Question about SMC Barricade 7004VWBR Wireless Router
Intermitent signal strength
I have an SMC Barricade 7004VWBR Wireless Router and am experiencing oscillating signal strength including dropping of the signal all together. This has worked fine for a long time and the problem has just begun. I have reinstalled the firmware (same version that I already had) to no affect. is there anything that I can be doing or is my router kaput now?
  • ebo2112 Jun 28, 2008
    Wow very similar problem here. I wondered in another post about power-supply issues, but only on the wireless side, now I see a solution below referencing the radio xmitters: Op-amps! (that's basically the power for the radio system and known to be finicky). And my router IS on a high shelf in a closed WORKSHOP of all things, in fact I just wiped a pile of sawdust off it earlier today! Yikes. Plus it is always on for the last three+ years.
    Guess I got my money worth since I paid $14 on a boxingday sale!
  • geep May 11, 2010
    My connection to my SMC has been working with my Acer portable for over a year but has stopped working properly recently (since I have installed a Wii at home actually but Nitendo techs told me that it's impossible that my problems can be related to that). My Acer wireless connection works at work and diffirent Hotspots. So there is definately something wrong with my SMC router but where to look?
    Here's what I have tried:
    • Disabled all security with broadcast of SSID (I don't like that but I tried)
    • changed channel from 6 to 1 to 11 to 9
    • tried with or without mac filtering
    • reset to factory default and retried the above
    Any idea beside buing a new router?
    Novelist:
  • 139 Answers
It is not unusual for the radio transmitters to fail in wireless routers after a year or two of use, especially if they're used in a location with poor ventilation or dust buildup. "Kaput" is probably a good term for it, but it would be worth finding someone with another laptop to try connecting through your router...just to verify that it's really a problem in the router and not in the wireless adapter in your computer.
Posted on Jan 11, 2008
Router
There are a few things thatcan cause you to lose wireless connection with your wireless router.1. Weak signal strength,check the signal strength on your wireless card. If it is weak move thewireless router away from brick or concrete walls and if possible locatethe wireless router higher up.2. Have you secured yourwireless router from people near your from unauthorized access? i.e. change thedefault password, setup encryption use WPA2 or WPA, change the default SSID,and turn off SSID broadcast, and for added protection, enable MAC addressfiltering which allows only the MAC address/es of your wireless card/s toconnect to your wireless router.3. You could be gettinginterference from electrical sources such as air conditioners, arc welders,washing machines etc. If so, the power supply to the wireless routers andcomputers etc should be connected to a surge protection power board, betterstill connect your computer equipment to an UPS (Uninterrupted PowerSupply). 4. Check the channels ofthe wireless routers and access points in your area and change the broadcastchannel on your wireless router to an unused channel or one that is currentlyused but has the weakest signal strength. This will minimize interferencewith your wireless router from other wireless routers and accesspoints in your area.
Apr 16, 2012 | SMC Barricade g SMC2804WBRP-G Wireless...
I have forgotten my password on my smc 7004vwbr and need help to reset
I assume this is your wireless KEY
The user manual is here http://www.smc.com/index.cfm?event=downloads.doSearchCriteria&localeCode=EN_GBR&knowsPartNumber=false&productCategory=1&modelNumber=955&partNumber=3552&downloadType=8&os=0
you can choose the exact model from here http://www.smc.com/index.cfm?event=downloads.searchCriteria&localeCode=EN_GBR&knowsPartNumber=false&productCategory=1&downloadType=0&os=0
You should be able to see how to view or reset the wireless password.
Connect your PC to the Router with a LAN cable:- You will need to login to your router- you do this by typing a number into a web browser, Internet explorer, is best as some routers do not work with other browsers The way to log into the router is usually to use the IP address, thats a number which will be in the manual - Page 29 on the manual (33 on pdf screen) To access the Wireless Barricade’s management interface, enter the Wireless Barricade IP address in your Web browser http://192.168.2.1. Then click LOGIN. (By default, there is no password.) Goto the wireless section - secruity and you should be able to see the KEY - IF its all * - the you can type in a newone
I would also remove the wireless profile from your PC - to do this have a read of this link. Remove the wireless profiles from your PC http://mgmcc.forumotion.net/networking-tutorials-f17/removing-an-existing-wireless-profile-t109.htm
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Mar 25, 2010 | SMC Barricade 7004VWBR Wireless Router
SMC Barricade SMC7004VWBR not found by Wifi toys
good day,
hope this link below will solve your problem.
routers
Feb 12, 2010 | SMC Barricade 7004VWBR Wireless Router
Need password for log in to SMC Barricade 7004 VWBR Router
The username could be: admin
and the password could be: passoword
the password could be: admin
Jan 01, 2010 | SMC Barricade 7004VWBR Wireless Router
Linking my smc 7004 wireless router to ipod touch
I will advise you to configure the WEP encryption using your router before connecting using your IPOD.
Note: IPOD support WEP encryption. Check the network connection if the Internet is working properly.
Mar 26, 2009 | SMC Barricade 7004VWBR Wireless Router
Unable to get IP address on SMC2804WBRP-G
You need to setup security on the laptop/access point. Apparently it has been setup in the router.
Jan 25, 2009 | SMC Barricade g SMC2804WBRP-G Wireless...
Connections fails and I have to constantly reboot the router
We have satellite Internet. They say everything is OK, but every few days I have to unplug my modem from the satellite, reboot, and everything is OK again. So I put a timer on mine, and it reboots every morning about 3.
Dec 22, 2017 | SMC Barricade 7004VWBR Wireless Router
SMC 7004 VWBR router
enable wireless in router and connect threw xbox
Apr 08, 2008 | SMC Barricade 7004VWBR Wireless Router
Dropping internet connection
check if this problem is with both wired and wireless computers, if not with the wired..only wireless has problems, check if you have any other wireless device operating in the same frequency of the router..if s, turn off other devices and check b.cos that me interfere your w/ls connection, if wired is having the same problem, connect modem straight to the pc and observe the connection, so that you can isolate problem..
Nov 04, 2007 | SMC Barricade 7004 Router
SMC barricade g and timing out
just a few things that can be checked, firstly in the routers settings look at the transfer speed of the router(not the connection speed) and see if it's set at 108MBPS, if so your wireless network cards on your pc's may only be able to connect at a maximum speed of 54MBPS, unless you have the latest 108 or 125MBPS g type cards. Secondly you should be able to check the wireless signal strength by the icon in your task bar or software you use, as if you have thick walls or objects in the line of the signal from router to pc's, the strength drops and can read low and therefore cause you to lose internet connection entirely. You can also try changing the channel at which the router runs, normally this is channel 2, but trying channel 11, which is the farthest away from appliance interference may give you better results, but both router and network card channel numbers will have to be changed.
May 13, 2007 | SMC Barricade g SMCWBR14T-G Wireless...
SMC Barricade 7004VWBR Wireless Router Logo
207 people viewed this question
Top SMC Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
J John
Are you a SMC Computer and Internet Expert? Answer questions, earn points and help others
