Question about Minolta Maxxum 400si 35mm SLR Camera
Can't fully see thru the lens
When I look thru the lens it is shaded, can't see clearly thru it. it is like the shutter didn't reopen entirely. the last picture I took, it is like it stayed shut. also, my external flash works and the camera works but not together. when I use it, I can't even try to focus the camera.
  • 685 Answers
Look in the back where the film goes in. Are all the shutter blades flat and in place, or are they wrinkled or is one or two blades bent or out of place preventing the shutter from functioning fully? Put the camera in M focus and M exposure at about 15th, Fire the camera several times. If the shutter looks and works ok then take the lens off and look at the mirror. Fire the camera a few times. Doe the mirror go all the way up to the top and come back down, all the way? If so then the shutter would appear to work fine and the lens may e the problem. If the shutter or mirror box do not work correctly they will have to be repaired by a qualified technician.
Posted on Apr 10, 2010
The top half of my pictures with a flash are shaded.
Not seeing the pictures I have to guess. If the shade you mention is not like a straight line, but more rounded, try making the picture without the lens hood. Or use a external flash, when you use another than the standard lens. I don't think you can take a picture in manual, with a shutter speed above 1/250 second, because in such case the top or bottom part could become shaded then, but then the shade is in a straight line from left to right.
Dec 26, 2013 | Nikon D3100 Digital Camera
Shutters on the lens won't fully open
Stuck automatic lens covers are fairly. But usually it's very easy to fix, without even opening the camera. See this link for troubleshooting steps for this problem.
Dec 14, 2012 | Kodak EasyShare C633 Digital Camera
Every time i take a picture with my nikon d-40 the pictures are blurry. the camera is on auto focus but i can't seem to get the picture to come out clear. any suggestions?
Is your shutter speed fast enough? If not, you'll need a faster shutter speed or a tripod.
Are you using the proper focus sensor? Is the entire image blurry or just portions of it?
What happens if you focus manually? If it comes out sharp, then there's a problem either with the lens or the autofocus system on the camera. Have you tried it with a different lens?
Is the AF switch on the lens set to A?
Jun 04, 2009 | Nikon D40 Digital Camera with G-II 18-55mm...
LENS IS JAMMED ON MY Canon A510 PowerShot
pls see these links they will help u
http://camerarepair.blogspot.com/2007/11/repair-of-stuck-lens-covers.html
http://www.flickr.com/groups/a510/discuss/72157594369867126/
pls rate me well !
May 10, 2009 | Tokina 3652T for Canon Power-shot A510,...
PICTURE IS COMING IN PURPLE SHADE
CCD has gone bad , it is the sign of CCD failure first pics gets purple shades and overexposed white seems like pink purple and then all off dont spend time and money in diagnosing th fault i am 100 % sure abt it, i dont think it is worth to get it replaced u can get a new one around the cost replacement , fuji and nikon are good in results
i know i havent fixed ur problem but no body can in this situtation
pls rate me genrously bcoz i helped u in diagnosing ur problem without wasting time
Mar 06, 2009 | Kodak Easyshare C813 Digital Camera
Shutter stays closed on bronica 645 etr medium format
Have the electronic shutter checked by a repair shop. Sounds like your Seiko electronic shutter has died or there's a short somewhere between shutter and lens. Hope this helps.
Fotobean
Jan 15, 2009 | Bronica ETR-Si Medium Format Camera
Mamiya RZ 67 lens is stuck on body
This is likely because the shutter has not been cocked all the way. Return the lens to the fully locked position and advance the film with the lever all the way down to reset the shutter. If it still doesn't work, move the lever to M for multiple exposure, make sure the back is aligned and trip the shutter release. Then fully **** the shutter again by pressing the advance lever down fully and again until it is reset. Then try to remove the lens again.
Dec 15, 2008 | Mamiya RZ67 ProII Medium Format Camera
Lens cover only opens half-way
If the lens barrel isn't fully extending on power up, that will prevent the lens cover shutters from springing open. There is a stationary prong that pushes the cover closed when the barrel is retracted.
Does the camera work otherwise? Take pictures thru the half open lens?
Jun 15, 2008 | Panasonic Lumix DMC-LZ7 Digital Camera
K100D Problem
Remove lens, locate silver vertical pin inside of mounting ring on left side as you are looking at camera. Lightly slide black plastic piece which is on the vertical pin downward; if it will go downward remount lens and try camera. If plastic piece will not go down, lightly slide it up and then down and now remount lens and try camera. My guess is that either that component is sometimes stuck or that it may have become mispositioned while removing and replacing a lens.
Nov 11, 2007 | Pentax K100D Digital Camera
Shutter will not fully open or close
It sounds like the shutter mechanism is dirty, or you have a bad spring. Try taking it to a camera shop and have them clean it. It is not very expensive, and well worth it if it fixes the problem. Best regards, nightdiver Let me know if it solves the problem.
May 25, 2006 | Konica Minolta DiMAGE F100 Digital Camera
Minolta Maxxum 400si 35mm SLR Camera Logo
69 people viewed this question
Top Minolta Photography Experts
Greg Cann
Greg Cann
TC CAMERA REPAIR.Com...
Are you a Minolta Photography Expert? Answer questions, earn points and help others
