Question about Cameras
How to use focus features - Cameras
  • 3,741 Answers
Knowing what options are available and how to focus is crucial when taking a photograph. Every time you take a photograph you will want to make sure your subject is focused. Use this article to help you with focusing.
1) Refer to these terms for understanding:
Shutter Lag: delay between pressing the shutter and the time the shot was taken.
2) Always check how the subject relates to the background when taking a picture. Otherwise you can end up with funny pictures such as trees in the background making antlers on a person. Some may attribute shutter lag to them not allowing the camera to focus beforehand. If you are too impatient to focus or are need to take pictures in an instant, try pre-focusing or panning.
3) Learn the different ways you can focus:
Autofocus – . However, autofocus can have trouble focusing on off centered subjects, where there is little contrast, poorly lit subjects, bright focus areas, focus areas with near and far objects in them, and fast moving subjects. If you cannot focus (blinks or flashes to let you know), use focus lock. Fixed focus – On cheap cameras and one time use cameras. Focus you cannot change.
Manual focus – You can focus by turning a ring on lens or using buttons and settings on point and shoot cameras. This is difficult to use for fast moving subjects.
Automatic Tracking – keeps moving subject in focus as long as you hold down the shutter half way.
Pre-focusing: Useful when a moving subject is following a predictable path. Use by switching to manual focus mode and focusing ahead of time on the spot that your subject will pass. Hit the shutter button before your subject hits the focal point. This should get you the picture, but you might need to practice. Consider using fast shutter speeds and continuous shooting options like burst mode when using pre-focus.
4) Try using different focus features:
Focus Zones: Are rectangles or brackets that you can move or select. Indicates where you camera is focusing.
Focus Lock: Used to change the plane of focus. Use by pressing the shutter halfway to lock the focus and then move the camera to the area you desire and take the picture. This usually locks exposure as well but some cameras have AE Lock which allows you to separate exposure and focus settings. Focus lock is helpful when you do not have facial recognition on your camera in order to prevent focusing on some background object. It is also helpful when you want to have your subject off center.
Focus assist: assisting light that makes it easier to focus in dim lighting. It illuminates the scene but only work at short range.
This will help. Thanks please keep updated.please do rate the solution positively .thank you for using fixya.
Posted on Nov 19, 2009
How to adjust the focus of Olympus lenses?The E-30 has a Focus Adjust feature but how do you determine if a lens back or front focuses? Then how do you properly use the Focus adjust feature?
Kept searching online and found this site :http://www.olympus.co.jp/en/support/imsg/digicamera/qa/products/e30/di102468e.cfm .
Sorry, I won't have to pay for your site but thanks anyway. The Internet; it's a wonderful thing!
conleyr
Jan 17, 2010 | Olympus Cameras
Sony kp 57hw40 Convergence Problem The screen looks distorted, Letters or words on the screen are bowed.(I can see double but the screen is stationary all the color, hue, sharpness, brightness, exc. can be...
If after the Flash Focus™ feature has been performed, the colors on the FLASH FOCUS screen do no line up (converge), press the FLASH FOCUS button on the television to begin the cycle again. If the colors on the FLASH FOCUS screen continues to appear misaligned, service will be required .
NOTE: It is recommended to perform the Flash Focus™ feature about thirty minutes after the television has been turned on and keep the room as dark as possible.
Sep 22, 2009 | Sony KP-57HW40 57" Rear Projection...
Akai PT4298HD projection tv
convergence must be adj then saved then magic focus
if cannot be adj chips need to be replaced.
Sep 21, 2008 | Akai PT4298HD Rear Projection Television
More info for poor focus problem
I don't know about any misaligned focus feature on the D80. Have you checked to see what focusing mode you are using, ie. single auto focus, closest subject, or wide area focus. Closest subject can really throw off your focus. I would switch to single auto focus mode. Another reason for poor focus would be dust on the auto focus sensor which is located under the mirror box.
Check on the focus mode, if it's not a mechanical problem, I'd be willing to bet that's what it is.
Jul 22, 2008 | Nikon D80 Body Only Digital Camera
Nikon D70 SLR Auto Focus
problem in lens censer replace it
May 14, 2008 | Nikon D70s Digital Camera
Focus on a particular subject
Try the FOCUS LOCK feature. This feature allows you to focus on a subject roughly the same distance away from you, then re-compose your picture without losing that focus. Open the lens barrier fully. Look through the viewfinder at the AF Target Mark (the 4 lines in the center of the viewfinder). Position the AF Target Mark on a subject roughly the same distance away from you. Press the shutter button halfway until the green lamp lights. While keeping the shutter button pressed halfway, re-compose your picture, then press the shutter fully.
Sep 01, 2005 | Olympus Stylus Verve / ?-mini Digital...
Sep 01, 2005 | Olympus ? Stylus 500 Digital Camera
Cannot focus on a particular subject
If the camera is having a difficult time auto-focusing, you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance from you and then move the camera back to the intended subject and take the picture without losing focus. First, turn the camera on and locate the Autofocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away as the subject the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While holding the shutter button halfway down, aim the camera at the original subject and press the shutter button all the way down.
Sep 01, 2005 | Olympus D-630 Zoom Digital Camera
Try the FOCUS LOCK feature. This feature allows you to focus on a subject roughly the same distance away from you, then re-compose your picture without losing that focus. Open the lens barrier fully. Look through the viewfinder at the AF Target Mark (the 4 lines in the center of the viewfinder). Position the AF Target Mark on a subject roughly the same distance away from you. Press the shutter button halfway until the green lamplights. While keeping the shutter button pressed halfway, re-compose your picture, then press the shutter fully.
Sep 01, 2005 | Olympus D-575 Zoom Digital Camera
Focus
If the camera is having a difficult time auto-focusing you can try the FOCUS LOCK feature. This feature allows you to focus on another subject roughly the same distance from you and then move the camera back to the intended subject and take the picture without losing focus. First, turn the camera on and locate the Autofocus Target Mark in the center of the LCD. The AF Target Mark resembles an open and close bracket [ ]. Position this AF Target Mark on a subject roughly the same distance away as the subject the camera is having trouble focusing on. Press the shutter button halfway enabling the lens to focus. While holding the shutter button halfway down, aim the camera at the original subject and press the shutter button all the way down.
Aug 31, 2005 | Olympus Camedia D-435 Digital Camera
Cameras Logo
49 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
