Question about Plustek Ipcam P1000 Network Camera
Is the Plustek IPcam P1000 a PTZ Cam? - Plustek Ipcam P1000 Network Camera
I have a cheap floureen DVR security system. I'm attempting to contact a electric rotating bracket which pans and tilts (it allows me to connect my cameras to it). My question is can I run this with the...
U have used Qsee, Swann and Lorex. I have a PTZ that has worked on several systems. There is a set-up for the actual PTZ camera which you appear to be aware of. The App or program you are using has a set up for a PTZ along with on screen controls for it in the program. If the DVR you are using is not PTZ ready there is your answer. Should have a 2 wire acceptors one negative one positive.
The movement you are seeing initially, are the PTZ powering up and self testing. What brand DVR are you using, and is is compatible with your PTZ camera?? LOL Swann Tech Service said my Lorex PTZ wouldn't work with my new hi-res system. Well it does...
I will try to look for your reply to continue to troubleshoot for you.
Cheers,
Chance
San Diego, CA
Dec 12, 2017 | Cars & Trucks
No PTZ control when moniot is connected to CCTV camera
PTZ CCTV camera enabling wide area coverage and gives details of area in night vision also. Your PTZ camera not monitoring well . Have you checked the setup you have installed is correct?
You can find setup instructions for configuring the PTZ camera from the Expert Security System provider.
Aug 08, 2013 | Dome 4 CCD CCTV Camera Surveillance...
How do you set up a ipcam to work on the internet
That's a great question, but there are no details here.
What kind of internet connection do you have? Are you behind a Wi-Fi router? What kind of ipcam do you have? Do you know the IP address?
Generally, if you are at home, you need to add a NAT transversal rule to your router to access anything from your home network on the Internet, unless your router and IPCam support UPnP. I can't help you any more without more details.
Apr 05, 2013 | Computers & Internet
Hi, i have a dlink dir-412 mobile router. how can i add an ip camera in this router. i will connect to internet via modem. i get an dynamic ip address after conect to internet. is it possible see the ipcam...
access your router using 192.168.1.1 username/passwd if not altered should be admin/admin u can set your ip (static ip) and i do not see why you can not assign an ip for your cam, my guess is you want to veiw you the camera feedback across the Internet. there various ways of doing this just remember that your cam is connected to your local network not to the Internet. good luck
May 09, 2011 | D-Link 3G Mobile DIR-451 Router
I have a Plustek OpticFilm 7600i SE film scanner. Every time I try and load-up the setup disc, the set up install starts and then comes up with this error message: An error (-500 : 0x8004ace8) has...
It is quite possible that there is another piece of software that is clashing with your Plustek OpticFilm scanner. It is hard to tell which software is having a clash. If you remove that software from your system you will obtain the desired results. I suspect the SP3 of Windows XP may be responsible for this because Microsoft has indicated that Windows XP SP3 is not for everyone. If you install Windows XP SP2 uninstalling XP SP3 your problem can definitely be rectified.
Good Luck!
Mar 10, 2011 | Plustek OpticFilm 7200 Film Scanner
I need to replace a Samsung SCC-641 can't seen to find any online.
I have two non working cameras with working power control plates if you are interested. Contact pbyer14@gmail.com
Jul 19, 2010 | Samsung Power Supply, Control Plate for ...
Where i can download a driver for a optic web cam
Open http://plustek.com/support/download.asp select your model and windows version from drop down list and download drivers.
May 23, 2010 | Plustek OptiCam Personal Web Camera
I can't remove numbers that appears in screen when i use a Samsung PTZ camera. Can you help me?
sounds like you are seeing a display generated from the PTZ camera itself. can you access the camera's menu?
Jul 20, 2009 | Samsung SADT-100PM POLE MOUNT ADAPTER FOR...
Plustek OpticPro9636T power supply specs
15V power adapter for Plustek OpticPro 9636T scanner
http://cgi.ebay.com.sg/15V-power-adapter-for-Plustek-OpticPro-9636T-scanner_W0QQitemZ260203426286QQihZ016QQcategoryZ51087QQcmdZViewItem
Apr 28, 2008 | Plustek OpticPro 9636T Flatbed Scanner
Plustek Ipcam P1000 Network Camera Logo
Top Plustek Computers & Internet Experts
David Payne
David Payne
Are you a Plustek Computer and Internet Expert? Answer questions, earn points and help others
