Question about Husqvarna 22 Hp 46" Deck Yard Tractor
MOWER STALLS WHEN CUTTING BLADES ENGAGED, STARTS RUNNING OKAY, AFTER A WHILE ACTS UP, AND SOMETIMES GOES BACK TO NORMAL
  • 7 Answers
SOURCE: deck repair
It goes on top of the littlie flat idler on the right side,
the right and left side is by sitting on unit.
You will see a little hole in the top of the bolt a little pin goes in there and holds it in place.
Posted on Sep 05, 2008
joboo1
  • 257 Answers
SOURCE: Craftsman 18.5 riding mower when I engage the
Hi Jeff, If you look at the deck, one or more of those pulleys is a tensioner, It pushes against the belt to tighten it, The rest of the pulleys can be identified by the fact that they only have a bolt through the middle, whereas the tensioner is mounted on an adjustable arm with a slot to allow adjustment. It should also be the only one that the belt doesn't go around the pully it just pushes on one side.If the tensioner arm is all the way to the end of the slot, the belt is streched and will need replaced but sounds like it may have come loose. Some of these decks also have a spring on the tensioner arm and those come off from a stick or other debris. Check it out and if you have a problem let me know and I will try to come up with a diagram. If your mower is that new there should be a belt diagram on the deck. i will need a model number of the deck or mower for that. Good luck!
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Mar 29, 2009
  • 33 Answers
SOURCE: motor stops when the pto or cutting blades are turned on or engaged.
you most likely have a bad safety switch. there is one under your seat,one on engagement lever for blades,and probably one or two more in other places.start with the one under your seat by unplugging it and then going ahead with normale start up and implement engagement. you will have found the bad switch when everything works as it should.replace switch if you feel its necessary or just leave unplugged. it will not affect performance or longevity of the tractor
Posted on May 02, 2009
  • 81 Answers
SOURCE: Mower wants to stall when blades are engaged
Usually when the motor stalls when blades are engaged on any mower it is the carb that needs cleaned and rebuilt. The motor isn't getting enough gas to handle the load.
Posted on Jun 23, 2009
  • 115 Answers
SOURCE: mower keeps cutting off
my brother had the same problem with same mower. he took it to service station new plugs etc. still did it he took his back maybe problem with the magneto/ coil since you only have 12 hours on it, take it back and get a different make ie john deere or cub cadet husqvarna riders are junk!!!!!
Posted on Jul 07, 2009
My toro lx 420 wants to stall when engaging the blade sometimes..also when I push on the reverse, it acts like to wants to stall as well...any easy troubleshooting ideas? runs fine when not engaged
Try rolling when you engage instead of in the still position may be too much on the motor, either that the belt is loose or needs to be replace. Or u need a carb adjustment at the idle.
May 02, 2016 | Toro Riding Mower LX Series 22 HP Kohler...
Starts fine, drives fine. When I engage cutting blades, it immediately stalls.
If in all other respects the mower is running like expected then it is most likely the switch under the operators seat that will not allow the blades to engage when no one is sitting in the seat. If the operator is under weight or the switch defective the unit will shut off!!
Apr 11, 2016 | Garden
Stalls When engaging the blade clutch
Check that the blade brake is disengaging. Slip belt off blade spindles and check that they spin freely. Check underside of deck for clogged grass, ropes, wire, etc.
May 07, 2012 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Mower cranks and runs smooth until i try to engage blades or put mower in gear. it then stalls out
The seat switch is not making. You can start the mower but if you try to move it or cut, the switch is acting as if there is no operator present. Find it under the seat.
Gary
Sep 16, 2011 | Craftsman 18.5 HP 42"
Kubota t1670 stalls when grass cutting
Is the tractor running fine until you engage the blades? Are you cutting tall grass? There are a couple of reason why it stalls. First, while the engine is OFF, you need to see if the blades move freely, you need to lay down beside the deck and reach up (with a glove on, so you won't cut yourself) and see just what is up under there. Remove any debris, I.E. old grass clippings, and anything else.(see if there is anything wrapped around the column where the blades meet the rest of the deck) Then you will have to grab one of the blades and see if it moves freely. Wiggle it back and forth and find out if all 3 move freely. Sometimes a bearing will go bad in one of the blade mounts and cause the engine to stall. Sometimes the electric clutch goes bad and then you have a whole new set of problems. Either way let me know what is going on. Please rate my answer.
Sep 04, 2009 | Garden
Mower stalls out after about an hour of run time
A few possibilities
1. If engine runs hotter than normal it can eventually heat up the carburetor to the point that there is a vapor lock. Blockage caused by gas bubble: a bubble of vaporized gasoline that blocks the normal flow of fuel. Problem goes away when things cool down. If that is the problem, you need to solve overheating problem. Since you have changed the oil, might be something blocking airflow to the flywheel which has the cooling blades on it. Or cooling blades are filled with debris. Make sure vent hole in gas cap is not blocked
2. Could be bad coil, or condenser causing the windings to act up when they are hot and have expanded they short out (kill engine) on their own casing. After they coil and shrink, they un-short themselves.
May 14, 2009 | Garden
Stalls when engage blades in forward, but cuts fine in reverse
Did you try to disengage the safety feature that should shut the tractor off when the blades are engaged and the tractor is placed in reverse? I believe that it is located under the shift leaver
May 14, 2009 | Mtd Garden
Husqvarna 22 Hp 46" Deck Yard Tractor Logo
161 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
