Question about Sony Ericsson Cyber-shot C902 Cellular Phone
Managed to put memory card in sim hole - Sony Ericsson Cyber-shot C902 Cellular Phone
Where is/how do you remove the sim card and memory card?
on you Samsung Galaxy A3 smartphone, your SIM card and microSD card are both on the side of the phone where the power button is. They will be located closer towards the middle (microSD) and bottom of the phone (SIM).
you will need to use the pin hole tool or you can use a small paperclip or a pin to pop out the tray that holds them.
see the tutorial (silent) video for a visual how to explanation:
How to put sim card and memory card on Samsung Galaxy A3 A300F
Dec 01, 2015 | Samsung Galaxy A3 A300
How do I delete contacts from sim card
copy the contacts on the sim card to a sd card in the phone. If you don't have one, get one and put it in the phone. Set up the memory in the phone to both sim and memory card. Copy the contacts onto the memory card. Remove the memory card and then go about deleting the contact list in the phone. Put the memory card back in the phone and set the memory in the phone touse the memory card only...not the sim. You're done.
Feb 24, 2015 | Cell Phones
I have an LGL75C with new sim card and cannot switch apps from phone memory to sim card
Do you mean from internal memory to SD card?Some apps can not be moved to SD cards.Also if you replaced your sim card the apps are on the old card.You would have to backup your apps from the old sim card to the external SD card then re-install them.Some cell providers have online back up that you can use.Good luck.
Mar 13, 2013 | Cell Phones
Memory card put in sim card hole by mistake and can't get it out
Very tricky, without messing up the contacts inside the phone. Pull out the rechargable batteries before you attempt anything or you will fry the unit! Then you may be able to GENTLY grab and turn the memory card and get it out of the phone. There is no guarantee that the sim contacts in the phone won't be damaged, but the memory card will surely be trashed.
Dec 26, 2012 | Samsung S5830 Galaxy Ace White Unlocked...
How do i insert sim card into Apple I Phone
On the right hand side of your mobile about half way down you will see the sim card tray - you should've got a little metal tool with the phone when you had it to release this - if not, use the end of a paperclip and push it in the hole - the sim card try will pop out and you put the sim card in there and push the tray back in
May 08, 2012 | Apple iPhone 4S
How do i copy all my contacts to my sim card?
Go to your contacts management in your phone . Hope this helps!
Contacts Management
Menu 8.5
This menu allows you to copy all of the
information from your SIM card, e.g. name,
handset number, etc. to your handset. If
a name is duplicated during the copying
operation, the information is also duplicated.
You can copy the entry from the SIM card to
the phone memory. You can copy the entry
from the handset memory to the SIM card (not
all the data will be copied).
You can delete all entries in the SIM card
or the Handset. Press the [END] key to
return to standby mode.
Service
good luck!
Mar 25, 2010 | LG Neon GT365 Cell Phone
Where to insert sim card in iphone 3gs
At the top of the iPhone you will see a small hole. Use a paperclip to push in the hole and the sim card try will pop out.
Put your sim card in the tray and put back in the iPhone
Dec 25, 2009 | Apple iPhone Smartphone
Memory Card Not detected in My MOTOROKR E6
if i gave master reset.. it's asking for Security code. I don't have that code. How to set it.
Jun 30, 2009 | Motorola Mobility ROKR E6 Smartphone
Help!!!
Hi I got the same phone today.
I assume you are trying to install the SIM card as you stated and not the memory SD card as some are talking about.
My manual just shows a picture!
Take out the battery hold the phone with the bottom toward you look at the hole where the battery was.
On the bottom of the square there is a slot in the middle that the SIM card slides into.
THE NOTCH ON THE SIM IS TO THE BOTTOM LEFT CORNER.
Place the SIM card flat against the bottom of the hole where the battery was with the notch as stated and slide it down towards you into place. The SIM just about disappears into the bottom edge of the battery hole. Thats what my manual showed about inserting theSIM card.
Haven't inserted a SD card yet.Hope this helps.
Aug 05, 2008 | Motorola Mobility MOTOKRZR K1 Cellular...
Sony Ericsson Cyber-shot C902 Cellular Phone Logo
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Sandeep Shenoy
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
