Question about Gaggia Titanium Espresso Machine
Hi i have on the screen grinder blocked, i have clean it out and checked the grinder motor its ok. Switch it back on gone to make a drink but come back on the screen grinder blocked. Anybody got any idear as SGS (Saeco gaggia services) are not being very helpfull. Many thanks Oliver Adams
  • engineers244 Nov 20, 2009
    Hi check with multi meter then run it up by taking off the two small spade connectors and connected to an externail maims supply 240 v.
  • bansheracer May 11, 2010
    HI How do you know the grinder motor is OK?
  • Gaggia Expert
  • 109 Answers
When you said cleaned it out did you remove the grinder burr gears,vacum out the coffee shute and the coffee dump solenoid?
I do this then put it back together,set the grind on 7 and normally all is good.
Posted on Feb 22, 2010
No steam pressure help
see this causess and proceed .God bless you
If the grinder does not run when turned on, make sure power is on to the outlet, then check the electrical cord.
If the grinder runs intermittently or doesn't stop, the switch may be clogged or damaged. Unplug the grinder and brush any grounds from the switch with a fine brush. Depress the switch several times with a toothpick. If the problem persists, disassemble the grinder to clean it and inspect the switch for breaks that you can fix.
If the grinder does not run, the motor shaft may be frozen. Disassemble the grinder, clean the shaft and lubricate each bearing point with one or two drops of lightweight machine oil. Rotate the shaft to evenly distribute the oil.
coffeegrinder1_1.jpgMost coffee grinders are accessed by removing fasteners on the base of the device.If the grinder still does not operate, the thermal limiter may be burned out. If you can't readily find a replacement thermal limiter, it may be more cost effective to replace the grinder.
If the grinder vibrates, the blade may be bent. Inspect the blade and replace if it is damaged or dull. Another cause of vibration could be a worn motor bearing. Unplug the grinder and remove the access plate. The bearing is bad if the motor shaft moves when pushed back and forth; replace the grinder.
Sep 25, 2012 | Lello 45920 Ariete Cafe Roma Deluxe...
Krups grinder 223
what problem do you have?
Sep 25, 2012 | Krups Coffee Makers & Espresso Machines
Krups grinder mod 233
see this causes and proceed .God bless you
Ids77 electric coffee grinder I want replace fuse how can I open this prodact please.
see this causes and proceed:God bless you
Sep 25, 2012 | Coffee Makers & Espresso Machines
Does the gaggia titanium have a grinder sensor? Can anybody tell me where it is? I have the "grinder blocked" message. I've cleaned the grinder, Shute and doser door, but I still have the...
Hi...Grinder blocked message is ..when you make coffee there is no current going into the grinder. In other words the grinder motor is blown(coil windings in the motor is blown). You have to replace the motor. The problem is common with Gaggia, Talea, Odea coffee machines. hope your machine is less than 2 years old to get fix under warranty.
Apr 10, 2012 | Gaggia Titanium Espresso Machine
I've had my Mazzer Mini for about 3 years. I grind about 1/2 lb per week. Today I went to grind and when I turned the timer switch nothing happened. Yes it is plugged in. I think it makes a popping...
1 check the supply wire to swich change if it is not ok 2 chek the swich change if it is not ok 3 if it is automatic check microswiches(one where ground coffee comes out and other below doser) clean from coffee upper swich and try. it block sometime from ground coffee 4 check the windings of electromotor give grinder for if it is not ok 5 check condensator change if it is not ok 6 try to spin the burrs by hand, check if they are not blocked. change bearings if it is not ok
if you need to change bearings you need advice how to open the motor.
Jan 05, 2011 | Mazzer Mini Burr Coffee Grinder
Cleaned the Gaggia MDF grinder and now it won't start
  1. check the supply wire IF IT NEEDS CHANGING CHANGE IT
  2. check the switch IF IT NEEDS CHANGING CHANGE IT
  3. check the thermo fuse if it is built in ( if it is resettable than reset) if it is not resettable than just make one bridge from wire for testing( you will need to input resettable one if motor is ok)
  4. check the electro motor and bearings IF REWINDING IS NEEDED GO TO MOTOR REWINDING WORKSHOP (ASK FOR CHANGE OF BEARINGS TOO)
Dec 12, 2010 | Gaggia MDF Electric Burr Grinder
My Cuisinart grinder was working one minute and stopped the next. Stopped working, will not do anything. Could the motor have gone out?
Before I would assume it is the motor, I would double check the switch that will not let it run if the cup is not pushed in all the way...
make sure there are no bits of coffe in the way keeping the cup out just a bit. it needs to be seated perfectly for the grinder to run...
If all that checks out then probably either the motor or the switch has gone bad....
If that is the case you might better throw out this one and nuy a new one... there are selling for 20-30 bucks new...not worth spending much time on to fix...
heatman101
Oct 07, 2010 | Cuisinart DCG-12BC Electric Blades Grinder
Grinder blocked
One posible problem is the coffee shute. This is leading aslo to the passage where you put the grinded coffee and cleaning tablets. This might have be clocked from dry coffee mixed with humitity or steam. So you can use a bending brush similar to the one used to clean babes milk bottles and at the same time vacum with air vacum cleaner.
You can make perfect cleaning if you remove the top platic panel and visual check that everything are perfectly cleaned.
The last thing that is possible for the problem is weak ginder motor which have lost its power so it can grinds but not have the power to push the grinded coffee all the way through chute to the coffee group. In this case you will need new grinder motor.
Hope that this can help you, good luck.
Jun 04, 2010 | Saeco Royal Professional Espresso Machine
Incanto sirius states grinder blocked. Took apart
I own a Saeco Incanto Deluxe. It employs the ceramic grinder that has worked flawlessly for 3-4 years. One day it stopped and "Grinder Blocked" appeared. I removed the entire grinder unit, cleaned it thoroughly and calibrated the grinder. This did not fix the problem. After many similar attempts, I found the entire grinder assembly (motor, grinder etc.) online for $149.00. Install of the new assembly took me five minutes and it works perfectly. Please note that the ceramic grinding blades (there are two round ones that must be aligned corrrectly) cost $40 a piece (same site where I found the entire assembly for $149). My suggestion--save yourself the agony and replace the assembly if cleaning and calibration fails.
Jan 16, 2010 | Saeco 00034 Incanto Sirius Super Automatic...
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
472 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
