Question about Dell Wireless Keyboard Optical Mouse w0147
My wirelesss dell keyboard will not send to the computer. Batteries were changed and system restarted. Is it dead?
  • 23 Answers
No the wifi keyboard is not dead because you have the probvem whit the reciever.you need to clean it in.
Posted on Nov 19, 2009
Sony vaio palmrest dead
make sure the kb turned on
make sure you got a good connection
make sure plus or usb connectors are clean
if you have ir or rf device make the rf box plugged in
than check the batteries in both devices
than push the button on the rf connector and keyboard at the same time and restart the computer.
than push rf connector the mouse button at the same time and restart the system again.
if the keyboard still not working try a different keyboard if bother keyboards do the same thing
turn off computer when you restart the computer push F11
go into cmos check keyboard turned on
F10 save and exit reboot.
Jan 22, 2014 | IBM PALMREST W/O TOUCHPAD 91P8399
Disable inspiron 1525 keyboard
Step 1:
Dell sells technology such as computers, computer peripherals and consumer electronics to both consumers and businesses. Dell sells both wired and wireless keyboards and mice that are compatible with Dell and other computer systems. Dell wireless keyboards may encounter hardware, software or other problems under certain conditions.
Power Dell wireless keyboards transmit data to the Dell USB receiver, which in turn passes the data to the computer's operating system. The keyboard gets power from two AA batteries. As the batteries lose charge, the keyboard's transmissions can become intermittent. Replacing the old batteries with fresh ones will ensure consistent communication and resolve the power issue. b> Interference Dell wireless keyboards operate best and are least susceptible to interference when the user places them at the recommended distance from the USB receiver. The distance, specified in the keyboard's accompanying software or installation guide, varies by keyboard. Even if the user places the keyboard at the proper distance from the USB hub, metal objects between the keyboard and hub can create interference; moving objects that create the interference resolves the issue. b> Connection The Dell USB receiver that passes data from the keyboard to the computer requires proper and secure installation in a working USB port. If the receiver connects to the USB port improperly, or if the USB port to which the receiver is connected is faulty, the keyboard will not operate as expected. The user can reseat the receiver in the USB port, or connect to the receiver to a different, functioning USB port to resolve connection problems. b> Synchronization Dell wireless keyboards can broadcast at more than one frequency, just as their associated USB receivers do. If the two devices broadcast at different frequencies, they will not pass information to each other. The user can resolve this situation using the buttons labeled "Connect" on the top of the receiver and the bottom of the mouse. Pressing the buttons simultaneously triggers the synchronization process. b> System Dell wireless keyboards are compatible with most Dell systems. However, a keyboard may be incompatible with a given computer for reasons related to the computer rather than to the keyboard. To determine if this is the case, a user can connect the keyboard to a different computer. If the keyboard functions as expected with the second computer, the problem may reside in the first computer rather than in the keyboard.
Dell wireless keyboard problems
http://support.dell.com/support/topics/global.aspx/support/dsn/en/document?c=us&dl=false&l=en&s=gen&docid=715E6659A4141AFAE040AE0AB7E10D59&doclang=en&cs= - Issue0_1
Feb 20, 2013 | Dell Inspiron 1525 Notebook
My dell wireless keyboard just stopped working. I
if your mouse is working. it would be the keyboard it self.. cause dell has bout wireless mouse and keyboard.. do you have warrenty on your system.. dell can replace the keyboard for free..
Dec 30, 2009 | Dell Wireless Keyboard Optical Mouse w0147
How to correct Keyboard Error Press F1 to
Depending on the age of the computer, it may not recognize a USB based keyboard.
Your other option is to plug the keyboard into another computer to ensure that it is working properly.
Oct 24, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Keyboard stopped working. Changed batteries and
Does ther del have an external remote module that is connecter to the computer where a standard mouse and b connects. see if the connection is there anything here is possible
Jul 27, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Wireless keyboard and mouse not working
Hello
Some wireless keyboards and mices have a button that enables the locating signal of the device, this button when pressed locates the receiver and initiate a pairing with the host. Look below you keyboard and mouse, and if your keyboard is a Bluetooth device, then check in your computer if the bluetooth is enabled and drivers are installed.
good luck
May 23, 2009 | Dell 0Y3740 Keyboard
Wireless keyboard went dead. Have changed batteries & pushed all green buttons
I had the same problem with my keyboard and it turned out to be a manufactureing problem I just got another keyboard.
Apr 20, 2009 | Dell Dimension 3000 PC Desktop
My Dell Logitech Wire mouse freezes randomly.
Update drivers to latest for the mouse. Replace the mouse's batteries & recheck. Hope this helps.
Dec 26, 2008 | Dell Wireless Keyboard Optical Mouse w0147
Dell Wireless Keyboard Optical Mouse w0147 Logo
189 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
