Question about Poulan Pro Chain Saw 46cc 20"
Need to replace drive sprocket on Poulan 2150 chainsaw. Do I need a special tool to remove?
  • 486 Answers
Outboard drums (drums on the outside of the clutch) are held on by a nut or e-clip.
Inboard drums are held on by the clutch which is threaded onto the crankshaft. And there is the challange.
***NOTE all chain saw clutches have LEFT hand threads, so, rightey loosey, lefty tightey. (just backwards from everything else)
*** NOTE #2: DO NOT USE AN IMPACT GUN
this will most certainly shear the flywheel key or damage the flywheel !!!!! (after 35 years, you can ask me how I know that, LOL)
1) Use a piston stop to hold piston from moving: THIS IS A MUST !!!
Ok, so you do not have one, let's make one.
a) remove the spark plug
b) insert a piece of recoil rope into the cylinder hole, leaving a tail to remove it by. (rope, large shoe string, anything that is soft, that is aprox 1/4 to 5/16 in diameter to place into the spark plug hole to help the piston to stop it's travel by filling up the empty space. Just make sure you can remove it later)
c) secure the saw (extra set of hands may be needed) and with a suitable wrench on the clutch center, rotate the clutch to the right until piston comes to a stop. With a hammer, tap the wrench to aid in rotation. This can be very difficult, and may take several taps.
d) after removed, inspect and grease the drum bearing before re-assemlby.
e) upon re-assembly of clutch, tighten by hand only, NO hammer required. The force of the chain will tighten the clutch.
f) remove the rope, and re-install the spark plug.
Posted on Nov 19, 2009
    President:
  • 2,220 Answers
Rwvanlue:
Your description of inboard and outboard clutches is reversed; please correct it.
Outboard clutch
http://www.youtube.com/watch?v=cdqkIuVNUQc
Inboard clutch
http://www.youtube.com/watch?v=YUbSIHMSSP8
Which one uses c-clip?
  • 169 Answers
YES THE TOOL PART NUMBER IS 530031112 THEY ARE ABOUT 7 OR 8 DOLLARS FROM YOUR POULAN DEALER. I DONT HAVE ONE IN STOCK BUT WOULD BE GLAD TO ORDER IT FOR YOU. COME SEE ME AT LAKEVIEWPOWER.COM
  • jeremy fountain
    jeremy fountain Nov 25, 2009
    his description of inboard outboard clutches is correct no edit needed
How do you remove a clutch drum on Poulan Pro PP4620AVHD chain saw
YouTube can be a great help with video's of 'how to' do things.
I have attached a video from 'donnyboy73.' I found his video's to be very informative and well put together. The video link is not of your exact saw but is a Poulan and I hope will be helpful to you.
HOW TO Remove Clutch & Sprocket on Poulan 2150 Chainsaw. The same procedure can be applied to many other chainsaws.
http://www.youtube.com/watch?v=zf28-ztoHfg
Oct 17, 2014 | Poulan Garden
How do i replace fuel filter on a 2150 poulan
Pull the full filter out using a wire or tool that has a hook on it. Replace and drop back in.
Aug 30, 2014 | Poulan Garden
How do i replaceclutch drive on a poulan chainsaw p4018wt
Attached is a video from YouTube Donyboy73. In it he removes a clutch and sprocket from a Poulan 2150. I know this is not your saw, but also know all 2 cycle chainsaws are very similar.
There are many helpful chainsaw videos on YouTube. I hope this helps.
Aug 15, 2014 | Poulan Garden
Need to know what the compression should be for a 2150 poulan chainsaw
the compression on a chainsaw can be checked by simply holding the crank rope by itself, it should chug down the rope very slowly.
Apr 03, 2013 | Poulan Oregon Chainsaw Chain For Chainsaw...
How to fix the throttle trigger lock on my poulan 2150
You will need to replace the trigger and throttle lock lever, they come as a pair part no. 530071305, to replace them you will need to drive out the two pins securing them in the back handle, you will also need to remove the throttle rod from the trigger.
Feb 24, 2012 | Poulan Garden
Need to replace clutch & drive sprocket
The threads are left-handed. Remove the spark plug and with the piston high enough to prevent entry into the exhaust/transfer ports, stuff some pull rope into the cylinder head and upper cylinder to block the piston from rising much further. You may need to get a special tool to remove the clutch core assembly--don't use an impact wrench as it will shear the flywheel key. If the clutch won't drive the chain and is full of oil, try washing the clutch drum out with spray carburetor cleaner and let dry. This might save the expense and trouble of replacing it. Hope this helps!
May 25, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
I have a Poulan 2150 chain saw which needs a new chain oil pump. What is the cost to replace it. Should I just buy a new saw.
If you perform the labor repair likely <$20 (<$9 for pump, <$1 worm gear). Compare replacement cost to 34cc± replacement, your call.
A link to a Poulan 2150 Gas Saw Type 7 follows (may not be your saw):
http://www.ordertree.com/modelinfo/PWE/2150-Gas-Saw-Type-7/75.2150-Gas-Saw-Type-7.1.59.1.html
If the link is not your saw it can be found here.
The IPL (exploded parts list) for your saw is the only detail for the oil system and it is sketchy at best. Oil components and part numbers are listed but may be on different illustrations. They are also beneficial with disassembly/reassembly:
Poulan.com
http://www.ordertree.com/modelinfo/POULAN-WEED-EATER/75.59.html
The dash number of your serial number is the type.
The oil pump is under the outboard clutch, this is helpful with removal.
R² Drive Link Outboard Clutch by Drivelink.blogspot.com
  1. Check the IPL for your saw to see if any special tools are needed. Poulan (Craftsman, Jonsered, Husky) clutch removal tool part number 530031112 if needed, is under $5 from many sources (look at the visible area between the weights if 2 small round sockets are visible you need the tool).
  2. There are metal piston stops available, when square (almost never) with the piston top these work well, if not square they have been known to punch through the piston. I suggest a length of nylon rope (nothing left behind) be used instead of the piston stop (retain 6" ± so you can remove it). Make sure the piston is near the top of the cylinder before feeding the cord or it can fall through the exhaust port and damage the piston as it rises.
  3. Everyone I have ever removed had a left handed thread (tighten it to loosen it).
If you have more questions or need additional help please reply below and I will get back to you. Thank you for using FixYa and Good Luck. HTH
Lou
Apr 03, 2010 | Poulan Pro Chain Saw 46cc 20"
I need to know how to replace the sprocket on poulan model 4620 chainsaw
It is a Poulan PP4620(dependent on clutch adjuster - AV, AVHD, AVL or AVX)
Poulan.com/CurrentModels (Check in Illustrated Parts List (IPL) box)
http://www.poulanpro.com/node4043.aspx
Type just the model numbers (choose the suffix after the list is provided).
All 4 of these display an outboard clutch, use this as a removal guide:
Lou
Mar 17, 2010 | Poulan Pro Chain Saw 46cc 20"
Want to change sprocket on poulan 4620 avx to 3/8, for ripping chain.
41569X is an Oregon 6 spur sprocket for a PP4620AV. It is not listed with the PP4620 or the PP4620AVX, I think it will work. Please verify this with Oregon here:
OregonChain Contact Us:
http://www.oregonchain.com/pro/service/contact_us.htm
I think this saw may be small for use with a mill but it is your decision.
I am reasonably this saw has an outboard clutch, this will help with replacement.
Good Luck. HTH
Lou
Feb 23, 2010 | Poulan Pro 42CC 2 Cycle Chainsaw, 18"
Poulan Pro Chain Saw 46cc 20" Logo
242 people viewed this question
Top Poulan Garden Experts
Roland W VanLue
Roland W VanLue
Phil Walker
Phil Walker
Are you a Poulan Garden Expert? Answer questions, earn points and help others
