible not to have this kind of setting?
Hi darknuage...
You do not have bluetooth on this Toshiba Satellite L655-171 according to the spec sheet I found at this website...
But you can buy a bluetooth dongle and have bluetooth on this computer.
Please take time to rate me
http://laptops-specs.blogspot.com/2010/06/toshiba-satellite-l655-s5071.html
Bluetooth Dongle
http://www.dealextreme.com/p/super-mini-bluetooth-2-0-adapter-dongle-vista-compatible-11866
Aug 12, 2011 | Toshiba Satellite L655-S5101 Laptop
Bluetooth Activation Toshiba satellite pro L300
Method 1 :  FN+F8 function should enabled the BT and should stay in this position. Then the BT could be always on.
Method 2 : Start menu -- Run -- Type " fsquirt.exe " without quote. it will automatically find the drivers and activate your bluetooth only if you have the Bluetooth driver installed.
Jan 04, 2010 | Toshiba Satellite Pro L300 Notebook
How do I enable bluetooth connection on my machine
I have the same machine, and was also looking for a bluetooth device and found that there is not one. I assume that you are running windows vista and have been confused, as I was, by the generic bluetooth driver. This is a standard driver with vista, in case you plug in a bluetooth dongle. I, personally got fed up with vista and installed xp home and found a much more usable system and much more free HDD space.
Jun 13, 2009 | Toshiba Satellite A215-S5837 Notebook
Toshiba A200 Bluetooth XP problem (originally Windows Vista)
Make sure that you installed both the driver and a bluetooth manager software like : Bluesoleil (http://www.bluesoleil.com/) or Widcomm. Windows Vista has an In-Built manager while Vista doesn't have so you have to manually install one. If you dont know how to contact me at any time.
Jan 02, 2009 | Toshiba Satellite A100-S8111TD Notebook
About my vista home basic
Check in the device manager to know whether the drivers are installed.
The issue would be bcause of the drivers.You can install the drivers using the drivers cd which you shold be having.
You can also use this
Start / Programmes / Camera Assistant. No idea who the software publishers are.
Whether or not this software is running, You can start the webcam using the [Alt] - [F7].
Bluetooth :
Try to enable it using key combination FN+F8.
You can download the bluetooth software from here :
http://aps.toshiba-tro.de/bluetooth/
Good Luck.
Live, Love, Laugh.
May 07, 2008 | Microsoft Windows Vista Ultimate Edition
Just purchased the kinsington bluetooth micro adapter. Vista loads the Toshiba Bluetooth stack software, but will not recognize the adapter (dongle) when I insert it. I have tried other usb ports and...
It is possible that the adaptor is not compatible with your version of windows vista, despite what the system requirements for the device say.
Below is a link where you can download the latest driver for your bluetooth adaptor. Support XP sp1, sp2, and vista. Try this driver
http://update.broadcom.com/downloads/btwinitialupdate.exe.
Apr 19, 2008 | Computers & Internet
SCMS-T blocks Bluetooth pairing with headset
I would like to add that to get to the registry editor you will need to type regedit in the run menu.
Once there follow the instructional map above ie. before each \ there is a folder, keep opening the folders until you come to the ] when you are in that folder follow instructions below. (Remember the two folders your are adding to are the EZC and AV)
Next from the top Edit menu select New DWORD Value. Rename it what is written between the " "
ie. ShowAvContentProtectionMenu
Then left click and Modify and enter the numbers after the =dword: in the value data
ie. 00000001
click OK.
And repeat the process for the second instructional map.
It worked for me without a hitch, I hope you have the same success.
Apr 12, 2008 | Computers & Internet
Toshiba Satellite A100-S8111TD Notebook Logo
95 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
