Question about Motorola Mobility RAZR V3
Twice that i bought V3 battery, same problem that i encountered...it usually easy to low battery...what's the cause of it?
New Husqvarna riding mower only used twice now won't start. 1st 2 times working fine, now it only clicks when i try to start
CLicking is usually a sign of low battery voltage. When the solenoid clicks on , the starter is added to the battery load. The voltage drops to below what will hold the solenoid and it disconnects the starter. No starter in the circuit raises the voltage enough to click on the solenoid and the cycle repeats. If you have a red jumper cable, jump the battery positive (+) to the big bolt on the side of the starter motor with a heavy duty red wire on it.
If the engine does not turn over, you have a battery isue.
May 13, 2015 | Husqvarna Garden
New batteries fitted but low battery flashing and wont switch on in K100D
Try cleaning the battery contacts in the camera with a cotton swab lightly moistened with rubbing alcohol.
Nov 17, 2009 | Pentax K100D Digital Camera
'04 Mazda3 had very low engine speed during idling
I have encountered this problem also, try changing your battery. My battery lasted almost 4 year till it was the cause the shot my alternator.
Dec 10, 2008 | 2004 Mazda 3
BR50 battery
The "gold thing" isn't used. Mine is uncovered.
You need to buy a battery from a company that sells a lot of them. This way their inventory is rotated regularly. Or buy one locally that you can return if it's bad.
Your original "should" have lasted longer than 9 months. Are you using the phone more now than before? Are you in weak signal areas now compared to before. Weak signal cause the phone to output more power, thus using more battery power.
You can also buy Extended Life batteries, but make sure you get a battery cover with it that matches your phone.
Hope that helps...
Geno
Apr 21, 2008 | Motorola Mobility RAZR V3m Cellular Phone
Motorola razr v3 keypad....!!!
This is usually caused by one button being stuck down, and the volume control buttons on the left of the main display, and the voice button on the right of the main display are the usual culprits. Try squeezing them and making sure they move normally. Then power down the phone, pop out the battery, and give it another shot.
Dec 15, 2007 | Motorola Mobility RAZR V3
RZAR v3 battery issue
Hi
try using until the battery is dead, then recharge for 24 hrs. let me know if it working so we can do other method
Nov 20, 2007 | Motorola Mobility RAZR V3
Phone is dead wont take charge
You simply need a new battery. Razr batteries are notorious for loosing life and the entire problem is the chargers you are using. You MUST have one with an IC chip that tells it when to stop charging otherwise watch how long you are charging it. Also when you have a new battery let it fully charge and fully die twice before you start normal charging this helps a lot.
Feb 24, 2007 | Motorola Mobility RAZR V3
Motorola Mobility RAZR V3 Logo
Top Motorola Mobility Cell Phones Experts
D. E. Hev
Richard Lane
Vernon Taylor
Are you a Motorola Mobility Cell Phone Expert? Answer questions, earn points and help others
