Question about Alesis RA-150 Amplifier
Took my RA300 and Tannoy Reveal X speakers to a cellar party for halloween. No drinks were spilled or anything but it had an ipod plugged into it most of the night and the volume on the amp turned to max, which wasn't excessively loud due to the low output from the ipod. But I have got my equiptment home and back on my computer and the sound seems a lot duller than before.. I have a horrible feeling I have done something to my amp but what? Please help
    Problem Solver:
  • 6 Answers
Normally when people bring their HI-FI to a party they tend to fix up the leads to the speakers in a flimsy manner ( as it is only temp) . With the crowd mulling around these leads(wires) could very well come loose or even short out. This leads to your Final Drive ( Output Amp) to short out. It is not an expensive repair. Check your final amp & replace any shorted/blown items. To get full satisfaction the job best be handled by the local agents of the amp.
Posted on Nov 19, 2009
Recently lost both tweeters in my Reveal 6-D's.Got replacements and highs are back after an easy install.While testing the speakers I noticed a '' plop '' when the woofer travels extensively with heavier...
Hmm, what killed the tweeters? Over-exuberant operation? What's going on with your amp? Is it being pushed into stress or distortion? THAT will kill a speaker faster than clean high power.
Mar 11, 2011 | Tannoy Reveal 6D Speaker
My Tannoy Reveal 5A Powered Monitors are producing a low hum. This is the case when in on or in standby mode, and is the case whether plugged in to an audio cable or not. Could you please assist with some...
Hi,low hum from monitor speakers are usually when there is not shield connected to the cables your using for connections. Also it might be from the power light,if there is no earth or ground connected before connecting the power source in that room.
So you will need to check the cabling properly and check how the (sleeve, tip and ring) are connected and also check the power outlet,if the (red,black and yellow or white) are connected properly.
after checking those if they are OK,that means the fault will be from the speaker itself.\
Just do a proper troubleshooting.
Thanks for using fixya.....
Oct 25, 2010 | Tannoy Reveal 5A Speaker
Tannoy reveal speakers have lost treble
What you need to do is connect a 1.5 volt battery to the speaker(s) terminals for a split second. Put your ear to the tweeter at the same time (you might someone to help you do this). If the tweeter "pops" it works, if not you might have blown them. The best way would (to be certain) is to remove the tweeter from the crossover inside the unit.
Tweeters are the first thing to go when the speaker has been connected to an amp that is wrong for them or they have been run at high volume.
Apr 20, 2010 | Tannoy Reveal 6D Speaker
Tannoy Reveal 66D
One possibility is that the mute switches on your speakers have oxydized contacts INSIDE the switch - this kind of malfunction mostly occurs when the equipment is exposed to moisture and/or smog.
The most common solution is to change both switches, but they can also be disassembled and cleaned up (which is a bit more complicated and time consuming).
Another possibility is a dried up filter capacitor in the power supply or somewhere in the preamplifier section, possibly also a bad preamplifier chip but if your speakers work fine (with the exception of the mute switch noise), then the problem is more likely with the switches.
Also, check the internal connectors for any dirt, broken wires or desoldered pins.
Could also be something else, you should know i'm only assuming on the possibilities and i'm listing the most common problems i've encountered so far.
Regards
3rq8 (Triarcuate)
Jul 15, 2009 | Tannoy Reveal 6D Speaker
Pop and Hissing after turning on Tannoy 6D
It happens, don't be upset. Call Tannoy and get an RMA # . They will repair under warranty. When you get it back it will be as good as new. Rob
Feb 27, 2009 | Tannoy Reveal 6D Speaker
My Tannoy Reveal 6D Monitors are only outputting sound from the tweeters. I'm looking for troubleshooting suggestions.
I still suggest calling Tannoy, They are usually very reasonable and will give you a fair price to service a very good product
Dec 02, 2008 | Tannoy Reveal 6D Speaker
No Sound/drivers fine/possible board issue
Yes; sad to say, but your board probably will need replacing. Spilling drinks on your computers, esp laptops, isn't a good thing to do. I have never experienced spilling anything on my computers personally, but I know other people why have, and the motherboard is what they had to replace.
Sep 06, 2008 | Dell Inspiron E1505 Notebook
Alesis RA-150 Amplifier Logo
149 people viewed this question
Top Alesis Audio Players & Recorders Experts
 Grubhead
Grubhead
shaqsatin
Level 1 Expert
Ben Armstrong
Are you an Alesis Audio Player and Recorder Expert? Answer questions, earn points and help others
