Question about HP Officejet Pro L7780 All-In-One InkJet Printer
2 issues- in Preferences under Printers, then drivers, both two sided and optional paper input tray items are checked. I still cannot print 2 sided. Unit says its not enabled. Try to print on legal size, prints on letter. Legal paper is in 2nd tray, and i manually went through control panel on printer to change all settings to use 2nd tray as default, paper size-legal etc. Had tons of problems with initial set up and tech support-needed firmware update. These things have never worked from the start.
  • 10,421 Answers
HOW TO TAKE BROTHER PRINTER OFF OF MANUAL FEED OPTION
Hi there!
The message that ask you to manually feed the paper will appear if you have recently printed on a different type of media.
Does this happen from only one application like Microsoft Word? If it does try printing a test page or a document from other application like Notepad or Wordpad.
If the same issue occurs go to the Printers folder (under control panel) then right click on your Brother printer icon, left click on Properties, click on Printing Preferences and make sure that Tray 1 is selected for the tray, Plain paper for paper type. If changes have been made make sure to click on the apply button to apply the changes.
If it only happens to one application like Microsoft Word. Click on File ( or the orb icon on the upper left hand corner) then Print, then Print again click on Printing Preferences and make sure Tray 1 is selected and Plain Paper.
Hope this helps! Thanks
Jun 09, 2011 | Brother MFC-7820N Laser Printer
How to print legal size paper?
Buy legal sized paper
Place paper in tray
Click print menu item (not button)
Select properties and change the paper size.
Continue through saying ok etc til it prints
Mar 02, 2011 | Lexmark C533DN InkJet Printer
How do i align head on printer
Hi Good day!! To Align read this
1. Raise the input tray, which you may fold over the top for compact storage. Lower the output tray at the bottom.
2. Slide the "paper-width guide" on the input tray to the left. This is the small, adjustable tab situated where you will place the stack of paper.
3. Load a small stack of paper into the input tray. Make sure short side is forward and the print side is up. For some paper, it makes no difference which side is up. Slide the stack down until it stops.
4. Slide the paper-width guide to the right, snug up against the stack of paper to ensure proper alignment.
Method 2:
1. click start
2. click printer and faxes
3. right click your installed printer and then properties
4. click printing preferences
5. click maintenance tab
there you should see alignment option click it
Thank you for using FixYa
Nov 19, 2010 | Canon PIXMA MP180 All-In-One InkJet...
How can i print both sides of paper on my magiccolor5550
IF you have the optional duplex unit installed on your printer then when you go to print something, your printer setup screen should have a duplex/2 sided printing box you can check. This will be under printing preferences or properties. If you do NOT have the optional duplex option then you have to manually duplex. That means on say a 2 page document that you want 10 copies of you have to print 10 copies of page 1. Then take those 10 copies and place them back into the paper tray and print 10 copies of page 2 onto the backs of page 1.
Those are you 2 choices for duplex printing.
Good Luck and Thank You for using Fixya.
Nov 17, 2010 | Konica Minolta Magicolor 5450 Printer
Printer selects tray1 as default tray. how can this be changed?
Tray 1 by default is set to any size, any type, which means that no matter what you print, it will pull from tray 1. You can change that by setting tray 1 for a specific size and type, such as 8.5" x 11"(Letter) and Plain paper, and then going into the print driver options (Control Panel, Printers & Faxes, right click on the HP 3550 and select Properties) and under the paper input tray, change it to either tray 2 or 3.
Jun 09, 2010 | HP Color Laserjet 3550 Printer
If I put paper into the tray that opens on the long side of the printer it does not print. only from the smaller paper tray on the rear of the machine
Check your printer driver in Printers & Faxes under "Preferences" and "Properties" for this printer. See if you have the small or manual feed tray specified aas default. You need to make the tray you want the default tray for the driver, or you will have to tell each print job to go to that tray before you press OK on print command dialog screen.
Apr 26, 2010 | Samsung CLP-510 Laser Printer
Dell 3100 CN printer...message on printer reads load tray
Cycle Power on the Printer
  1. Turn the printer off.
  2. Wait 10 seconds.
  3. Turn the printer on.
  4. Determine if the issue still occurs.
Verify There is Paper in the Tray
Verify the Paper Size
Look at the chart below to verify that the paper size meets the 3000cn / 3010cn / 3100cn-series specifications.
Verify the paper size in the tray matches the size set in the 3000cn / 3010cn / 3100cn-series printer´s operator panel.
To verify the paper size in the tray matches the size set in the printer's operator panel, perform the following steps:
  1. Press the MENU button.
  2. Press the down arrow until Tray Settings appears and press the return%20arrow%203100cn.jpg button.
  3. Press the down arrow until Paper Size appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or MPF) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper size, as shown in Figure 1, and press the return%20arrow%203100cn.jpg button.
  6. Press the MENU button.
*1 Denotes country-specific factory default values.
*2 Available for the optional 250-sheet cassette only.
Figure 1 - Paper Size Chart
Verify the Paper Type Matches the Type Set in the Printer´s Operator Panel
To verify the paper type matches the type set in the printer's operator panel, perform the following steps:
  3. Press the down arrow until Paper Type appears and press the return%20arrow%203100cn.jpg button.
  4. Press the down arrow until the specific paper tray (Tray 1, Tray 2, or Multipurpose Feeder) appears and press the return%20arrow%203100cn.jpg button.
  5. Press the down arrow to select the specific paper type, as shown in Table 1, and press the return%20arrow%203100cn.jpg button.
Table 1: Paper Type Chart
All media types that are not Plain 1 should be printed from the MPF only.
Verify the printing preferences on the Dell™ 3000cn / 3010cn / 3100cn / 5100cn-series printer.
To verify the printing preferences is set to print from the correct tray with the correct paper size, perform the following steps:
  1. Click the Start button, go to Settings, and click Printers and Faxes.
    The Printers and Faxes window appears.
  2. Right-click Dell Laser Printer 3000cn / 3010cn / 3100cn / 5100cn-series and click Printing Preferences.
    The Printing Preferences window appears.
  3. Verify the Paper Size drop-down is set to the correct paper size loaded in the specific tray to be printed from..
  4. Click the Paper Tray tab.
  5. Click the Paper Source drop-down menu and select the specific tray to be printed from.
    This sets the size and tray defaults.
Verify the Paper Size From the Printing Application Matches the Designated Printer Tray
To verify the paper size from the printing application matches the designated printer tray, perform the following steps:
  1. Open the application being used to print the document. (Example: Microsoft Word)
  2. Click File and click Print.
  3. Verify the paper size.
Verify the Paper Source From the Printing Application Matches the Designated Printer Tray
  3. Verify the paper source.
Do not replace any printer hardware as this is not a printer hardware issue.
Nov 12, 2008 | Dell 3100cn Laser Printer
Tray 1- load plain letter
Linda,
On printer check media/paper type tray 2 or 3 is plain and tray 2/3 is set for letter paper size too, via printer control panel. Also check under paper handling other options for tray 1, also on tray 2 and 3, I think there is a blue little round switch on left should be set as letter not custom.
Some paper types cannot be feed from anywhere else but tray1/bypass ie labels/laminate/card stock.
Check print driver on pc has tray 3 option installed and is not set as default to print to manual bypass/tray 1
light flashing cause printer wants paper type/size that it "thinks" it hasn't got in tray 2/3
If that dont cover it...post back
Soulvisitor :-)
Dec 18, 2007 | HP LaserJet 4100n Printer
Can't print envelopes
Solution Title: How to print on COM10 envelops from the Bypass tray (PCL6) using a Windows 2000 O/S Resolution/
Solution
thumbsup.gif Fixed! thumbsdn.gif Did not fix. Resolution Role: Fix
Critical Message: The Envelope must be placed in the Bypass Tray face down (flap side up) and Long Edge IN. In Microsoft Word (Word 2000)
    1. Under the Tools tab, select Envelopes and Labels.
    2. Enter your Delivery and Return addresses.
    3. Click on Options
    4. Under Envelope Options; [Envelope size], select Size 10 (41/8 x 91/2 in)
    5. Under Printing Options, select Portrait (LEF) - Long Edge Feed
        • As Feed from, select Tray 5 (Bypass)
    6. Click <OK>
Within the WorkCentre Pro 123/128 print driver
After opening up the print driver [<Start>, <Settings>, <Printers>, double-click on the WCP 128 PCL6 driver], click on Printing Preferences under the General tab.
  • Under the Paper/Output tab
Set the following features as follow:
    • Job Type: Normal Print
    • Paper Size: COM10
    • Output Size: Same as Paper Size
    • Image orientation: Portrait
    • Image Rotation: OFF
    • 2 sided Print: 1 sided Print
    • Stapling: None
    • Output destination: Center Output Tray
    • Offset Stacking: None
  • Under Tray/Layout
  • Set Paper Source to Tray 5 (Bypass)
  • Click on Bypass Tray Settings
    • Paper Type: Heavyweight (1 or 2)
    • Feed orientation: Portrait
  • Click <OK>
  • " on Specify Paper Type and select Heavyweight (1 or 2)
  • " (Apply> and <OK>
  • " <OK> again
In Microsoft Word under Envelopes and Labels, Click <Print> to send the information to the printer.
Note: This setup represents one way of printing envelopes. Other ways setting up some features in a different manner will work as well.
Solution v1.3.20.0 312637.How to Print on COM10 Envelops From the Bypass Tray (PCL6) 2006-04-05 21:57:29
Nov 02, 2007 | Xerox WorkCentre PRO 128 Copier
H.P laserjet 4100 series.
Printout a copy of your printer configuration. Press the right-side of the MENU button once, then the right-side of the ITEM button twice, and press the SELECT button once. This will print out a configuration page. In the lower right part of the information on this page, it will give you stats on the Paper Trays and Options. Standard settings on these should be "Default Paper Size: LETTER, Tray 2 (LETTER). If either of these says anything different, I would do a cold-reset on the printer to reset it to factory defaults. If you have a network card installed, you need to pull it out before doing this. To do a cold reset, turn the printer off, then hold down the GO button and turn the printer on. Wait about 5 seconds, then release the GO button. Also, you need to check your print setup on your PC. I am assuming you have a WindowsXP machine. Click START, SETTINGS, PRINTERS&FAXES. Right-click your printer icon and select PROPERTIES. Click the PRINTING PREFERENCES button at the bottom. Click the PAPER tab. Check the boxes at lower left. "Size is should be Letter", "Source is & Type is should both be Auto Select". Click OK, click OK, and exit the Printers Window. Lastly, I would make sure that you have Letter size selected from the application you are trying to print from. Hope this helps.
Feb 26, 2007 | HP LaserJet 4100n Printer
HP Officejet Pro L7780 All-In-One InkJet Printer Logo
91 people viewed this question
Seeker5211
Seeker5211
