Question about Canon imageCLASS D680 Laser Printer
Canon D680 paper jam can't clean out
Paper was fed in from the side and there is a jam now. When I take the toner cart. out, you cannot see the paper. Yet, from the other side I can see where my staff tried to pull it out, and just tags are left. It could even be accordianed(?) in only and inch of space? thanks.
Soulvisitor
  • 1113 Answers
SOURCE: NEW TONER INSTALATION
Non gen toner or fuser gear smashed, replace toner or fuser assy NO NEED TO YELL
Posted on Dec 28, 2007
SOURCE: paper jam
We had this same problem. You need the back cardboard section of a legal pad. Take out the cartridge and slide the back of the cardboard slowly into the rollers, pushing it out the end where the paper comes out. This helps push the paper jam out. You may have to do this several times slowly to get the jammed paper out. But it worked for us!
Posted on May 21, 2008
HARDWAREGURU
  • 66 Answers
SOURCE: Canon PIXMA MP480 bought 4 months ago jams paper
paper jam problems are usually occured by dust and debris in the printer . clean up ur printer from inside . also align ur paper tray. that will fix the problem. thanks and take care of urself.
Posted on Jun 09, 2009
SOURCE: canon mx300 printer feeder pulls unevenly causing paper jam
the left side of the printer pulls the paper causing the printer to jam when trying to print
Posted on Jul 10, 2009
FixinFax
  • 3085 Answers
SOURCE: changed toner cart. do to void in middle of print
Most toner PIRATES just drill and fill recycled carts without changing the drum or blade.
Posted on Aug 20, 2009
Paper jammed inside my printer near bottom
open front cover where toner cart is situated and remove cart.check and see if the jammed paper has fed into the machine and if so pull paper in the direction it is feeding into the machine.
Oct 26, 2012 | Samsung ML-3051N Laser Printer
My canon imageclass mf4270 jams 90% of the time when i try to print. sometimes if i pull out the toner cart several times. it will print.
Hello sir; Check the paper path carefully is there have anything block over there, especial at both end. is the paper jam everytime at same place? cleaning up the roller with alcohol.
Aug 05, 2009 | Canon Office Equipment & Supplies
Had paper jam, Cleaned it out.
Ni there is something ( a small piece of paper) over the sensor in doc feeder- have a close look with a torch
Apr 23, 2009 | Canon imageCLASS D680 Laser Printer
I have a canon image class d680. the machine no
Have you tried to clean the pick up rollers with a rag with a small amout of WD-40 or Simple Green. Clean the roller then whip off with a dry rag. If the problem improves you need to replace the pick up rollers. If not you may have to replace the paper feed clutch. Also, look to see if the seperation pad is ingaging when the paper tray is pushed in. Open the left side door. I've seen the actuator break. Also, have you tried to use the manual feed tray???? I know you made sure the paper guides in the paper tray are set correctly for the size paper in the tray??? Good Luck
Feb 26, 2009 | Canon Office Equipment & Supplies
Canon D680
need to replace pickup rollers, you might want to replace all of them.
Dec 20, 2007 | Canon imageCLASS D680 Laser Printer
Canon d680
try new cartridge. are you using new or remanufactured?
Nov 09, 2007 | Canon imageCLASS D680 Laser Printer
Blank pages printing on ImageClass D680
Greeting IceCreamMan, It sounds like you?ve eliminated the toner cartridge as the culprit. I suspect that when you did the disassembly and connector was missed or an electrical connection fault developed. Look for the electrical contacts that connect to the toner cartridge, they may not be making contact. Make sure the spring contacts on the printer are connecting to the cartridge and that they are clean. If that?s not it then check: -all connectors to make sure they are plugged in and oriented correctly -for missing or incorrectly aligned top or side panels (sometimes they are linked to switches) -all wires (for damage) and secure connections Let us know how it goes and don?t forget to rate the posting.
Jan 04, 2007 | Canon imageCLASS D880 All-In-One Laser...
Canon imageCLASS D680 Laser Printer Logo
150 people viewed this question
old marine
old marine
