Question about Sony Playstation 3 (PS3) Console
Flashing red light
Unit switches on and then switches off immediately. Red light flashes continuosly
SOURCE: red flashing light, won't power on
Try turning the power off at the back and leave it unplugged for 10 minutes.
How long has it been running for without being turned off to cool down?
Posted on Feb 04, 2009
  • 85 Answers
SOURCE: red light flashing/won't turn on
you are right about replacing the thermal compound between the cpu/gpu and heat sync. the gpu and cpu may need to be refolowed also. another tip is dont over tighten the screws. Tip: keep your ps3 flat do not keep it standing. when it is standing and heats up the thermal compound can start to move away from the heat sync. Keeping it flat will help extend the life PS3 at least from the overheating issue.
Posted on May 18, 2009
  • 34 Answers
SOURCE: PS3 shuts down after one second
hi , i hate to say this but you need to do this asap. Call the playstation support line and send it in. your ps3 is experience a corrupted hard drive. This will only get worse and will eventually shut down for good.
Posted on Jun 23, 2009
  • 40 Answers
SOURCE: ps3 turns off straight away and flashes red
it sounds like you have a short in the system. take it to a repair plase. don't try to service it your self it will disable it self if you take off the cover.
Posted on Jul 31, 2009
  • 370 Answers
SOURCE: Flashing red light. Console fails to turn on.
Follow all 6 videos and your PS3 will work again. and it wont cost you $150 with sonys Refurbish program
Posted on Jul 25, 2010
I have an old Carrier N1340 air conditioner that works when switched on, green light flashes 4 times, for a few times then it shuts down. There is also a flashing red light inside that unit.
There will be a list of flash codes in your manual or on the inside cover of the unit indicating what the problem is eg. low pressure or high pressure alarm
Nov 15, 2016 | Carrier Heating & Cooling
PS3 switched off during use, Red light flashing at front,can't get game out.Tried switching on while holding disc removal button,that did not work,left unit overnight to cool down,tried it again and it...
Sounds like a heat problem. You can either send it to sony and get it fixed for about $50. Or check out this youtube video below which has help many people through this problem.
Hope this helps, Nathan Taylor
Jul 18, 2011 | Sony Playstation 3 (PS3) Console
I just bought a second hand baby monitor from graco and they have charged but the one on my room is flashing a red light and continuosly beeps why???
When mine is red I check two things, that it's sitting flat in the charger and that all plug ins on all units are in snugly. The other thing is sometimes the main unit in the babys room is turned off so make sure the switch on the side is on. Hope it helps.
Jan 26, 2011 | Graco Imonitor Digital Baby Monitor
System comes on and immediately red light flashes
PS3 flashing is not hard to fix. Do you want to fix it by yourself instead of pay $150 checking to Sony? Here's the solution :
PS3 Red Light Fixing Guide
Feb 21, 2010 | Sony Playstation 3 (PS3) Console
Red light flashing and noise
The user manual states the flashing red light signals that your transportation lock is on. Look underneath the scanner and you'll see a switch for "lock" and "unlock." If the switch is turned to "lock" move it over to "unlock" and plug the usb cable back into your computer. It should work with no flashing red light. If not try restarting your computer and plugging it back in again.
Mar 30, 2009 | Epson Perfection 2480 Photo Flatbed...
Garage Door Openenr Motor Buzz
Look at your manuel find the page that shows the limit access switch. (Unplug your opener.) It isn't really a switch, but the three white plastic screw like parts. The center has a brown wire connected to it, which has a metal piece that is as wide as all three white screws. The outside screws are your limit access stop guides, one for the up control stop guide and the other for the down control stop guide. If the center screw with the metal part gets caught behind on of the stop guides the motor will not engage. Gently move metal piece from behind the stop guide.
Nov 10, 2008 | Sears Craftsman LiftMaster Chamberlain...
Flashing red light
sounds like a flaky power supply or lamp ballast
Jun 01, 2008 | Radio Shack Cinego D-1000 Multimedia...
Lock/unlock signal beeps
if you could send the serial number it will help me determine who manufactured it for sears and then point you in the right dirrection.
Sep 16, 2007 | Kenmore Elite HE4 Electric Dryer
Sony Playstation 3 (PS3) Console Logo
66 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
juanmireles1
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
