Question about HTC Hero Smartphone
When I try to use Bluetooth to transfer pictures & music from & to other phones it shows paired but not connected. How can I connect?
Transfer of pics from Laptop to Samsung galaxy 2
I think it can be easier with an android assistant, you can transfer or backup text messages, contacts, photos, and other media files like videos, music files.
And which allows you to view them on PC, so you can choose selectively and freely. MobiKin Assistant for Android Windows Version
Mar 24, 2016 | Samsung Cell Phones
Bluetooth failed to connect on a sucessfully paired z221 device. fix?
You should use Accessories - Bluetooth File Transfer from your computer to send or receive files
Jul 02, 2012 | AT&T Cell Phones
How do I pair my phone to my blue tooth
Connecting a Bluetooth headset or car kit You can listen to music over a Bluetooth stereo headset, or have hands-free conversations using a compatible Bluetooth headset or car kit. It's the same procedure to set up stereo audio and hands-free.
  • For you to listen to music with your headset or car kit, the headset or car kit must support the A2DP Bluetooth profile.
  • Before you connect your headset, you need to make it discoverable so your phone can find it. You can find out how to do this by referring to your headset manual.
  1. From the Home screen, press MENU, and then tap Settings > Wireless & networks.
  2. Tap Bluetooth settings.
  3. If the Bluetooth check box is not selected, select it to turn Bluetooth on.
  4. Make sure that the headset is discoverable.
  5. Tap Scan for devices. Your phone will start to scan for Bluetooth devices within range.
  6. When you see the name of your headset displayed in the Bluetooth devices section, tap the name. Your phone then automatically tries to pair with the headset.
  7. If automatic pairing fails, enter the passcode supplied with your headset.
The pairing and connection status is displayed below the hands-free headset or car kit name in the Bluetooth devices section. When the Bluetooth headset or car kit is connected to your phone, the Bluetooth connected icon is displayed in the status bar. Depending on the type of headset or car kit you have connected, you can then start using the headset or car kit to listen to music and/or make and receive phone calls.
Jun 21, 2011 | Jabra Bluetooth Headset with Adjustable...
How do download a music from the PC to my cellular phone?
This process is not considered downloading but transfer, because you already have the music downloaded to your computer. You will need either Bluetooth or cable connections to connect your phone to your computer in order to make the transfer Bluetooth needs no cables but a little slower than cable connections. Connect your phone to your computer using the phone cable. or pair the computer Bluetooth with the phones Bluetooth this is easy if you already have Bluetooth on your computer such as if you use wireless keyboards and mouse, after select the songs you like to transfer and send them to a specific folder on your phone.
Apr 13, 2011 | Nokia 6300 Cellular Phone
How can I use my bluetooth for file transfer?
CONNECT YOU BLUETOOTH TO PC VIA PC SUITE OF YOUR PHONE .
CONNECT BLUETOOTH TO PC
RIGHT CLICK & OPEN SETTINGS
CLICK ON "ENABLE OTHER DEVICES TO FIND THE PC" & CLICK OK
PAIR YOUR MOBILE WITH PC .
YOU CAN NOW TRANSFER DATA.
Feb 04, 2011 | Cell Phones
Won,t send or receive pictures lg 290c
To send or receive pictures or any file, you need to be sure that your phones bluetooth is turned on, without it your phone will not be able to send or receive pictures or any files. Also, you can transfer files to a computer using a USB cable, connect it to a computer and other devices that Has a USB hub. Files can also be transferred through the SD memory card, you can transfer pictures to the memory card and remove it from your device, then you turn off your phone, remove the memory card, install it into other devices that allows memory cards, then you copy pictures from the memory card to other devices.
To use your bluetooth in transferring the pictures from your phone to other bluetooth devices, then you turn on youe bluetooth by going to the phones menu, select the settings, then you go to the bluetooth and turn it on, make sure the bluetooth device of other phones and devices are turned on then you select the picture to send and select via bluetooth, it will search for the available bluetooth devices, then you select the one you are willing to send your pictures to then you either pair id the device is not familiar, ensure you use a password that is easy to remember to pair with the other device.
That way your phone will be able to send the pictures. That should solve the problem. Hope this information assisted you!
Jan 10, 2011 | LG Cell Phones
I am trying to download pictures from my galaxy s fascinate phone and my computer is asking for a disc to be inserted to set it up. A disc did not come with the phone.
Most cell phones today have a few ways of getting pictures, music, videos to your PC/Laptop.
1. Via USB cable - This method usually requires drivers from a CD that came with your phone or can be downloaded from the manufacture's website in order for your PC to recognize your phone when you connect.
2. Via mini SD card - Most phones now have a mini SD slot where you can add more memory to the phone for pictures, music, videos, etc. Usually found attached on the side when you take the battery cover off. It will be a small black chip about the size of a finger nail and to remove it, you simply press it in, then it should release. If you have a memory card reader/slot on your PC/laptop, the mini SD card usually needs a separate adapter to make it fit into a standard SD slot.
3. Via Bluetooth - This requires your PC/Laptop to be able to connect with bluetooth devices. You must pair the PC with your phone first so they can communicate with each other. While using your phone, pick the file (picture, music, video, etc) from your phone, select Options, and send via bluetooth.
Oct 30, 2010 | Samsung Computers & Internet
I have a mac and I can't get music to transfer...
are you connected via bluetooth or usb and is this a phone you have connected to your apple mac and what are you using to transfer the music and pictures ?
Jun 28, 2009 | Motorola Mobility RAZR V3
Blackberry Itune/media player/mp3 player/bluetooth operation
alright bhavin,
all you need to do is first PAIR your both the devices using bluetooth, then in black berry on music or ringtone or picture whichever you want go to.. menu-->option-->receive using bluetooth ,,,, once you allow files to be transfer from nokia you will receive in blackberry... and for sending out from black berry... select SEND USING BLUETOOTH....
i was doing the same to transfer between my nokia and blackberry phones...!!!
but for downloading this particular files, i never this so sorry about it..!!
Sep 25, 2008 | RIM BlackBerry 8700c Cellular Phone
HTC Hero Smartphone Logo
132 people viewed this question
Top HTC Cell Phones Experts
Charles Blake
Charles Blake
Level 1 Expert
D. E. Hev
ChuckyMo
Are you a HTC Cell Phone Expert? Answer questions, earn points and help others
