Question about Hitachi 55FX48B 55" Rear Projection Television
MY HITACHI CUT OFF YESTERDAY BY ITSELF. THEIR ARE THREE INDICATOR LIGHTS ON THE RIGHT FRONT LOWER PART OF THE TV, AND THE TOP ONE IS STAYING ON. YOU PRESS THE POWER BUTTON AND IT TRIES TO COME ON, I GUESS IT DOES A SELF TEST AND THEN SHUTS OFF AGAIN.IT ALSO IS MAKING A HIGH PITCH INTERMEDIATE SOUND DURING THE INITIAL SELF TEST. THE TV IS A 55" HITACHI ULTRAVISION, ABOUT 4-5 YEARS OLD. ANY SUGGESTIONS? THANKS
  • Hitachi Master
  • 5,138 Answers
Shorted Hori ouput Transistor near FBT flyback Transfomer.Go towebsite online Encompass Parts Distr. they have listing for your Tv also have service manual,or Call 1-800-638-3328
Posted on Nov 19, 2009
My temp light keep blinking
When the temp light is blinking, that indicates that one (or more) of the cooling fan has stopped spinning. The TV will stay off to protect itself from overheating until the fan is replaced. There are two fans. One is available here: http://www.encompassparts.com/products/?GS01131 ; the other is http://www.partstore.com/Part/Hitachi+Ltd/Hitachi/GS00931/New.aspx .
Retrevo has the manual for the Hitachi 50V710 here: http://www.retrevo.com/support/Hitachi-50V710-TVs-manual/id/372ag010/t/2/ . You will need to enter the code to access the file.
I hope this helps.
Sep 14, 2011 | Hitachi 50V710 50" Rear Projection...
I have a hitachi tv i need code
Hello
Three digit universal remote codes for hitachi are:-
001/ 004/ 009/ 013/ 059/ 061/ 079/ 088/ 091/ 137/ 139/ 140/ 141/ 142/ 143/ 144/ 145/ 146/ 179/ 210
Four digit universal remote code for Hitachi are:-
0088 0059 0142 0060 0072 0004 0009 0091 0001 0012 0061 0137 0139 0141 0179 0227
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
Code Search If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
Mar 24, 2011 | Televison & Video
Tv code of hitachi for universal remote
hello
Four Digit Universal Remote Code for Hitachi are:-
Three Digit universal remote code for Hitachi are:-
Direct Code Entry
Nov 27, 2010 | Hitachi Televison & Video
Blue light blinks three times
very common issue for these sets! p50h401 and p50s601 are almost the same.
for more info on this set please check out http://www.hometheatershack.com/forums/hitachi/38229-hitachi-p50h401-led-flashes-3-times.html
if will tell you how to trouble shoot this tv. these tv's are known for two caps in the power supply to go bad and they need replaced then you have to test the sdr buffer boards if they are bad you need replacement boards or you can send them off to be repaired.( Repairing the buffer boards is a lot less then replacing them ) the link for the repair guy is on the page. this guy also sells the repair on ebay but if you contact him directly i beleave the price is lower. just tell him you were send over by home theater shack.
Sep 19, 2010 | Hitachi Ultravision P50S601 50 in. Plasma...
Mitsubishi projection TV model VS-5047 won't turn on
No. It is shutting itself off after it finds something is not right in circuitry.
Apr 14, 2010 | Televison & Video
Hitachi 51UWX20B no sound, no picture, blinking green LED
The 392-150 is a higher current device then the 110---you can use either--this is normal in the hitachi sets---I usually replace both with 150's---check the led that does not light---should indicate which voltage source is bad---if it is one of the 2 voltages for the convergence ic's(one is a positive and the other a negative voltage) then the convergence Ic's may be bad---look for any discolored resistors around the ic's---one way to tell if it is a convergence ic is to de-solder both ic's and see if the set turns on(the convergence will be out the window) but if it comes on change both and do the alignments with the Hitachi remote. By the way----the led should have a location number printed on the top of the circuit board.
Aug 07, 2009 | Hitachi 51SWX20B 51" Rear Projection...
Hitachi 43UWX10B
you need the front panel PC board . You can get one most likely at the following link, just leave them an email and indicate your model number and what youre needing they will respond quickly.
http://servicemanuals.vstore.ca/
Jun 18, 2008 | Hitachi 43UWX10B 43" Rear Projection...
Hitachi Ultravision Digital 55" hdtv
Good Day;
Try this:
Symptom: All Front LED indicators are flashing in sequence: Power-->Temp-->Lamp-->Power......continuously
Cause: Replace Lamp . This symptom may happen all the time or it may be intermittent. It is normal if it occurrs from time to time, See OG under TV Front Indicators explanation notes.
Good Luck, big IRISH.
Jun 13, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
TV won't stay turned on, no picture, started making high pitched noise
That high pitched noise you're hearing is the power supply telling you that it has too much of a load on it and lowered its operating frequency which in effect cuts its output way down! Normally you don't hear any thing since the power supply operates at a frequency that's beyond human hearing. In an RCA this indicates more than likely that your horizontal output transistor is shorted and this short was caused by the flyback transformer shorting. This is a common happening with RCA's You'd need to take to a tv shop and have it checked out. Stargazer
Jan 28, 2007 | RCA F27650 27" TV
Televison & Video Logo
132 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
