Question about Bosch 18 in. SRS55L02 Logixx Slim-Line Free-standing Dishwasher
HI dishwasher will not drain if i remove all the water will run thro cycle and stops with a couple of cms of water left have tryed to find filter inside and failed, removed sides and can see a pump on right hand side can turn impeller easily, is this the drain pump? if not how do i get at pump and or filter. is it possible that plastic chamber on left hand side could be blocked assume this transfers heat Robert
BIKER T
  • 909 Answers
SOURCE: Pump won't stop draining
you will almost certainly have a build up of water in the base. remove the water and retry. check to see if limit switch is not sticking or has possibly gone faulty.failing this, your board is faulty.
Posted on Oct 08, 2007
IB4G2008
  • 3587 Answers
SOURCE: Bosch SHU9915 Does Not Drain
faulty controls..the signals are apparently getting there, but the machine is intepreting them oddly..may need a new control board behind panel
Posted on Mar 09, 2008
aborcass
  • 2651 Answers
SOURCE: Bosch Dishwasher Not Draining
Im really not all that familiar with the bosch unit, but a few things i would ck. when you cancel a cycle (it should drain the water) is it humming??? does it sound as if it even trickling into the sink discharge?? do you have a disposer under your sink that this unit drains into, if so remove the clamp and look for possible obstructions right there.Honestly passed this ill have to defer to someone else sorry and good luck
Posted on Mar 10, 2008
  • 3 Answers
SOURCE: SKT5102/gb1 - not pumping out
I had a problem that seems to be related, but it came out that the pump was blocked. I had service to open and remove a small plastic clip that had came into the machine accidently. I do not recognize that water was pumped back as you explain but if the water is not emptied may be this is the result...
Posted on Jan 02, 2009
rylee_smith
  • 8619 Answers
SOURCE: Bosch dishwasher has water in bottom after cycle is complete
Hi
Kindly check for the following :
Check for hose kinks or food plugging drain hose. Start at the drain port exit.
Check the check valve and drain hose for debris.
Check pump motor for reversing during the pump out make sure the dishwasher is pausing between the wash and drain cycles letting the pump/motor reverse for the drain cycle.
Check pump motor assembly for a drain solenoid, during the pump out make sure the solenoid makes that distinctive "clunk" noise
If you have recently installed a new garbage disposal, check knock-out plug at connection.
Check pump impeller for damage.
Check that the water inlet valve isn't seeping fresh water into the dishwasher when off.
Please contact for any further clarifications.
A Fixya Rating would be appreciated if.
Thanks
Rylee
Posted on Feb 13, 2009
Bosch Dishwasher won't drain.
Is there a hi-loop in the drain line, is water siphoning back in after a drain cycle?
Jul 08, 2016 | Bosch Dishwashers
Water is left when cycle is finished
Hi
Dishwasher not draining issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. Check the drain hose for any visible clogging, remove if present. If no visible lint is present then remove then turn off the dishwasher and remove the drain hose and check for any visible clogging. If still not visible then the drain filter or drain pump is clogged and you'll need to clean the drain filter and drain pump. Also, check for any food pieces stuck near the pump impeller.
Please note that dishwashers don't drain out the complete water such that heating element doesn't overheat.
Hope this helps... Please post back for any further assistance.
Daniel
Mar 26, 2011 | Bosch Dishwashers
Kenmore 17379 dishes are not clean after running a cycle
Hi
If you are noticing that the dishes are not clean, then there are a few things to check for. Check the soap powder if it's kept in a dry environment. Also try replacing the powder with something like a gel or liquid. Next thing to check for is the water pressure and fill valve. Check if the water is filling in and the spray arms are throwing the water with enough pressure. Try and listen to the sound if you hear a proper spraying action sound. If it seems as a low water pressure then check the fill valve.
Now, check if dishwasher is draining the water or not. While the dishwasher is working check whether the dishwasher is draining and there is not much left out water after the cycle is complete.
Jan 31, 2011 | Kenmore 24 in. 17372 / 17374 / 17379...
Upper tray doesn't clean, lower tray is fine. Also, lot of soap sticks in the soap compartment after the cycle. Thanx.
Hi
Jan 31, 2011 | Whirlpool 24 in. GU2500 XTP Built-in...
The water will not drain from the dish washer and there does not seem to be anything blocking the drain. I ran it through another cycle and now it is leaking water slowly. Is there anyway to drain this...
I would suggest removing and cleaning the filter sometimes debree and build up of small particals can stop it from draining. Clean the filter in hot soapy water and then replace it in the dishwasher and run the dishwasher through a cycle, this worked for me.
Jan 25, 2011 | GE Nautilus 24" Built-in Dishwasher
Our dishwasher is retaining water in the base and not cleaning our dishes fully what is the problem?
Hi
The water temperature plays a major role in cleaning of dishes. The temp should be between 125 and 150 F for dishwasher to clean the dishes.
Hope this helps...
Daniel
Aug 15, 2010 | Frigidaire Gallery FGBD2451KB Full Console...
DW5700P1 dishwasher must have stopped running last
A lot depends on at what point the dishwasher stopped working.
Have you tried to turn the mains power off and on again and then try one of the short cycles.
I would suggest if water is not draining, then empty with a small pan and check filter for blockages. Also good idea to check there is no blockage on the drain side.
A good site to check is
http://www.partselect.com/dishwasher+water-wont-drain+repair.htm
Please post a comment to let me know what you find.
May 29, 2010 | Frigidaire Dishwashers
you need to remove the drain pump motor and see what is obstructing the impellar.(small shreds of glass:small popcorn pieces etc. Doesnt take much to stop the drain pump.Try and get to drain pump from the front. Miele very compact.
May 28, 2010 | Miele Incognito G818SCVi Built-in...
Miele G 7856 Commercial Dishwasher
Hi. The above machine stops mid cycle and drain/fill light is on, also error code F3E, have cleaned both hot and cold water inlet filters, also checked drain pump and drain line, all ok. Machine drains with no issues and fills with hot water, runs for a while then shuts down.
Any ideas?
Aug 20, 2008 | Miele 24 in. G638 Plus Free-standing...
Bosch 18 in. SRS55L02 Logixx Slim-Line Free-standing Dishwasher Logo
55 people viewed this question
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
