Question about LG Vu CU920 Cellular Phone
I cannot hear anything when I make a call. I have
I cannot hear anything when I make a call. I have popped the battery and that does not help. and the volume is at max. I have also tried to mute and unmute and nothing there either
When starting it makes a popping sound.
You have to find out where the popping sound is coming from, it can be a bad intake or exhaust valve or bad lobe on the cam, Ignition timing, rich or lean fuel mixture, or just a simple vacuum leak,
check all the hoses on your engine, and listen for hissing while it runs, vacuum leaks are often found by hearing a hissing, even when the brake booster leaks and you hear it hissing by your feet while you drive,,
Good luck, if you find anything and have more questions, leave me a comment, I'll help you!
Mar 24, 2015 | 2003 Saturn ION
My son has a1999 kodiak 4x4. He was jump starting another wheeler and sparked the positive to ground. Now it will turn over but not crank.. help?
If im hearing you right You can hear the starter trying to start but you the engine will no longer start..
If so check to see if anything to do with the starting and running is bad: Spark Plugs, Cap, Roater, some times there are a few parts to do with starting im not familiar with that machines engine but i had a part that attached after the battery that would go bad and im sure from crossing the power a part such as that inline with the positive connections has popped or fried. Check the fuse panel also if it has one. i hope this helps.
Mar 02, 2015 | Cars & Trucks
Why is my battery draining
Unhook the battery and have someone sit in the car while you touch the contacts to the battery. + pos. If something is stuck on, draining your battery, you should hear is pop on when you make the connection leading you to your problem. Or maybe its just a defective battery
Mar 28, 2012 | 2004 Suzuki XL-7
I had replaced the battery, first time they gave me the wrong battery. I got a new one but there was about 2 days where it did not have a battery in it at all. I out the correct one in there, all of the...
Was the pop heard when the battery was being removed or installed/........it may have been a fusible link that was blown, i would strongly suggest checking the fuses and fusible links in the engine comnpartment ebfroe checking anything else.,........
Dec 20, 2010 | 2005 Nissan Altima
How do you change battery on key fob lexus220
To take off the battery, first remove the key from the fob, you will see a little **** for the tip of the metal key to slip in (it's only 3mm deep or so). Twist the metal key and you should hear the fob pop. Once it's popped, you can separate the pieces and remove the battery.
New batteries are typically available at Radio Shack. Salesperson at same usually know how to open it.
Hope this helps.
Dec 16, 2010 | 2008 Lexus Is
My pantech reveal's speaker has suddenly stopped working. I cant hear anything when i receive or make calls. A headset icon popped up to the left of the battery icon during the same time the speaker...
it means you have the phone in headset mode so it is sending audio to headset not speaker ...should be able to turn it off in the phone settings
May 25, 2010 | Cell Phones
Lg tv has vice ut no pictures
No I did hear a pop or anything it just make sound but no picture
Dec 15, 2008 | LG 42LC2D 42 in. LCD HDTV
Car wont start unless i pop start it 1998 sw saturn manuel
The battery may not have been your problem it may be that the altenator is not keeping it charges allowing the battery to run down have it checked most auto parts stores will do it for free
Dec 01, 2008 | 1998 Saturn SL
No Power
if you need any other help please feel free to e-mail me at fixya@whypayforhelp.org
Jun 24, 2008 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
LG Vu CU920 Cellular Phone Logo
71 people viewed this question
Top LG Cell Phones Experts
Computer Repairing
Computer Repairing
Raphael Josiah
Are you a LG Cell Phone Expert? Answer questions, earn points and help others
