Question about Canon EOS Digital Rebel XS / 1000D IS Digital Camera
Upon inserting memory card, red access light comes
Upon inserting memory card in new 1000d, red access light comes on, whether camera is on or off and remains on until battery removed and camera will not operate. Camera functions seem ok until card inserted and yes it is the correct card.
5 Suggested Answers
Bubbabear64
  • 2794 Answers
SOURCE: Memory card locked
Take the card out. On the left side of the card is a tiny white switch. Reverse the position.
Posted on Jul 04, 2008
  • 12 Answers
SOURCE: no card displays on cannon 1000d camera
try with another sd card...if card is the problem replace it... if not try to repair it in authorised shop
Posted on Nov 25, 2009
t00nz
  • 4738 Answers
SOURCE: Loaded new memory card, and screen reads memory
I'm guessing you bought a new 4GB SDHC card. Although it looks exactly the same as a standard SD card, the format the card uses is very different. If your camera is more than a few couple years old, it's likely it was designed before the SDHC format came out. Sorry, but a SDHC card will not work with older cameras.
For older cameras, you'll need to use standard SD cards (usually those 2GB or less). But if you really want to use a 4GB card, do a Google search for 4GB SD "non HC", with the non HC in quotes. Believe Transcend makes one.
Posted on Dec 25, 2009
  • 22 Answers
SOURCE: canon EOS 400D will not power up
Generally a fuse blows on these, on the DC/DC converter (psu ) board. This is situated on the front of the camera, fairly easy to get at just involves undoing loads of screws!! The fuse is marked "K", replace or short out with a thin piece of wire. May be caused by changing lenses with the power on, but not sure.
Watch for the charged flash capacitor though!!
Had this problem with mine.
Phil
Posted on Aug 02, 2010
When memory card is inserted the camera wont work
You can insert CF memory and some memory stick cards when you use a special adapter. When you use a memory tick, make sure it is compatible, because the memory stick is the most incompatible memory card, if you have not the correct one.
When you use a CF memory card, check all contacts. Not one contuse pinn in the camera should be belt a little. Use a bright light and a loupe to check.
Feb 13, 2014 | Sony Alpha DSLR-A350 Digital Camera
Canon t3i will not turn on without sd card?
This a situation the manual not even mentions. The red light on the bottom right of the camera is the memory access indicator. It should light green as I remember ok. And blink when it is writing to or reading from the memory. If it is red, it means : this is not ok.
This light is not a gadget. It should be taken serious. As long as it is burning, of flashing you are not supposed to switch of the camera or to remove the memory card. If you still open the memory compartment or switch of the camera or remove the battery, while the camera indicates I'n accessing the memory, serious damage can occur to the memory card.
You could lose all your pictures, because of it.
I would suggest, make sure your battery is charged correctly.
Format your memory card in a PC with FAT 32.
Check if al contacts in the camera are clean and shiny. (Battery and memory card contacts too)
The place the battery and the memory card in the camera and try switching it on again. If it should start, first do a format of the memory card in the camera before you starts taking pictures, of the camera has its own format and can make a folder.
You should be able to switch on the camera without a memory card inside. The camera will us the internal buffer, to let you take a picture in DEMO mode.
I hope the red light does not indicate your internal memory is corrupted. Because if nothing helps and the red light comes back, I think you should contact a Canon service centre.
Jan 14, 2014 | Canon EOS 600D Rebel T3i Digital Camera
My kodak 1073is camera keeps telling me to format my new sandisk sdhc memory card when I do it tells me to insert a new card
Please confirm the model # so that I can check whether the large capacity memory cards are compatible with your camera.
Jun 23, 2012 | Kodak EasyShare M1073 IS Digital Camera
Insert memory card and says card not read, format disk. Camera menu wont allow formatting.
Maybe it is having trouble with the size of the memory. Memory cards have grown enormously in capacity in the last couple of years, and even relatively new cameras may not be able to cope with the memory size of the newest cards.
SD and SDHC cards fit the same slots, but many cameras won't work with the SDHC (high capacity) cards. SDHC is not backwards compatible.
Nov 04, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
I have a Conon Powershot S1 IS camera and bought a Transcend Compact Flash 4GB memory card and when I insert in into the camera a red light flashes at the menu and set buttons?
Have your new memory card inserted into your PC to test for any virus. Format the memory car.
Please check if your cannon is adaptive to the 4GB (check the instruction manual) if the card shows the same fault now after inserting.
Use another card into the camera to confirm if the card slot is faulty.
Sep 13, 2010 | Canon PowerShot S1 IS Digital Camera
Camera is stating No Card when there is an SD card in camera
camera sd card board is faulty you need to relace new sd card board.
Jul 09, 2010 | Canon EOS Rebel XSi Digital Camera
No card displays on cannon 1000d camera
Possible bent pins in the card slot. This does require professional fix. Either manufacturer if under warranty or Camera repair shop.
Jun 15, 2009 | Canon EOS Digital Rebel XS / 1000D IS...
Memory Card
If you transfer the photos to your computer from the camera, you should be able to save to another memory card. I can't say whether or not the photos on the new memory card will show up on your camera since there may be certain requirements to display on camera screen.
Plug your camera into the computer USB or insert old memory card. A box should pop up giving you the option to view files. Copy and Paste (or Drag) selected photos to a specified folder on your computer (Like My Pictures in My Documents). Insert new memory card. Copy and Paste (or Drag) selected photos to the drive for your memory card.
May 06, 2008 | Samsung Digimax S630 Digital Camera
Camera wont turn on, intermittent red power coming on
This may or may not work (it's primarily a trick for certain Canon cameras with similar symptoms). Remove the cameras battery, then remove the memory card. Insert a BRAND NEW or fully charged rechargeable batteries. DO NOT insert the memory card. Instead, just turn on the camera. If the lens retracts, turn off the camera, insert the memory card, then restart the camera.
If this doesn't work, here are some other things to try. But don't get your hopes up, as they only seem to work for little less than half the cameras with similar problems:
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Jan 08, 2008 | Fuji FinePix V10 Digital Camera
Canon EOS Digital Rebel XS / 1000D IS Digital Camera Logo
26 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
