In the middle of operations it freezes - Computers & Internet
  • 115 Answers
Might be issue with Bad sector in your hard drive.Pls format and re-install the Operating system and check it .
Posted on Nov 19, 2009
Faby 3 slush machine over freezing
Assuming the mix is mixed correctly and the auger is turning, make sure the micro switch to the right of the motor in the back is in place correctly and works ok. That switch tells the freezing to stop.
Jun 13, 2015 | Faby Cab S.p.a Faby CAB Frozen Drink...
Asus k53e keyboard freezes and then fan blows out hot air
sounds like it's overheating turn over after shutting down and look to see if there's clogged vent for fan
use a plastic tip on vacuum to get dust out then try it again
May 22, 2012 | ASUS K53e B1 Notebook
Fridge partly freezing at top and bottom , middle staying neutral, why?
Check your evaporator fan motor also make sure there is no obstructions such as plastic bags blocking air flow.
Aug 02, 2017 | LG Refrigerators
Refrigerator food freezing even when on lowest setting
There is one of three reasons why your fridge section is freezing food. You didnt mention whether you had a side by side or freezer on top or bottom model, so the following checks may not apply to your unit.
One reason food might be freezing is your cold control has failed, and will not turn the unit off when the physical temps are correct. When this occurrs food normally freezes throughout fridge section, top, bottom, middle, front and back.
BOTH controls, though you may only have one, should be at the middle setting. Adjust your controls, place a plastic cup of water at the top, the middle, and bottom shelf of your fridge. Check all three AFTER 24 hours. if all three are ice, you COULD have a bad cold control.
It is possible you might also have a door damper that is stuck open. A door damper is a swinging or sliding door that opens / closes either when temp control settings are adjusted, or on some fridges, when either door is opened, the damper closes. Please note, door dampers are USUALLY only present on side by side refrigerators. They can have a motor, or thermostat open the door automatically,which can break, and others will simply have a lever of some sort, which usually wont.
If after 24 hours, only the middle and bottom cups are ice, your evaporator fan motor, in the freezer, is likely not operating. Not knowing the BRAND you own, it could be the motor itself, a thermostat located on the evaporator, your defrost heater, or a main computer control board that controls the fan motor.
Sorry I cant be as specific as id like, but i had to cover all possible bases
Oct 16, 2011 | GE HSM25GFTSA Side by Side Refrigerator
The cursor freezes in the middle...
Mike ,,if this is a reoccuring problem the best /only solution is to re-install your Operating system and while this is taking place do not touch any keys unnecessarily and have perpherilal equipment unplugged at this stage,make sure mouse is compatable if wi-fi or external.
Good luck
Davey Snake!!
Jul 20, 2011 | Sony VAIO Notebook
Ps3 freezes in the middl of the game
Um You Know What you should do I recommend you to get a cooler fan it works perfectly for me bud!
Mar 29, 2010 | Sony Playstation 3 (PS3) Console
Geting booted from pogo bowling , and other pogo games.
Please try using firefox browser. Safest and better than internet explorer. (click here to get )
let me know if the problem is still there.
May 21, 2009 | Microsoft Windows XP Professional for PC
Freezing in the middle of play
If u r playing on xbox live it can be the internet connection or memory problem.
Mar 27, 2009 | Microsoft Xbox 360 Console
My laptop freezes in the middle of doing anything therefore I cant get anything done.
run a spyware removal program on the computer and see if that helps. also what is the make and model of the computer as well as the operating system you are using
Dec 16, 2008 | Acer TravelMate 2300 Notebook
Computers & Internet Logo
26 people viewed this question
David Payne
David Payne
