Question about Hotpoint NWXR473EV Dryer
Renew my rubber door seal on my Hotpoint aquarius CTDOO dryer around the drum area
    Director Badge:
    Uploaded 100 video answers.
  • 213 Answers
Follow these steps to replace your door seal:
For all Free appliance repair videos visit our VIDEO TUTORIALS
Disconnect all power to the machine first!!
1 Locate the outer clamp band securing the seal to the door rim on the washing machine and examine it carefully for holes or tears. Many can be prised off with a flat-bladed screwdriver they have a spring system holding them, but some have a tensioning arrangement that has to be loosened.
2 After removing the outer clamp band, locate the inner one securing the seal to the drum and establish how this is secured. It may be necessary to loosen a clip, or you may be able to prise the band off with a flat-bladed screwdriver. Some are like very large Jubilee clips that you have to undo usually from the top.
3 Once the clamp bands have been removed, use both hands to pull the seal away from the inner drum rim. Some machines have a water spout holes that will have to be lined up. Others have a drain holes.
4 Rubbing a drop of washing up liquid into the groove on the door seal/gasket that locates on the drum makes fitting the new seal easier.
5 the new washing machine door seal should be fitted by locating the drain holes at the bottom of the seal first then push it on with both hands working opposite directions towards the top. This is quite hard if you have never done it before.
6 refit the inner band remembering this must be tensioned correctly for it to be water tight.
7 now fit the outer band and the test the machine for any leaks,
All washing machine spares featured in this article are available at apart4u with more video help in our tutorial section.
Information provided is a guide only. aPart4u accepts no liability for any problems occurring whilst attempting any advice shown. If in any doubt about fixing your appliance, always contact a qualified repairer.
Posted on Jan 19, 2010
Hotpoint aquarius ctdoo. the door catch on my dryer is not holding the door shut. do i have to take the outer casing off to get to it to replace it? is it a fairly easy job? thaks for any advice
You should not need to remove tho outer casing, usually the latch is screwed straight to the door, I see if I can find the replacement,
which is your model?
Apr 20, 2008 | Dryers
I CANT GET FRONT OFF HOTPOINT AQURIUS TI CHANGE RUBBER SEAL
to change the door seal you have to take the front boot ring off fold the door boot into the drum and undo the retaining clip around the door seals inner drum you can get a screwdriver in from the top a bit tricky but its the only way as the front is riveted on and wont come off like the older machines
Dec 08, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
HOW TO REMOVE RUBBER SEAL
ok if you look around the front of the rubber seal you will see a wire holding it in place on the wire there is a spring if you pull the spring off with a pair of pliers the door seal will just pull off the cabinet then take off the lid and you will see the wire that goes around the door seal where its held onto the drum some have a screw on it and some just pull off then give the seal a good pull from the front of the machine it will pull off quite easy then just push the new seal into place and replace the wire thankyou
Jan 23, 2011 | Hotpoint Aquarius WMA56 Front Load Washer
Hotpoint aqurious leaking at front underneath,concrete block wet at front towards door,alot of water coming out,any ideas thanks.david
Carefully check the door seal for any sign of a hole or tear in the seal.
Or it could be leaking from the drum front or the drum front seal, this is another seal , not the door seal., you cannot see this without removing the front panel.
Feb 22, 2010 | Hotpoint Aquarius WD63 Front Load...
My hotpoint aquarius condenser dryer wont dry the clothes.The stainless steel panel at the back of dryer get roasting hot within seconds of switching on dryer. The rubber seal around the inside of the...
You have an air flow issue to resolve.
https://www.repairclinic.com/RepairHelp/Dryer-Repair-Help
Utilize the above link above to aid you in disassembly/diagnostics and parts.
Hint: try using without an external vent attached to compare. Beyond that, you will need to consult the above link for more advanced information.
Nov 25, 2017 | Dryers
Hotpoint ultime wt640 has a slight squeek seem to be on front around door area had top off and turned drum motor and drum seem fine and springs ok
Remove rear cover of washer, remove drum belt,and from front of washer, spin drum by hand.
There should be no noticeable noise.
If you can still hear sqeek, then it could be a drum bearing that is dry or starting to fail. or the drum is rubbing on the front of the door seal
You should be able to detect what it is this way.
Please rate my solution.
Thankyou.
Jan 17, 2010 | Hotpoint Aquarius WD640 Front Load...
Hotpoint aquarius 1200 washing machine leaking
this could be
1 door seal
2 heater ellement
3 front plate
4 front plate seal
5 outer container split
try looking at these first
Jun 27, 2009 | Hotpoint Aquarius WD63 Front Load...
Can anyone tell me how to replace the heating elememnt on tumble
open back pay attetion to where you take the old one off just streach it out around the clips
Feb 17, 2009 | Hotpoint NWXR473EV Dryer
Replacing door hinge wd63
Hi there is a plastic band around the rubber seal to take it off you would need a small screwdriver and prise it open gently than lift off the rubber and replace the door switch to put back the band just push clip the two ends together when it is around the rim
Jul 16, 2008 | Hotpoint Aquarius WD63 Front Load...
Dryers Logo
359 people viewed this question
Top Hotpoint Dryers Experts
Gerry Harvey
Gerry Harvey
shaun taylor
Are you a Hotpoint Dryer Expert? Answer questions, earn points and help others
