Question about Canon PIXMA iP6700D InkJet Photo Printer
Error code 5100 is being displayed on the screen
    President:
  • 787 Answers
Error 5100 is Carriage error.Possible problems in:
- Carriage unit
- Timing **** strip film
- Logic board assembly
- Carriage motor
First, make sure there is no paper jam anywhere in the machine.. look inside, rear, where the paper tray (output) is, etc to see if you find any shreds or torn paper that may have gotten stuck and you didn't see.Look carefully in the zone of Purge unit, using flashlight in the right side on printer.If this not help your printer need service.
Posted on Nov 19, 2009
Testimonial: "Brilliant problem solved in a few seconds. Many thanks."
There's an error 5100 appear on my printer canon mp770. I need some help,please.
Problem You are unable to print and receive the message Error 5100 on the computer or printer display screen.
Cause Error 5100 is a carriage error that can usually be fixed by using service mode and flushing the printer heads when it has a blockage.
Solution Try the following:
If this doesn't work then the printer may need repair.
Canon Printer Error 5100
Oct 19, 2012 | Canon LASER SHOT LBP-2900 Printer
Display marks error 5100 Error code. It does not
Hello there Try
Solution 1:
Clean the timing strip.
Solution 2:
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) may be not lubricated well enough .
Lubricate the sliders with some white grease (don't get it on the small wipers or the black caps); this repair probably require to remove the right panel off of the printer to gain access to the purge mechanism.
All Best: Pineworks
Jan 15, 2010 | Canon PIXMA iP6220D InkJet Photo Printer
Laptop with blank screen
Standard Original IBM POST Error Codes 1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
so it sounds like your video card is having trouble
Jun 26, 2009 | Acer Aspire 5100 Notebook
Error code 5100
5100 means either there is paper stopping the carriage from moving properly, or there is grease on the plastic strip behind the carriage. If you wipe off the grease with a Q-tip the error will go away.
Jun 24, 2009 | Canon PIXMA MX700 All-In-One InkJet...
Ip4200 error code 5100
The purge cap (the white sliding mechanism that the print head parks to when it's not in use) sometimes is not lubricated well enough from the factory.
If you lubricate the sliders with some white grease (don't get it on the small wipers or the black caps) the mechanism can now slide more freely, and the unit can park the head properly without giving you the dreaded head homing error 5100 (or E-2-2 on the LCD display)
Keep in mind that this repair will probably require you to remove the right panel off of the printer to gain access to the purge mechanism. There are two screws behind the printer, and two in front for each corrosponding side panel (the front screws are behind the grey front panel of the printer - open the top cover to see the clips which hold the front cover on)
Mar 08, 2009 | Canon PIXMA iP3000 InkJet Photo Printer
Error message on Canon MP160 flashing E-2-2 error message 5100
The error code refers to Ink Cartridge
Issue: ERROR: Error code 5100 appears on the computer screen
Issue: ERROR LED: E, 2, 2
1. Disconnect and reconnect power cord to reset the device
2. Remove Packing Material MP160 / MP180 / MP460
3. Reseat ink cartridge (MP160 / MP180 / MP460)
Nov 15, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Error code 5100 - can't clear it
Lift up below the display screen.The printer top will raise up and a arm will lock into place.Make sure the ink cartriages are firmly in place,snaped into position,sitting flat.Lift arm out of the way and close the lid.Worked for me ,good luck.
Oct 07, 2008 | Canon PIXMA MP460 All-In-One InkJet...
Canon PIXMA MP450 "Servic Error 5100"
Try this... it worked on my MP450... Turn the printer on and open the lid, it shows the cartridges. Now let the cartridges settle to the left. You can notice that the cartridges run on a metal belt. It might be dirty, mine showed a black stripe on it. Take a cloth, a cleenex will be fine and clean it up. Move the cartridges to the right (force them with your hand) and clean the part of the belt left behind them. Now turn it off, close it up and turn it back on. It should work
Apr 02, 2008 | Canon Pixma MP450 All-In-One InkJet...
Error code 5100 shows onscreen and there are no comments in guidebook
move ink tank to right and turn of then turn on, found in another canon printer fix it.
Jan 28, 2008 | Canon PIXMA MX700 All-In-One InkJet...
Canon PIXMA  iP6700D InkJet Photo Printer Logo
257 people viewed this question
old marine
old marine
