Question about Samsung SGH-G600 Cellular Phone
I have just brought a samsung g600 phone. put my sim card in and the speed dial has randomly picked names to put in it. When I hilight one and press the centre button the address book should come up nothing happens. Is the phone faulty or am i missing something?
Need puk code
Please call the Customer Care of your Network Operator (sim card provider), they will tell your the code. There's no other way or no means to get the code except from the Service Operator. They might ask your few questions related to the Sim Card, like your name or your address, tell them promptly and they will give you the puk code for your sim card. It's also important to note down the Sim Card Number (number written on the sim card) if in case they ask you the sim number. You will also be assisted on how to disable the security settings.
Note: if you keep entering random/unknown numbers/codes, the sim card will be locked and will be rejected. It'll not be usable anymore. Good luck.
Thanks for using FixYa.
Sep 23, 2010 | Samsung SGH-G600 Cellular Phone
Need to copy contacts from sams g600 to sim card
Press the following keys in this order...
-Left Click(menu)
-2
-8
-2
-2
-left click
-centre select button
May 19, 2010 | Samsung SGH-G600 Cellular Phone
How do i unlock my G600 i really need the sim lock to access my phone, can you help?
BACK UP YOUR FILES BEFORE UNLOCKING
This will also bring the phone to default settings
1. First do a CUSTOM reset: *2767*2878# (star 2767 star 2878 hash)
turn off the phone
2. take out the battery and sim and put wrong network SIM and insert a half of it,
so it won't ask for network password and shows "Insert SIM" message.
Now put the battery ,and switch the phone on .(phone shows "Insert SIM" message.)
3.With out turn off the phone push the sim fully in. At this stage the phone is still asking to "Insert SIM"
4. Make a FULL reset by typing: *2767*3855#(star 2767 star 3855 hash)
5. The phone should reboot working with "wrong" sim inside.
6. Make a Change the NCK password to 8 zeros by typing: *7465625*638*00000000*00000000#
(star 7465625 star 638 star 8zeros star 8zeros hash)
7. Now Disable network lock By typing: #7465625*638*00000000#
(hash 7465625 star 638 star 8zeros hash)
Phone is unlocked (check with *#7465625#)
If you find that SPLock is still on afterwards follow the below
After you do the reset, check and make sure that your network lock is active by
pressing *#7465625#.
If it isn't active you must use this code
to reactivate it, *7465625*638*00000000*00000000#.
Then deactivate the sp lock first. To do that input *7465625*77*00000000*00000000#,
(this will reset the lock)
then enter #7465625*77*00000000# (to disable the sp lock).
Then disable the network lock #7465625*638*00000000# and
the phone is finally unlocked
Sep 02, 2009 | Samsung SGH-G600 Cellular Phone
I NEED PHONE LOCK FOR T MOBILE G600 SO I CAN PUT VODAPHONE SIM IN
1-Turn on the phone without sim card .
2-Pull off the battery cover and insert any non-accepted sim card (without turning off the handset)
3-Do full reset *2767*3855# , phone will reboot and goes to Menu .
4-Customize Sp-lock code *7465625*638*00000000*00000000#
5-Unlock your phone with new SP code #7465625*638*00000000#
6-Enjoy G600 unlocked
Tested with few pieces
Feb 08, 2009 | Samsung SGH-D600 Cellular Phone
Need samsung g600 unlocking code
I have just tried it with my new locked to orange g600 and it works fine on all networks.
if it doesn't work after step 3.. try changing the 'non-accepted' sim card that ur putting in..
eg if you are locked to vodafone and you try this method and use an orange sim card and it doesn't work, try using a o2 sim or even virgin :)
its easy good luck
Jan 29, 2009 | Samsung SGH-G600 Cellular Phone
Can i unlock my samsung sgh g600
Jan 03, 2009 | Samsung SGH2100SGH600V300 Unlock/Unlocking...
Unblock my phone
contacting SAMSUNG is the only option you have .
Nov 13, 2017 | Samsung SGH-G600 Cellular Phone
Speed dial
Scroll to the name you want to put in speed dial. OPTIONS tab then DETAILS....then scroll down to ADD TO SPEED DIAL then it will prompt you Yes or No? click on YES..then pick a position and SELECT
Dec 05, 2007 | Cell Phones
Speed dial not working
I have done it. I have found a way to chance the speed dial settings on my Samsung D900i.
The following instructions work for my phone but I cannot guarantee they will work for everyone else.
YOU WILL NEED A PEN AND PAPER.
Press Menu > select Phonebook > Speed dial (4) >Select
You should see names assigned to the numbers.
Decide which speed dial number you want to change e.g. 2 Mum Mobile (remember the name)
Press Back > Contact list (1) Select
Type in/go down to that name e.g. Mum Mobile (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > choose Yes > Back > Speed dial (4)
You should now see that Mum Mobile has been replaced with a big number 2. This means that speed dial number 2 is un-assigned.
Press Back > Contact list (1) > Select
Decide who you want to be assigned to speed dial 2 (WRITE DOWN PHONE NUMBER BECAUSE YOU ARE ABOUT TO DELETE IT)
Press Options > Delete (5) > Select > Yes (HERE IS THE WEIRD THING)
Press Back > Create contact (2) > SIM (2) >Select
Type back in the name and number of person you have just deleted > Save > Back > Speed dial (4)
You should see that Speed dial 2 is now the person of your choice.
HOW COOL IS THAT!!!!!!!!!!
Press Back > Create Contact (2) > Select > SIM (2) > Select
Type in Mum Mobile and Number (THE FIRST NUMBER YOU WROTE DOWN) > Save.
That is it, repeat the instructions until you have all the speed dials of your choice.
Hope this helps the many frustrated D900i users out there.
Aug 31, 2007 | Samsung SGH-D900 Cellular Phone
Samsung SGH-G600 Cellular Phone Logo
47 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
