Question about Ibanez Grg170dxbkn Electric Guitar Hsh Night
Ibanez suddenly quit sending signal to the amp
My son has an Ibanez and it suddenly quit sending a signal through the amp. The amp works and we switched out every cable. Any suggestions as to what the problem may be and how hard it is to fix?
  • 3,153 Answers
First off make sure it hasnt had a KILL switch installed and that its not in kill position.
These models have suffered some wiring issues in the past and your may be one of those.
If you feel comfortable with a soldering iron then here is the wiring diagram
If not a local music shop will check it out for you and suggest any repairs.
Posted on Nov 19, 2009
Ibanez 5 string bass guitar serial no A 05022695 on underside of neck what is the value
The guitar was made at the Saein Plant, Korea in February, 2005.
Depending on the exact model number and condition, it would sell for approx US$600-900. They are quite well regarded.
Oct 28, 2017 | Ibanez Music
Ibanez IBZ10G Electric Guitar Amplifier quit working after 6 years of non-use. Only used it a couple of times. Any ideas what might be wrong?
Not without having it on the work bench in frony of me, but to be honest, I'd dispose of it and buy a different amp. The cost of repairing it would not be worth it.
Aug 05, 2017 | Ibanez Music
Well I've bought the new Ibanez AF-2, and when I plugged into the FX Loop of my Peavey 5150 combo and tested the TakeOff mode, my amp for a bit don't blast my head off and destroyed the...
You put the pedal where???? The guitar goes through the pedal. This is NOT to be used in an external effects loop of an amp. The signal levels are wrong as the effects loop is LINE LEVEL and the pedal is for instrument signal levels. Move the pedal to before the inout of your amp as it is designed to be used.
Jul 19, 2011 | Ibanez AF2 Paul Gilbert Signature Airplane...
Well, my Ibanez TBX150R Tone Blaster Xtreme Guitar Combo Amp worked fine for the longest time, and suddenly after a show, every time I turned it on the "hot" channel it popped and banged every...
Sounds like a problem with the channel itself, if the clean channel works then its not the lead, input, guitar or the drivers. You have to be careful when opening up amps as some can hold a residual charge and there can be danger of electrocution.
I would recommend getting it looked at by a pro, it doesn't sound like an expensive fix.
Jun 30, 2011 | Ibanez Tbx150h Tone Blaster Xtreme Guitar...
I have an Ibanez TSA15H amp that keeps blowing the F6 fuse. the fuse is a 500mA, but Ibanez told me to change it to a 100mA fuse and that would solve the problem. i did this, and it still blows. also...
This appears to be a common problem with this amp. Putting a smaller fuse will only cause it to blow easier...not sure what Ibanez techs were thinking. Mine blows with 500mA fuse...usually because failing to let it warm up the 30 seconds with standby switch off. I have used .75A-250V fuse and it eliminates the problem. Note: it also defeats the purpose of the fuse and leaves the circuit unprotected....voids warranty/fire risk/ shock risk/world will end, etc. I don't recommend using higher rated fuses but it appears that portion of the circuit draws more than the 1/2 amp fuse can handle.
Jun 29, 2011 | Ibanez Tube Screamer Series TSA15H Head...
Hi, My Ibanez AEL 20 has a preamp - tuner 5AEQ45F. Tuner works but there is no signal in output jack. Guitar is quite new, and the preamp hasn't been used before. Can I get a PCB schematic diagram...
Remember that while in tuner mode, the audio output is disabled. Try additional presses of the tuner button to see if the audio comes back on. Also verify the volume and EQ gains are turned up. Verify the battery is new.
May 30, 2011 | Ibanez Ael20e AcousticElectric Guitar with...
Ibanez Grg170dxbkn Electric Guitar Hsh Night Logo
233 people viewed this question
Top Ibanez Music Experts
Michial Gueffroy
Wayne Tolonen
cwradio73
Are you an Ibanez Music Expert? Answer questions, earn points and help others
