Question about Cell Phones
I have an 3phase roof top unit the owner was told it can run on 1phase wiring. is this true.
    President:
  • Cell Phones Master
  • 1,922 Answers
Yes you can , but it would be cost prohibitive because the compressor would need to be changed out with a single phase unit( that is if they make a single phase unit this large) and anything else as in condenser/evaporator motors would also need change out if they are 3 phase motors, as for just wiring it to a single phase line, it can't be done
Posted on Nov 19, 2009
3phase to 1phase transformer
when your dealing with a high leg as long as your using two phase wires it is balanced. any two legs will give you 240 volts a.c.
Aug 29, 2015 | Heating & Cooling
Wiring oven diagram
should go to imperialrange.com you can find the wires diagram in it.
good luck
Jan 23, 2014 | Imperial Ovens
I have a travel trailer with a coleman 7300 roof top ac unit. the unit will blow cold air but water leaks thru the plenum. i was told by the previous owner that it needs a new seal. i would like to fix it...
If it's leaking inside where filter cover is, then real good chance the drains being plugged is the only problem. If water (condensation) not running off roof when operating in cool mode, then I'd bet drains, which are located under unit on roof, and you should see them sticking down like buttons. They have a hole in side that needs cleaning with a pipe cleaner or similar to open them up. If need be, shut off power to unit and remove top cover on roof unit and look for the drain holes in base, and clean them out. If water comes in while raining, but AC not running, then it's gasket. That is remedied by removing ceiling assembly (just screws) and 4 bolts that pull/hold the upper and lower assemblies together, unplug wiring to upper unit, and simply lift it off, change gasket and re-install. Tighten those 4 bolts equally when gasket is aligned properly over hole, only until gasket is approx 1/2, original thickness. Plug harness back in and your done. (about an hours work.) Only other thing that may be wrong is styrofoam drip tray for cooling unit, under cover on roof may have a crack , allowing condensation to leak in. If that 's the case, you can try to find a sealant compatible with styrofoam to seal those cracks.
Nov 14, 2010 | Dometic Rooftop RV Air Conditioner
If i am in the process of buying a generator to run 2 carrier RV rooftop ac units how big should the generator be?
You need to find out the maxamps of the rooftops which is located on each unit, then you will need to find out if these are 1phase, 2phase or 3phase units.
That information is also located on the unit and usually is marked 1P or 2P or 3P. If its 3Phase you
would need to talk to a electrical contractor or the
manufactuer of the generator you wish to purchace.
More in for is needed on the phase of the unit and amps that it draws
Feb 12, 2010 | Dometic Rooftop RV Air Conditioner
Only have two phase power power company refuses to install three phase can i run my hobart h600-t mixer serial#31-1068-582 ml# 104385 with just two phase?
first thing, there is no 2 phase pwr. there are only single phase or three phase.you have 2 choices either you can convert mixer from 3phase to 1phase which will be expensive, or you can get a rotophase which will make 1phase pwr to 3phase pwr to run mixer, dont go with static phase inverter, only the rotophase inverter
Jan 19, 2010 | Hobart H600 Stand Mixer
I have an A.O. Smith f48l47a50 blower motor, and I need help with wiring. First it's a 460v,1phase,1/2hp,975rpm,3spd motor. My question with the wiring is do I need to supply a wire for line power? I know...
are you SURE its 460volt single phase??? that voltage is normally a 3phase motor voltage,and color of wires is right for 480/277, but that would be 3 phase.....not saying your wrong,just make sure
Jul 29, 2009 | Heating & Cooling
Taylor 1999, series 754, 3phase ice cream dispenser freeze up
I have had this with other Taylor machines. The rear drive bearing has a pin driven into the coupling that turns the beater bar. This pin will shear off. The pulley will turn and give the illution that the beater bar is turning but it really isn't. With the unit unplugged, try holding the beater bar still and try turning the large drive pulley.
I have also had situations where the hex piece that the drive shaft goes into, was rounded out. As soon as the mix go a little firm, the beater bar would stop turning but the rear drive assy didn't.
Check this out and let me know.
Jul 07, 2009 | Freezers
Wrong voltage rating
Hello. If the unit is rated 460v, 3phase, the only way you can get it to meet your supply of 208v, 3phase, is:
a) have a transformer installed to make 460 from your supply by an electrician, or call your power company and see if 460 could be supplied to your building, but it would only be for that machine.
or
b) replace the heating elements for the 208v supply, have the pump motor checked to see if it will work on 208v, and a control transformer for the control circuit, as well as all the wiring related to the pump and heaters, as on 208v, they will draw more current than on 460.
so, can it be done? yes. Is the expense worth it? only you can answer that, However I would suggest that you resell that machine, and get the correct one from the start.
Hope that helps, and thank you.
Feb 16, 2009 | Jackson 25 in. TempStar HH Free-standing...
Need wiring info on DAYTON 3E342A. All info needed .
if you will google the make and model number you should find a pdf owners/ service manual
Dec 17, 2008 | Dayton Electric Heater
Cell Phones Logo
64 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
