Question about Creative Labs Zen Micro MP3 Player
If i want to safe or delete a file from my usb it says it is writ
If i want to safe or delete a file from my usb drive, it says that i cant because the usb drive is write-protected.
what should i do to un-protects it?
If you know the make of it, search the net for a software upgrade. That may work. I had the same issue with a Philips 4Gb stick and an upgrade fixed the problem for a few months. Then it appeared again. Since it was still under warranty, I returned it and got a refund. Good luck!
Posted on Nov 19, 2009
How can I Delete an old map in the memory of a Garmin nuvi 765T GPS Receiver.
You can delete an old map by connecting the unit up to your PC, using a USB to mini-USB cable. Once the Nuvi shows up as a valid drive letter in windows, double click on the drive and then go to the Garmin directory. Look for the file named gmapprom.img. It should be a file near 1 GB. Right click on the file and select delete.
This will delete the map. Warning, once you do this, your GPS will no longer function and you will need to install a new map.
Before you delete it, always make a backup of the map file on your PC.
Once you are finished, be sure to SAFELY remove the drive in Windows BEFORE you remove the USB cable.
Dec 13, 2014 | Garmin nuvi GPS
I cant rename my toshiba canvio 3 1tb
Check to see if there is a file in the root directory called "autorun.inf". (Make sure you can view hidden files.) If there is, either delete it, or move it to a backup folder. Now you should be able to rename your portable hard drive.
If you don't see the new name take effect right away, Safely remove the drive, unplug it and plug it back in. The changes should show up immediately.
Mar 02, 2013 | Toshiba Canvio 500 GB USB 3.0 Portable...
I cant delete files from my usb-stick. i thinks a virus is stopping me from deleting the files.can anyone please tell me what i can do?
insert drive in your computer but dont open any files. close out the screen that comes up for the drive. then go to my computer and right click on the drive one time. then you should see scan for viruses. do that to check for and delete viruses. then go and open the usb drive and try to delete the files
Mar 21, 2012 | PQI 512MB Intelligent Stick USB 2.0 Flash...
Ceedo file is corrupted how do i remove it
Hi, Thanks for using fixya.
Go in My computer/ Computer with the 160 pluged into the usb port. Right click on the Seagate choose format If you have other files on it and you don't want them deleted go in safe mode and try to delete the file that way
Hope this helps.
Terry.
Feb 15, 2011 | Seagate 160GB 3.5" External USB Drive 160...
How can I recover a deleted file on my Cruzer USB stick? I don't have any security problems, I just accidentally deleted the file. Please help!
if you have choosen only delete option then you can restore it from recycle bin but in most cases the deleted files from usb drive does not go into recycle bin, rather they are pemanently deleted. if you have choosen shift+delete then there is no way that you can get the file back as shift+delete permanently deletes the files..
Oct 17, 2010 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
Deleting files from a write proctected pen drive
HP USB Disk/Drive Format Utility is a Windows based software
used to format drives to FAT, FAT32 and NTFS partition types.
1. Download this tool:
http://dl.dropbox.com/u/4040651/HPUSBFW_2.2.3_MASTER.exe
2. Format pen drive
(Before removing USB flash drive click on the Safely Remove
Hardware icon and then click on USB flash drive you want to remove)
Jun 27, 2009 | Pen Drive IVO MP3 Player
HOW TO REMOVE WRITE PRTECTED OR AUTORUN.INF FILES
removing write protection in pen drives is impossible..because tht is due to some hardware problemsi and no software can remove writ protection..anyway try this..logon to a linux machine(i prefer ubuntu )
and in terminal route to your drive and type sudo chmod-R 777/media/ and press enter..if one failes to delete files again..then throw away the pendrive.he heh..!!
Jun 15, 2009 | iLO (2 GB) MP3 Player
Downloaded files wont delete
Hi.. If the files were loaded to the SD card directlt from your computer via a card reader, try deleting them while in Safe Mode.If loaded directly to your phone, check if there is a setting on the phone or on the file properties to protect the files. If so, adjust it as needed, then attempt to delete the files again.
Jan 20, 2009 | SanDisk 2GB microSD Memory Card
Non ntfs problem
One possible work around
Provided you have access to another PC and feel comfortable with taking your hard drive out of your PC and putting it back in
1. buy a USB external hard drive enclosure and install your hard drive into it
2. connect this USB hard drive to another PC
3. create some free space by deleting some files (see Safe files to delete below for details)
4. reinstall hard drive back into your PC and try to boot normally
1. temporary files - on Win XP these are normally in "C:\WINDOWS\Temp"
2. temporary internet files - on Win XP these are normally in "C:\Documents and Settings\[Your Username]\Local Settings\Temporary Internet Files"
3. other temporary files - on Win XP these are normally in "C:\Documents and Settings\[Your Username]\Local Settings\Temp"
Note that if you have more than one user account on the PC, then each user could have files that are safe to delete in the folders mentioned in number 2 and 3
-Magnon
May 24, 2008 | Intel (RK80532PG0881M) Pentium 4, 3 GHz...
Creative Labs Zen Micro MP3 Player Logo
59 people viewed this question
Top Creative Labs Audio Players & Recorders Experts
Carlos L. Burgos
Carlos L. Burgos
Are you a Creative Labs Audio Player and Recorder Expert? Answer questions, earn points and help others
