Copier won't print. Scan bar is stuck and does
Copier won't print. Scan bar is stuck and does not move.
  • 115 Answers
Issue has been resolved from BT ,hence resolving the ticket.
Posted on Nov 19, 2009
  • SANTOSH KUMAR Nov 19, 2009
    Its by mistake pls ignore this solution
    email_santos
Our Data light keeps flashing and the printer won't print. How do we get the data light to stop flashing so we can use our copier again with our computers?
Sounds like a bad print job stuck in a print spooler.
Turn off copier. Go around to all computers that print to it and open the print queue. delete all print jobs. reboot each PC. Power up copier and see if it clears
Jan 15, 2013 | Sharp Mx-M450nb Digital Copier
I have a Brother MFC 8440. The scan bar has stopped functioning the bar deos not move to scan the documents. It makes intermittant sounds but seems stuck in its resting place?
If the device was moved without the light bar being locked prior to moving, it is possible that the light bar was knocked out of alignment and it will not work. It is very important to lock the light bar prior to moving for that very reason. I would suggest you take the device to a qualified specialist to identify the issue.
Nov 04, 2011 | Office Equipment & Supplies
Scan light/bar will not move. It seems to be "stuck" It does light up, top feed vibrates but will not feed. Print command from screen works and unit prints
If making a copy on the printer does the same thing, it's a hardware problem in the copier/scanner area. You can try turning off the printer then powering it back on after 30 seconds. Make sure the printer is plugged in straight to the power outlet in the wall, bypass any surge device or power strip. If problem persists, I strongly suggest you contact Lexmark technical support to further investigate the problem.
Aug 10, 2010 | Lexmark X7350 All-In-One InkJet Printer
The printer will print a bar code but the reader will not read it. the reader reads the bar code from a second printer just fine
Sounds like there are some elements worn off of the printhead causing some of the bars to not be printed. To test, create a label that prints a thick black line or solid black box across the width of the label (assuming a 4" label). Any vertical white lines that show indicate elements that are not functioning.
You could also put one label above the other, lining up the barcodes and you'll probably see bars that are missing from the label that won's scan.
The only ways to correct the problem are to install a new printhead or move the barcode field on the label so that the missing elements fall in the spaces between the bars.
Hope that helps !
Apr 08, 2010 | Zebra TLP 2844-Z Thermal Label Printer
Sharp AL-1631 copy problem
it doesnt sound like to much is rong with the scanner they all judder at start up. if there was a scan drive issue you would get a L3 error code. does the m/c continually tick over? if so then you may just be out of toner as the m/c will be trying to reach its toner levels and that can take some time.
Dec 03, 2008 | Sharp AL 1631 Copier
Scan head lamp does not move
the scanner lock could be on. This is located above the paper exit
trat. It has a knob with a picture of a lock. It shoulb be in the lock position. The scanner bar could be dirty. This is located under the copier glass.
Dec 01, 2008 | Office Equipment & Supplies
Scan a document to my file server
that's in scan settings from print manager..
May 03, 2008 | Kyocera Mita KM-3035 All-In-One Laser...
jasbo
jasbo
