Question about Epson ZDS/ ECM-A0653 10.4 LCD
My C87 Printer problems
Dear Guru's
(1) I have a C87 Printer that used to work on a parrallel port however a connection nut fell off the housing of the port so it was a bit wobblie.I tried to glue it with araldite but it didn't stick.
(2)So I put a USB port card into my computer (Pentium 3) My programs are WindowsXP.
(3)Under instruction I then changed the ports by clicking on to;-
Control Panel then
Printers then select
Epson C87 & right clicked then
clicked on Ports then
removed the tick from LPT1 to USB local port
then pressed apply
(4) Then I pressed the test page and it worked perfectly, then I got some printing done off a website and that worked well but when I wanted to print off an e- mail it wouldn't work and the same with my documents.
(5)Then I decided to re-install to happier times like two days before but the calanders didn't seem to give me a choice so I had to go back a couple of months
When I turn on the printer and click the print button my computer makes all the right windows and noises but nothing, it talks the talk but doesn't walk the walk
My name is Paul Drake and my e-mail is [email protected]
  • Gerry Millward
    Gerry Millward May 11, 2010
    Hi Paul
    It's a long time now without any help forthcoming on this problem. Can you post a new comment updating the situation, so that I can try and help you fix it, or close it as solved!
  • 353 Answers
In view of the original poster's lack of interest and the long time since it was posted, I think we can call this one "Solved by Poster".
Posted on Mar 15, 2009
6ya staff
SOURCE:
Hello can this fax print out from the computer
the only way that u can use the fax machine as a printer is if it has either a parrallel port, or usb port that u can connect from the fax machine to the computer.
Apr 14, 2010 | Brother IntelliFAX 560 Plain Paper Fax
Epson TM 88II not working with Win XP SP2
Are you confident this is using a parallel interface?
The ones I used to work with used a 25pin to 9pin serial connection. The 25 pin connection on the printer is the same as a parrallel port on a PC, but if you think of a normal parallel lead the printer should use a 'centronics' connector to conform to this. I think you may need a 25pin to 9pin serial lead which aren't very common but plenty of people should still make them.
Stephen
Feb 18, 2010 | Epson TM T88II Label Printer
Connecting a HP 4550 parrallel printer to a USB Laptop
in order for you to use USB on this printer. you need to get "HP175x jetdirect, USB to parallel" which is print server box use to convert USB to parallel print port fo rolder printers that don't have USB or use as multiple pinters for network.
price is around $70 USD.
Jun 05, 2009 | HP Color LaserJet 4550 Printer
Printing from 2 differant computers.
At the same time,,no,u have to either use the parralel port or usb at one point of time
this printer was actually launched when the transition just started,,usb printers were new and the parrallel printers were already in use..so its like a backup,,if parrallel port on ur comp doesnt work,,then use the usb
best of luck,,giv a good rating,,keep me posted
May 19, 2009 | HP OfficeJet K80 All-In-One InkJet Printer
Lamp blinking
Normal 0 Driver could be corrupt.
Disconnect the printer or at least be sure it is turned off. I'd do both and reinstall the CD software program that came with the printer. When the software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Jan 06, 2009 | Epson Stylus photo C87 InkJet Printer
Sharp AR 5320 USB Printer port does not working
The usb cannot be switched off in either service of customer modes. have you tried using the parrallel port? Maybe it is a computer issue, wrong drivers perhaps, try a different usb port on your machine
cheers
Nov 29, 2008 | Sharp AR-5320 Black and White Copier
Problem with sharp ar 5320 copier
Sounds like a bad earth or loose connection. Try using the parrallel port instead, or take the panel off and look for bad connection
cheers
Canon bjc 50 printer
You are correct on your deduction.
It is the USB to Parrallel adpter. They are not reliable in the XP/Vista enviroment. I have run into this several times.
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
Oct 07, 2008 | Canon Office Equipment & Supplies
RJ45 Port
without the port you cant connect
Apr 23, 2008 | HP OfficeJet 7410 All-In-One InkJet...
Printing using Parrallels and winxp
How do you have this unit connected via parallel - there is no parallel port
Apr 22, 2007 | Epson Stylus CX6600 All-In-One InkJet...
Open Questions:
See all Epson ZDS/ ECM-A0653 10.4 LCD Questions
Computers & Internet Logo
74 people viewed this question
Top Epson Computers & Internet Experts
Philippos...
Level 1 Expert
Peter Dragonetti
Are you an Epson Computer and Internet Expert? Answer questions, earn points and help others
