87 Other Users Have The Same Problem - Continued
Comment by Guest, posted on Jan 06, 2009
yo dude I know where you are coming from!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Comment by Guest, posted on Dec 13, 2008
when i turn on my psp the screen stays black even though the greenlight is on
Comment by sunakochan, posted on Nov 27, 2008
i can't pit games on my memory stick..
my system setting says "system software version 4.01"..
i suppose it must have "M33" after it..
what should i do?
what will i do with my psp?
its system software version is 4.01..
how will i enable m33?
Comment by purna_lang, posted on Nov 21, 2008
i tried to start up my psp with a pandora battery and a magic memory stick. but a black screen comes on while the green light of power is still on
Comment by Guest, posted on Oct 29, 2008
Yeah when I try to charge my psp it charges for like 30sec then the light goes green and it wont change. WHAT DO I DO?????
Comment by Guest, posted on Oct 26, 2008
my psp green light will turn on for 30 seconds but my sound also doesnot work.my screen is black all the time ever since i cleaned my screen with soap and water.i thought it would be sronger than a dab of water and soap.
Comment by yuanali, posted on Oct 19, 2008
when i turn on my psp it has a blackscreen and stays open and doesnt turn off when i push the power. only way is to take the battery out.
Comment by CheeseTom, posted on Oct 19, 2008
The screen on my psp stays black when i try to turn it on but the green power light is still on then turns off after about 20 seconds or so!!! How san i fix this???
Comment by Guest, posted on Oct 11, 2008
my psp dont turn on i try and trybut dont do anythig:(
Comment by nazgaul, posted on Sep 12, 2008
after installed pimp my psp software on my psp , i cant see anything except date , time and battery status on the main menu. if someone know how to fix it , plz help me out.
Comment by Guest, posted on Sep 12, 2008
after install pimp my psp software on my psp , i cant see anything except date , time and battery status on the main menu .. how can i fix that problem ? if someone know , plz help me out ...
Comment by sly-mstreet, posted on Sep 06, 2008
the green light comes on for a couple seconds then shuts off, i took out the umd & the memory stick, tried powering up with the charger, pulled the power button for at least 7 seconds to see if it'll power up again but to no avail, the screen's still black & it was working fine awhile ago, is it "bricked"??
Comment by namaskah, posted on Sep 04, 2008
My PSP bricked after "key" changing. I do the software - key cleaner
Now, my PSP can't boot. nothing in screen, black always. but the power green light able to on.
Is there any solution? Fix by own (DIY)
Thank you.
Email address:
namaskah@yahoo.com.sg
Comment by jpppppg, posted on Aug 30, 2008
my psp wont turn on but when i turn on the power the green lighit shows for 5 sec seconds then turns off. but when turns on in 5 min. it freezess then turns off
Comment by jeryon28144, posted on Aug 30, 2008
well my PSP will not turn on the green light cuts on but the psp wont turn on
Comment by Guest, posted on Aug 29, 2008
My psp only works sometimes. It turns and the light goes green, then most of the time it shuts off and sometimes it runs normally. W
hat is the problem?
Comment by Guest, posted on Aug 27, 2008
psp wont come off menu screen
Comment by Guest, posted on Aug 22, 2008
my psp is the same but i haven't played it in a couple of months and i'm going on holiday so i tried to put it on but it wont the screen stays black i can charge it and wen i press the power button the green light appears for 30 seconds but the screen still stay blank
Comment by Guest, posted on Aug 20, 2008
my psp turns off in the middle of play
Comment by cepbill, posted on Aug 20, 2008
Green light comes on for about 30 seconds and goes off. Tried a Pandora battery with no luck.
Comment by yasmine08, posted on Aug 16, 2008
well my mom bought a psp at a pawn shop! we charged it and we tryed to cut it on! we pushed the power button and the green light came on but the screen is blank!!!! i need help!!!!!!!!!!!!!
Comment by kianmin, posted on Aug 16, 2008
i put themes in my psp n den i delete all my files at recovery menu.......den my psp restarted but it is not on.......pls help me pls
Comment by Guest, posted on Aug 12, 2008
i took out my baterry while upgrading on my psp and when i charge it the charge light comes on and then turns off and i turn on my psp and the screen is all black and the green light comes on and off how do i fix it
Comment by Guest, posted on Aug 10, 2008
my brother turned the psp off while loading in the screen stays black and the light stay on for like 30 seconds
my screen is blank and the sound works
my psps screen won't come on. I turn it on and the green light comes on and the sound works but the screen stays black.
Comment by hott_mia, posted on Aug 09, 2008
this game is about 6months old and when u turn it on the green light comes on then in about 10secs the light comes off but the game doesn't come on at all.
Comment by rachelx95, posted on Aug 09, 2008
My brothers got the old PSP when it first came out. They havent used them forr like four years.I charged it completely but when i turn on the power, the green button comes on stays on for 30 seconds and turns off and the screen stays black. What do i do?
Comment by collinstower, posted on Aug 03, 2008
well i got my
psp from my
cuz and he turned it off when it was loading and every since then it wont turn on i can charge it and push the power bottom on and the green light will come on for like 30 second then turn off. The
screen stays black like it is when it is cut off. what do i need to do to fix it...
Comment by Guest, posted on Aug 03, 2008
well i got my psp from my cuz
light will come on for like 30 second then turn off. The screen stays black like it is when it is cut off. what do i need to do to fix it...
same darn promblem ugh !!!!!!!!!!
Comment by Guest, posted on Aug 01, 2008
get a new one
Comment by sora633, posted on Jul 30, 2008
my older sister drop our psp she says, "i was walking in the kithchen to help mom then i droped it and the batery,the umd disc,and the cover to the batery". so she put it back together and kept it off the rest of the night.the next day she turned it on and the signal for the psp was dead.all it did was turn on and none of the symbols appeared from it,the backgrowend was there only.plus i want to beat my game iv been dying to know what happens next i dont want to see it on the computer i want to beat it myself ! PLEASE HELP ME WITH MY PROBLEM!!!!!!PLEASE!!!!!!!!!!!!!:(
Comment by Guest, posted on Jul 29, 2008
my psp screen is not working and the screen is black every time i turn it on but all that comes on is the green light not the screen how do i fix my psp problem and do i have to bye a new one cause my mom says if i brake it i won't get an new one so how do i fix my psp problem without paying
Comment by Guest, posted on Jul 28, 2008
I just bought a new game for my psp but when i put the game in it had me load a few things before i played the game. Then it told me that it will be shutting down my psp then my psp shut down.after that i charged it over night and the next day the green light will turn on for 30 secs but the screen will not show anything and it wont make any sound.And i only had it for a week before all this happened.
Comment by Guest, posted on Jul 26, 2008
i dont know how to fix it and i aint gonna waste money on new psp unless nesicary
Comment by Guest, posted on Jul 25, 2008
it turn on and the blue background show for like 30second and it cuts off
Comment by zippo13, posted on Jul 25, 2008
Comment by taeao_mamea, posted on Jul 25, 2008
I have the same exact problem
Comment by babidaniels, posted on Jul 24, 2008
well when i was trying to upgrade it, the upgrade failed then my psp turned off. i tried to turn it on and the light will come on for a little while the screen would stay black and then the light would go bak off. what happened to it??????
Comment by carlos9, posted on Jul 22, 2008
i dropped my psp when is was loading and now the screen is black can it be fixed .
Comment by Guest, posted on Jul 22, 2008
psp screen does not come on sometimes
Comment by katiepedrosa, posted on Jul 22, 2008
My psp wont turn on .then when I put it on to charge it does want to turn on but then when its fully charged and I take the charger of and when I turn it on it does not want to turn on !
Comment by Guest, posted on Jul 21, 2008
i turn my game on after exchanging game with a friend it said need upgrading so i turn it off i guess to soon . now it wont come on. so someone told me it was bricked or froze up . and i need to get a duo memory stick so i did i put it in but it still didnt work what can i do now.
Comment by akb3l4l, posted on Jul 20, 2008
my psps screen stays off when i switch it on the green power light comes on for 3o secons then turns off
Comment by stuartharte, posted on Jul 20, 2008
when i turn my psp on the green power light comes on but the screen stays black and after around 10 seconds the power light goes off .i have heard tghe term brick to describe this problem and have seen lots of people on various forums have thge same problem how do i solve
Comment by Guest, posted on Jul 20, 2008
same problem
Comment by cesarsoto, posted on Jul 19, 2008
my psp got busted after i played my freinds game wwe 2008 i put it to charge after that then it never turned on. i tried a new battery but it still didnt work
Comment by luck13ms, posted on Jul 18, 2008
my psp wont let me type when im on the internet
Comment by jeromethebus, posted on Jul 17, 2008
my psp works but the screen wont show anything
Comment by Guest, posted on Jul 17, 2008
the green light stays on but the screen stays black what should i do
Comment by Guest, posted on Jul 06, 2008
yes
Comment by x_xundee, posted on Jul 06, 2008
everytime I hit the on button of my psp the screen wont appear?
what can I do
Comment by Guest, posted on Jun 25, 2008
i bought a game for my psp it started up but when it unloaded it turned black now ever since the screen wont turn on i tried putting it in the freezer for 10 min.
Comment by dfrazier620, posted on Jun 24, 2008
i carge it and push the power bottom on and the green light will come on for like 30 second then turn off the screenstays black like it is when it is cut off
Comment by Guest, posted on Jun 23, 2008
psp stays blank but green light comes on
Comment by SourPatch, posted on Jun 20, 2008
my mom gave me a psp that she found my aunt had knock it out my hand and it hit the floor hard ever since then when i go on the internet it wont let me type and if i click home it goes black and when i try to do anything else it goes black right now it wont do nothing at all. i try takeing out the battry and the memory card but it still dont work i even try leaving off for a couple of days it still dont work i even try recharging it but it still dont workk i dont know what to do please help me i cant live with out my psp
Comment by SEAWEE207, posted on Jun 19, 2008
I Bought a psp off the street FOR MY BROTHER ,and i didn;t know it had any problems .it looks very new .When i turn it on it stays in a black screen like if it was turned off. It also takes a few seconds for my psp to turn off.And i bought a red battery that looks the same as a regular battery ( says TOOL and it' s RED) MY friends say that its bricked what is that.And they say that the red tool battery will help to un-brick it.PLEASE SOME ONE HELP ME (IF YOU HAVE ANY VOLUBLE INFO OR SOFTWARE THAT WILL HELP e-MAIL ME AT ) SEAWEE207@GMAIL.COM THANKS
Comment by autobotman, posted on Jun 17, 2008
My sisters knocked down my psp. ever since then the screen won't turn on and it won't turn off unless you take the battery out. evrything else is working fine.
Comment by Guest, posted on Jun 10, 2008
when i turn my psp on it stays for a while then just shuts off
Comment by Guest, posted on Jun 09, 2008
Have no data and no internet on my PSP. I have tried blowing the memorystick and wiping with a cloth. Will you help me.
About a year ago my data was in my PSP and a day later my data was gone. I took my memorystick out and blew it off and wiped it with my shirt. My internet wont work it is gone or something. Please help me fix my PSP.
About half a year ago my data was in my PSP a day later all my data was gone. What can I do.I've tried taking the memorystick out and blowing it and wipeing it with my shirt. On my PSP the internet went out and i dont know how to get to work. Please help me get my PSP to work again.
Comment by isidroruiz, posted on Jun 08, 2008
my screen its on but it is hard to see the light isnt on
Comment by kanino, posted on Jun 01, 2008
i go to turn my PSP on and the power light turns green but the screen stays black. what do i do?
Comment by THESURGE32, posted on Jun 01, 2008
PLEASE HELP.....MY PSP WILL NOT CHARGE.IF I TRY TO CHARGE IT...THE ORANGE LIGHT WILL NOT SHOW UP......MY BATTERY IS DEAD AND IT WONT CHARGE.......WHAT SHOULD I DO????
Comment by Guest, posted on May 31, 2008
My Psp Shut off when i was doing an upgrade and when i try to turn it n the screen stay blank but the green light comes on for about 30 s
Comment by blackbandana, posted on May 25, 2008
ok i dropped my psp on the bathroom floor it was kinda of wet and the battery had already died so i tried chargin it but it didn't work so now the green power light turns on put the screen doesn't appear what should i do?
Comment by Guest, posted on May 24, 2008
Hi there , I have the same problem. I turned of my psp when it was loading a video game, now the screen is just black what can I do. thanks. TIGU.
Comment by Guest, posted on May 19, 2008
well when i put the umd on the psp it takes to long to load and the umd never comes on so i cant play the game
Comment by ufalufa, posted on May 19, 2008
I turn on my psp and the grenn light comes on for about 30sec along with the backlight but then it goes off and it shuts down. that is all i does. i was playing it earlier then this. do you think when i was putting on some themes it had something to do with it? Please Help
Comment by j-dogg160, posted on May 13, 2008
i turn my psp on and the green light is on, but the screen is black
Comment by dene0, posted on May 09, 2008
psp green light comes on screen stays black then psp power light goes of
Comment by Guest, posted on May 07, 2008
from my cuz and he turned it off when it was loading and every since then it wont turn on i can charge it and push the power bottom on and the green light will come on for like 30 second then turn off. The screen stays black like it is when it is cut off. what do i need to do to fix it...
Comment by bigchuck, posted on Apr 17, 2008
i have the same problem how can it be fixed
Comment by storm231, posted on Apr 16, 2008
i got my psp from my friend and now every 15 seconds it turns off i push it down and then it works if i let it go the psp frezzes and then it just turns off altogether helpppp
Comment by robin76, posted on Mar 08, 2008
i took the baterries out and then when i put it back in my psp and it was not turning on what do i do
Comment by TIGU, posted on Feb 17, 2008
well i got my
psp
from my
Comment by Guest, posted on Jan 12, 2008
klj,
I have the same problem as Nettyb33. I can turn on my psp, the it will flash for about 30 seconds and turn off. I read the solution what is a P.U.M and where can you purchase one?
Comment by nettyb33, posted on Jan 11, 2008
My psp wont turn on, i can charge it and push the power bottom on and the green light will come on for like 30 second then turn off. The screen stays black like it is when it is cut off. what do i need to do to fix it...
