Question about Dell Inspiron 1525 Laptop
Keyboard & touchpad not working - Dell Inspiron 1525 Laptop
Power capacitor damage
Posted on Nov 19, 2009
Touchpad stopped working when a friend openned the laptop to fix the DC power pin. reinstalled driver, power cycled, disabled and enabled touchpad, still only works with mouse. keyboard works fine
Most probably, your friend disconnected the cable connecting the touchpad to the motherboard while disassembling the laptop to fix the DC power pin, & forgot to reconnect it back.
You will need to partially disassemble the laptop again & reconnect the touchpad to the motherboard.
Nov 13, 2010 | Toshiba Satellite A60 Notebook
PROBLEM WID THE KEYBOARD,TOUCHPAD IS NOT RESPONDING.THE ICONS DO NOT RESPOND.THE MACHINE WAS SHOWN AT THE SERVICE CENTRE,REQUISITION FOR NEW KEYBOARD PENDING SINCE LAST MONTH.KINDLY HELP ASAP.
try plugging in a standard desktop keyboard & mouse
if works the problem is probably the onboard keyboard/touchpad
if not work probably driver problem
try restart while pressing F8, select safe mode
if works go to control panel & check mouse settings
if ok either malware - run anti-virus application
or is bad hard drive media - run error checking
right click C: drive, select Properties, select Tools, select Error Checking, follow instructions
Nov 04, 2010 | Acer Computers & Internet
Acer laptop keyboard & touchpad not working
If you can log in by pressing the f8 key in safe mode, then try the system restore. If it doesn't work, it could be very well be a hardware failure.
Nov 09, 2009 | Acer Aspire 5102WLMi PC Notebook
Dell inspirion 1545 touchpad not working. pointer does work but both right and left click buttons not workings. My son says he closed as normal last night but problem touchpad this morning. Any clues.
Hi.,
Try in Safe mode once...,
(How to enter Safe mode?
:- Immediately after switching on the system, keep tapping F8 key on the keyboard, You will see a list of options there, select "Safe mode", & hit enter..)
also try Decreasing the touch sensitivity in the control panel,
Sep 30, 2009 | Dell F3534 Touchpad
Daughter has similiar problem with keyboard on inspiron 1545
Dont just fall for their promises. If your external keyboard works fine, it is surely a manufacturing fault. Insist on a replacement or a service. Tell them your external keyboard works fine and make sure you sound like a techie. People at those companies think we are dummies. Good luck
Jun 24, 2009 | Dell Spacesaver USB Keyboard J4624 SK-8115...
Juice on pi-1536 keyboard and touchpad
Juice on keyboard ?? Disconnect ALL power immediately!! Then, remove keyboard, run under quite hot tap water, then immediatey submerge keyboard in isopropyl alcohol in a shallow tray, place in a beach towel & with washing machine water OFF, spin the unit in towel, allow 24 hrs to dry in sun, reinstall. It works.... If LAPTOP got drenched, stand on side, with screen open, dry thoroughly 2 days, pray a lot,
Jun 21, 2009 | Fujitsu Siemens Computers & Internet
HP Pavilion DV1000 touchpad and keyboard freezes
sometimes its a hardware driver software and OS driver software conflict on touchpad. if after OS installation the touchpad is already detected, no need to install the touchpad driver. try disabling the touchpad driver you installed. hope this helps
May 30, 2009 | HP Pavilion dv1000 Notebook
Inspiron 1520 Can't turnoff touchpad. Unable to connect to Synaptics pointing driver. Find my cursor in random spots all over. Help!! Thanks
1. Go to the "Control Panel" and double click on the "Mouse" item.
2. Go through the tabs in the "Mouse Properties" window & find the tab where you can set up your touchpad. This differs from laptop to another since it is based on the touchpad's drivers.
3. On that tab, check & make sure that your touchpad is disabled.
4. Click "Apply" to apply the changes, then close the "Mouse Properties" window.
If you cannot find a tab to set up your touchpad, then your touchpad drivers might not be installed. In this case, you will need to install them first.
If the above does not work, then you might consider carefully opening your laptop and disconnecting the touchpad. Most laptops will run fine without it. However, beware that since all laptops are very different it might even then not be easy or possible to disconnect just the touchpad; it's possible that it's an integral part of the keyboard assembly, which means that you will be practically disconnecting both the touchpad & the keyboard.
If this either did not work, then you might consider replacing your touchpad (and/or) keyboard.
Apr 08, 2009 | Dell F3534 Touchpad
Touchpad & Keyboard unresponsive
please replaced the laptop ,other option u r put the button & clean the button
Mar 16, 2009 | Acer Aspire 5720 Notebook
Dell Inspiron 1525 Laptop Logo
62 people viewed this question
Alun Cox
