Question about HP vs15 15"LCD Flat Panel Monitor
When I get to the sign-in for Win XP, the picture shifts to right
When I get to the sign-in for Win XP, the picture shifts about 2'' to the right, so that there's a vertical black 2'' stripe on the left. Adjusting that in Nvidia panel helps improve that, but only partially, and the problem returns upon restarting the computer.
The monitor is HP LCD.
  • laptopdr Nov 19, 2009
    Before I go replacing caps in the monitor, I'd like to make sure that it's not some mode incompability. It works fine during start-up, until it comes to the Win XP sign-in. Which means that it stops working correctly when it switches into the 1048 x 768 resolution.
  • 643 Answers
Hello, and welcome to Fixya.!
Your isue sounds like it can be resolved by reloading the newest graphics card driver for your nvidia card.
Being that the monitor shows correctly before the windows xp login screen, that points to the issue not being with the monitor or any of its hardware, but with the software that loads up for it when windows starts to load ( hence the driver)
If you can reply with the name brand and model of your computer, i can choose the appropriate download to fix this issue for you..
I will be waiting for your reply!
Posted on Nov 19, 2009
  • HP Master
  • 5,138 Answers
Remove back to monitor look for any swollen capacitors if they are puffed up on top replace them most of the time they will be 1000uf 16v
Have Thinkcentre which boots in Win 7 and 2 Win XP
Try to re-install 2 Operating systems use this order,
1,Install windows XP by booting the XP cd,
2,and then install Win 7 by booting from Win 7 cd.
Then while you restart computer there will be a prompt menu asking to select OS to start. Thanks
Jul 25, 2010 | Lenovo ThinkCentre M57 Desktop - Intel...
Tip
Amazing shortcuts
Getting used to using your keyboard exclusively and leaving your mouse behind will make you much more efficient at performing any task on any Windows system. I use the following keyboard shortcuts every day:<br /><br />Windows key + R = Run menu<br /><br />This is usually followed by:<br />cmd = Command Prompt<br />iexplore + "web address" = Internet Explorer<br />compmgmt.msc = Computer Management<br />dhcpmgmt.msc = DHCP Management<br />dnsmgmt.msc = DNS Management<br />services.msc = Services<br />eventvwr = Event Viewer<br />dsa.msc = Active Directory Users and Computers<br />dssite.msc = Active Directory Sites and Services<br />Windows key + E = Explorer<br /><br />ALT + Tab = Switch between windows<br /><br />ALT, Space, X = Maximize window<br /><br />CTRL + Shift + Esc = Task Manager<br /><br />Windows key + Break = System properties<br /><br />Windows key + F = Search<br /><br />Windows key + D = Hide/Display all windows<br /><br />CTRL + C = copy<br /><br />CTRL + X = cut<br /><br />CTRL + V = paste<br /><br />Also don't forget about the "Right-click" key next to the right Windows key on your keyboard. Using the arrows and that key can get just about anything done once you've opened up any program.<br /><br /><br />Keyboard Shortcuts<br /><br />[Alt] and [Esc] Switch between running applications<br /><br />[Alt] and letter Select menu item by underlined letter<br /><br />[Ctrl] and [Esc] Open Program Menu<br /><br />[Ctrl] and [F4] Close active document or group windows (does not work with some applications)<br /><br />[Alt] and [F4] Quit active application or close current window<br /><br />[Alt] and [-] Open Control menu for active document<br /><br />Ctrl] Lft., Rt. arrow Move cursor forward or back one word<br /><br />Ctrl] Up, Down arrow Move cursor forward or back one paragraph<br /><br />[F1] Open Help for active application<br /><br />Windows+M Minimize all open windows<br /><br />Shift+Windows+M Undo minimize all open windows<br /><br />Windows+F1 Open Windows Help<br /><br />Windows+Tab Cycle through the Taskbar buttons<br /><br />Windows+Break Open the System Properties dialog box<br /><br /><br /><br />acessability shortcuts<br /><br />Right SHIFT for eight seconds........ Switch FilterKeys on and off.<br /><br />Left ALT +left SHIFT +PRINT SCREEN....... Switch High Contrast on and off.<br /><br />Left ALT +left SHIFT +NUM LOCK....... Switch MouseKeys on and off.<br /><br />SHIFT....... five times Switch StickyKeys on and off.<br /><br />NUM LOCK...... for five seconds Switch ToggleKeys on and off.<br /><br />explorer shortcuts<br /><br />END....... Display the bottom of the active window.<br /><br />HOME....... Display the top of the active window.<br /><br />NUM LOCK+ASTERISK....... on numeric keypad (*) Display all subfolders under the selected folder.<br /><br />NUM LOCK+PLUS SIGN....... on numeric keypad (+) Display the contents of the selected folder.<br /><br />NUM LOCK+MINUS SIGN....... on numeric keypad (-) Collapse the selected folder.<br /><br />LEFT ARROW...... Collapse current selection if it's expanded, or select parent folder.<br /><br />RIGHT ARROW....... Display current selection if it's collapsed, or select first subfolder.<br /><br /><br /><br /><br />Type the following commands in your Run Box (Windows Key + R) or Start Run<br /><br />devmgmt.msc = Device Manager<br />msinfo32 = System Information<br />cleanmgr = Disk Cleanup<br />ntbackup = Backup or Restore Wizard (Windows Backup Utility)<br />mmc = Microsoft Management Console<br />excel = Microsoft Excel (If Installed)<br />msaccess = Microsoft Access (If Installed)<br />powerpnt = Microsoft PowerPoint (If Installed)<br />winword = Microsoft Word (If Installed)<br />frontpg = Microsoft FrontPage (If Installed)<br />notepad = Notepad<br />wordpad = WordPad<br />calc = Calculator<br />msmsgs = Windows Messenger<br />mspaint = Microsoft Paint<br />wmplayer = Windows Media Player<br />rstrui = System Restore<br />netscp6 = Netscape 6.x<br />netscp = Netscape 7.x<br />netscape = Netscape 4.x<br />waol = America Online<br />control = Opens the Control Panel<br />control printers = Opens the Printers Dialog<br /><br /><br />internetbrowser<br /><br />type in u're adress "google", then press [Right CTRL] and [Enter]<br />add www. and .com to word and go to it<br /><br /><br />For Windows XP:<br /><br />Copy. CTRL+C<br />Cut. CTRL+X<br />Paste. CTRL+V<br />Undo. CTRL+Z<br />Delete. DELETE<br />Delete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETE<br />Copy selected item. CTRL while dragging an item<br />Create shortcut to selected item. CTRL+SHIFT while dragging an item<br />Rename selected item. F2<br />Move the insertion point to the beginning of the next word. CTRL+RIGHT ARROW<br />Move the insertion point to the beginning of the previous word. CTRL+LEFT ARROW<br />Move the insertion point to the beginning of the next paragraph. CTRL+DOWN ARROW<br />Move the insertion point to the beginning of the previous paragraph. CTRL+UP ARROW<br />Highlight a block of text. CTRL+SHIFT with any of the arrow keys<br />Select more than one item in a window or on the desktop, or select text within a document. SHIFT with any of the arrow keys<br />Select all. CTRL+A<br />Search for a file or folder. F3<br />View properties for the selected item. ALT+ENTER<br />Close the active item, or quit the active program. ALT+F4<br />Opens the shortcut menu for the active window. ALT+SPACEBAR<br />Close the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4<br />Switch between open items. ALT+TAB<br />Cycle through items in the order they were opened. ALT+ESC<br />Cycle through screen elements in a window or on the desktop. F6<br />Display the Address bar list in My Computer or Windows Explorer. F4<br />Display the shortcut menu for the selected item. SHIFT+F10<br />Display the System menu for the active window. ALT+SPACEBAR<br />Display the Start menu. CTRL+ESC<br />Display the corresponding menu. ALT+Underlined letter in a menu name<br />Carry out the corresponding command. Underlined letter in a command name on an open menu<br />Activate the menu bar in the active program. F10<br />Open the next menu to the right, or open a submenu. RIGHT ARROW<br />Open the next menu to the left, or close a submenu. LEFT ARROW<br />Refresh the active window. F5<br />View the folder one level up in My Computer or Windows Explorer. BACKSPACE<br />Cancel the current task. ESC<br />SHIFT when you insert a CD into the CD-ROM drive Prevent the CD from automatically playing.<br /><br />Use these keyboard shortcuts for dialog boxes:<br /><br />To Press<br />Move forward through tabs. CTRL+TAB<br />Move backward through tabs. CTRL+SHIFT+TAB<br />Move forward through options. TAB<br />Move backward through options. SHIFT+TAB<br />Carry out the corresponding command or select the corresponding option. ALT+Underlined letter<br />Carry out the command for the active option or button. ENTER<br />Select or clear the check box if the active option is a check box. SPACEBAR<br />Select a button if the active option is a group of option buttons. Arrow keys<br />Display Help. F1<br />Display the items in the active list. F4<br />Open a folder one level up if a folder is selected in the Save As or Open dialog box. BACKSPACE<br /><br />If you have a Microsoft Natural Keyboard, or any other compatible keyboard that includes the Windows logo key and the Application key , you can use these keyboard shortcuts:<br /><br /><br />Display or hide the Start menu. WIN Key<br />Display the System Properties dialog box. WIN Key+BREAK<br />Show the desktop. WIN Key+D<br />Minimize all windows. WIN Key+M<br />Restores minimized windows. WIN Key+Shift+M<br />Open My Computer. WIN Key+E<br />Search for a file or folder. WIN Key+F<br />Search for computers. CTRL+WIN Key+F<br />Display Windows Help. WIN Key+F1<br />Lock your computer if you are connected to a network domain, or switch users if you are not connected to a network domain. WIN Key+ L<br />Open the Run dialog box. WIN Key+R<br />Open Utility Manager. WIN Key+U<br /><br />accessibility keyboard shortcuts:<br /><br />Switch FilterKeys on and off. Right SHIFT for eight seconds<br />Switch High Contrast on and off. Left ALT+left SHIFT+PRINT SCREEN<br />Switch MouseKeys on and off. Left ALT +left SHIFT +NUM LOCK<br />Switch StickyKeys on and off. SHIFT five times<br />Switch ToggleKeys on and off. NUM LOCK for five seconds<br />Open Utility Manager. WIN Key+U<br /><br />shortcuts you can use with Windows Explorer:<br /><br /><br />Display the bottom of the active window. END<br />Display the top of the active window. HOME<br />Display all subfolders under the selected folder. NUM LOCK+ASTERISK on numeric keypad (*)<br />Display the contents of the selected folder. NUM LOCK+PLUS SIGN on numeric keypad (+)<br />Collapse the selected folder. NUM LOCK+MINUS SIGN on numeric keypad (-)<br />Collapse current selection if it's expanded, or select parent folder. LEFT ARROW<br />Display current selection if it's collapsed, or select first subfolder. RIGHT ARROW<br /><br />
on Jan 10, 2011 | Computers & Internet
Tip
Key-bord shorcut
· Shift + F10 right-clicks.
Win + L (XP Only): Locks keyboard.
Similar to LockWorkstation.
· Win + F or F3: Open Find dialog. (All Files) F3 may notwork in some applications which use F3 for their own find dialogs.
Win + Control + F: Open Find dialog. (Computers)
Win + U: Open Utility Manager.
Win + F1: Open Windows help.
Win + Pause: Open System Properties dialog.
· Win + Tab: Cycle through taskbar buttons.
Enter clicks,AppsKey or Shift + F10 right-clicks.
· Win + Shift + Tab: Cycle through taskbar buttons inreverse.
· Alt + Tab: Display CoolSwitch. More commonly known as theAltTab dialog.
Alt + Shift + Tab: Display CoolSwitch; go in reverse.
· Alt + Escape: Send active window to the bottom of thez-order.
· Alt + Shift + Escape: Activate the window at the bottomof the z-order.
· Alt + F4: Close active window; or, if all windows areclosed, open shutdown dialog.
Shift while a CD is loading: Bypass AutoPlay.
· Shift while login: Bypass startup folder. Only thoseapplications will be ignored which are in the startup folder, not those startedfrom the registry (MicrosoftWindowsCurrentVersionRun)
· Ctrl + Alt + Delete or Ctrl + Alt + NumpadDel (BothNumLock states): Invoke the Task Manager or NT Security dialog.
· Ctrl + Shift + Escape (2000/XP ) or (Ctrl + Alt +NumpadDot) : Invoke the task manager. On earlier OSes, acts like Ctrl + Escape.
· Printscreen: Copy screenshot of current screen toclipboard.
· Alt + Printscreen: Copy screenshot of current activewindow to clipboard.
Ctrl + Alt + Down Arrow: Invert screen. Untested on OSesother than XP. · Ctrl + Alt + Up Arrow: Undo inversion.
Win + B : Move focus to systray icons.
2.) Generic
· Ctrl + C or Ctrl + Insert: Copy.
Ctrl + X or Shift + Delete: Cut.
· Ctrl + V or Shift + Insert: Paste/Move.
· Ctrl + N: New... File, Tab, Entry, etc.
· Ctrl + S: Save.
Ctrl + O: Open...
· Ctrl + P: Print.
· Ctrl + Z: Undo.
· Ctrl + A: Select all.
· Ctrl + F: Find...
Ctrl+W : to close the current window
· Ctrl + F4: Close tab or child window.
F1: Open help.
· F11: Toggle full screen mode.
Alt or F10: Activate menu bar.
Alt + Space: Display system menu. Same as clicking theicon on the titlebar. · Escape: Remove focus from current control/menu, or closedialog box.
3.) Generic Navigation
Tab: Forward one item.
· Shift + Tab: Backward one item.
· Ctrl + Tab: Cycle through tabs/child windows.
Ctrl + Shift + Tab: Cycle backwards through tabs/childwindows.
· Enter: If a button's selected, click it, otherwise, clickdefault button.
· Space: Toggle items such as radio buttons or checkboxes.
Alt + (Letter): Activate item corresponding to (Letter).(Letter) is the underlined letter on the item's name.
Ctrl + Left: Move cursor to the beginning of previousword.
· Ctrl + Right: Move cursor to the beginning of next word.
Ctrl + Up: Move cursor to beginning of previousparagraph. This and all subsequent Up/Down hotkeys in this section have onlybeen known to work in RichEdit controls.
· Ctrl + Down: Move cursor to beginning of next paragraph.
Shift + Left: Highlight one character to the left.
· Shift + Right: Highlight one character to the right.
· Shift + Up: Highlight from current cursor position, toone line up.
· Shift + Down: Highlight from current cursor position, toone line down.
· Ctrl + Shift + Left: Highlight to beginning of previousword.
Ctrl + Shift + Right: Highlight to beginning of nextword.
Ctrl + Shift + Up: Highlight to beginning of previousparagraph.
Ctrl + Shift + Down: Highlight to beginning of nextparagraph.
Home: Move cursor to top of a scrollable control.
· End: Move cursor to bottom of a scrollable control.
on Oct 10, 2010 | Computers & Internet
@ sign not working, is there another key for this?
you can try ur onscreen keyboard for the @ sign.
you can find it in Accessories--->Ease of Access----------> OnScreen Keyboard
you can even type the following commands in RUN
in Windos Xp: type OSK
in windows Vista/win 7 in search box : type OSK
good day
May 29, 2010 | Dell Latitude D600 Notebook
I am getting a distorted sound from the speakers. i did not receive an installation CD, not sure if this is the problem
If you mean the xp/vista/win 7 installation cd's then you have to make your own. The manual that came with the pc will give you the information that you need. If it's xp it will be 1 dvd, vista needs 2 dvd's or 7 cd's, i'm not sure about win 7. As for the sound, what you could do is to drop the drivers for the sound card and reboot the pc, this will refresh the connection between hardware & software. To drop the drivers you need to go to start>>right click my computer>>properties>>hardware tab>>devise manager>>click on + sign next to "sound, video & game controllers & look for the sound card. Do not remove codecs, just the sound card then reboot.
Hope that works for you!!
Jul 27, 2009 | HP GM325AA#ABA 2 Speakers
Tip
Windows keyboard shortcuts
CTRL + C = copy
CTRL + X = cut
CTRL + V = paste
Keyboard Shortcuts
explorer shortcuts
notepad = Notepad
wordpad = WordPad
calc = Calculator
internetbrowser
For Windows XP:
Copy. CTRL+C
Cut. CTRL+X
Paste. CTRL+V
Undo. CTRL+Z
Delete. DELETE
Select all. CTRL+A
To Press
Display Help. F1
on Dec 24, 2009 | Computers & Internet
Tip
Windows XP Shortcuts
Copy. CTRL+CCut. CTRL+XPaste. CTRL+VUndo. CTRL+ZDelete. DELETEDelete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETECopy selected item. CTRL while dragging an itemCreate shortcut to selected item. CTRL+SHIFT while dragging an itemRename selected item. F2Move the insertion point to the beginning of the next word. CTRL+RIGHT ARROWMove the insertion point to the beginning of the previous word. CTRL+LEFT ARROWMove the insertion point to the beginning of the next paragraph. CTRL+DOWN ARROWMove the insertion point to the beginning of the previous paragraph. CTRL+UP ARROWHighlight a block of text. CTRL+SHIFT with any of the arrow keysSelect more than one item in a window or on the desktop, or select text within a document. SHIFT with any of the arrow keysSelect all. CTRL+ASearch for a file or folder. F3View properties for the selected item. ALT+ENTERClose the active item, or quit the active program. ALT+F4Opens the shortcut menu for the active window. ALT+SPACEBARClose the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4Switch between open items. ALT+TABCycle through items in the order they were opened. ALT+ESCCycle through screen elements in a window or on the desktop. F6Display the Address bar list in My Computer or Windows Explorer. F4Display the shortcut menu for the selected item. SHIFT+F10Display the System menu for the active window. ALT+SPACEBARDisplay the Start menu. CTRL+ESCDisplay the corresponding menu. ALT+Underlined letter in a menu nameCarry out the corresponding command. Underlined letter in a command name on an open menuActivate the menu bar in the active program. F10Open the next menu to the right, or open a submenu. RIGHT ARROWOpen the next menu to the left, or close a submenu. LEFT ARROWRefresh the active window. F5View the folder one level up in My Computer or Windows Explorer. BACKSPACECancel the current task. ESCSHIFT when you insert a CD into the CD-ROM drive Prevent the CD from automatically playing. Use these keyboard shortcuts for dialog boxes: To PressMove forward through tabs. CTRL+TABMove backward through tabs. CTRL+SHIFT+TABMove forward through options. TABMove backward through options. SHIFT+TABCarry out the corresponding command or select the corresponding option. ALT+Underlined letterCarry out the command for the active option or button. ENTERSelect or clear the check box if the active option is a check box. SPACEBARSelect a button if the active option is a group of option buttons. Arrow keysDisplay Help. F1Display the items in the active list. F4Open a folder one level up if a folder is selected in the Save As or Open dialog box. BACKSPACE If you have a Microsoft Natural Keyboard, or any other compatible keyboard that includes the Windows logo key and the Application key , you can use these keyboard shortcuts: Display or hide the Start menu. WIN KeyDisplay the System Properties dialog box. WIN Key+BREAKShow the desktop. WIN Key+DMinimize all windows. WIN Key+MRestores minimized windows. WIN Key+Shift+MOpen My Computer. WIN Key+ESearch for a file or folder. WIN Key+FSearch for computers. CTRL+WIN Key+FDisplay Windows Help. WIN Key+F1Lock your computer if you are connected to a network domain, or switch users if you are not connected to a network domain. WIN Key+ LOpen the Run dialog box. WIN Key+ROpen Utility Manager. WIN Key+U accessibility keyboard shortcuts: Switch FilterKeys on and off. Right SHIFT for eight secondsSwitch High Contrast on and off. Left ALT+left SHIFT+PRINT SCREENSwitch MouseKeys on and off. Left ALT +left SHIFT +NUM LOCKSwitch StickyKeys on and off. SHIFT five timesSwitch ToggleKeys on and off. NUM LOCK for five secondsOpen Utility Manager. WIN Key+U shortcuts you can use with Windows Explorer: Display the bottom of the active window. ENDDisplay the top of the active window. HOMEDisplay all subfolders under the selected folder. NUM LOCK+ASTERISK on numeric keypad (*)Display the contents of the selected folder. NUM LOCK+PLUS SIGN on numeric keypad (+)Collapse the selected folder. NUM LOCK+MINUS SIGN on numeric keypad (-)Collapse current selection if it's expanded, or select parent folder. LEFT ARROWDisplay current selection if it's collapsed, or select first subfolder. RIGHT ARROW
on Sep 11, 2007 | Microsoft Windows XP Professional With...
How do I ge my pictures from kodak easy share to my screen sver
Just save your pictures to "My Pictures" folder (windows xp) or "Pictures" folder (windows vista).
Then, right click on your desktop and go to Properties (win xp) or Personalize (win vista), then on Screen Saver, select "My picture slideshow" and you will have your pictures as your screensaver.
Nov 15, 2008 | Kodak EASYSHARE 5500 All-In-One InkJet...
Keyboard Shortcut for Windows
This is usually followed by: cmd = Command Prompt iexplore + "web address" = Internet Explorer compmgmt.msc = Computer Management dhcpmgmt.msc = DHCP Management dnsmgmt.msc = DNS Management services.msc = Services eventvwr = Event Viewer dsa.msc = Active Directory Users and Computers dssite.msc = Active Directory Sites and Services Windows key + E = Explorer
CTRL + C = copy
CTRL + X = cut
CTRL + V = paste
Keyboard Shortcuts
explorer shortcuts
devmgmt.msc = Device Manager msinfo32 = System Information cleanmgr = Disk Cleanup ntbackup = Backup or Restore Wizard (Windows Backup Utility) mmc = Microsoft Management Console excel = Microsoft Excel (If Installed) msaccess = Microsoft Access (If Installed) powerpnt = Microsoft PowerPoint (If Installed) winword = Microsoft Word (If Installed) frontpg = Microsoft FrontPage (If Installed) notepad = Notepad wordpad = WordPad calc = Calculator msmsgs = Windows Messenger mspaint = Microsoft Paint wmplayer = Windows Media Player rstrui = System Restore netscp6 = Netscape 6.x netscp = Netscape 7.x netscape = Netscape 4.x waol = America Online control = Opens the Control Panel control printers = Opens the Printers Dialog
internetbrowser
type in u're adress "google", then press [Right CTRL] and [Enter] add www. and .com to word and go to it
For Windows XP:
Copy. CTRL+C Cut. CTRL+X Paste. CTRL+V Undo. CTRL+Z Delete. DELETE Delete selected item permanently without placing the item in the Recycle Bin. SHIFT+DELETE Copy selected item. CTRL while dragging an item Create shortcut to selected item. CTRL+SHIFT while dragging an item Rename selected item. F2 Move the insertion point to the beginning of the next word. CTRL+RIGHT ARROW Move the insertion point to the beginning of the previous word. CTRL+LEFT ARROW Move the insertion point to the beginning of the next paragraph. CTRL+DOWN ARROW Move the insertion point to the beginning of the previous paragraph. CTRL+UP ARROW Highlight a block of text. CTRL+SHIFT with any of the arrow keys Select more than one item in a window or on the desktop, or select text within a document. SHIFT with any of the arrow keys Select all. CTRL+A Search for a file or folder. F3 View properties for the selected item. ALT+ENTER Close the active item, or quit the active program. ALT+F4 Opens the shortcut menu for the active window. ALT+SPACEBAR Close the active document in programs that allow you to have multiple documents open simultaneously. CTRL+F4 Switch between open items. ALT+TAB Cycle through items in the order they were opened. ALT+ESC Cycle through screen elements in a window or on the desktop. F6 Display the Address bar list in My Computer or Windows Explorer. F4 Display the shortcut menu for the selected item. SHIFT+F10 Display the System menu for the active window. ALT+SPACEBAR Display the Start menu. CTRL+ESC Display the corresponding menu. ALT+Underlined letter in a menu name Carry out the corresponding command. Underlined letter in a command name on an open menu Activate the menu bar in the active program. F10 Open the next menu to the right, or open a submenu. RIGHT ARROW Open the next menu to the left, or close a submenu. LEFT ARROW Refresh the active window. F5 View the folder one level up in My Computer or Windows Explorer. BACKSPACE Cancel the current task. ESC SHIFT when you insert a CD into the CD-ROM drive Prevent the CD from automatically playing.
To Press Move forward through tabs. CTRL+TAB Move backward through tabs. CTRL+SHIFT+TAB Move forward through options. TAB Move backward through options. SHIFT+TAB Carry out the corresponding command or select the corresponding option. ALT+Underlined letter Carry out the command for the active option or button. ENTER Select or clear the check box if the active option is a check box. SPACEBAR Select a button if the active option is a group of option buttons. Arrow keys Display Help. F1 Display the items in the active list. F4 Open a folder one level up if a folder is selected in the Save As or Open dialog box. BACKSPACE
Display or hide the Start menu. WIN Key Display the System Properties dialog box. WIN Key+BREAK Show the desktop. WIN Key+D Minimize all windows. WIN Key+M Restores minimized windows. WIN Key+Shift+M Open My Computer. WIN Key+E Search for a file or folder. WIN Key+F Search for computers. CTRL+WIN Key+F Display Windows Help. WIN Key+F1 Lock your computer if you are connected to a network domain, or switch users if you are not connected to a network domain. WIN Key+ L Open the Run dialog box. WIN Key+R Open Utility Manager. WIN Key+U
Oct 19, 2008 | Computers & Internet
Install win xp and erase win vista
Would like too know how to erase win vista and install win xp
Dec 29, 2007 | Microsoft Windows XP Professional With...
HP vs15 15"LCD Flat Panel Monitor Logo
18 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
