Question about Nikon COOLPIX P60 Digital Camera
Nikon P60 is not getting switched on, showing 'lens error' .
The lens is not coming out and showing the message 'lens error'.
  • ericflipp430 Nov 19, 2009
    my lens dose not come out and show me the message 'lens error'.
  • 6,831 Answers
Hello
The problem is that the lens has become stuck in the barrel. There are some DIY solutions you could try, but the probability is that you will have to get it fixed by a professional.
Use these at own risk as it may further damage the camera.
Firstly , try connecting your ac adapter or usb cable.
Try holding the shutter button while switching on the camera.
Look at the lens , and if some of the lens 'circles' is misaligned or not concentric then try wiggling it (while holding camera lens down).
Try gently pushing or pulling the lens when it extends but this is risky as it may cause the lens barrel to slip out of its guidance system.
Another way to do this is to place the camera lens down on a hard surface and then power it up. Be sure to use a soft cloth or something similar as to not scratch your lens or casing. Let the lens push the camera up and down a few times and sometimes the little resistance provided by the camera is enough to get things going again.
Try hitting your camera near the lens on the body with the soft tissue on the palm of your hand.
Other than that , I would take the camera to a repair center for a evaluation to see if it would cost more to repair than to replace the camera.
If it is still under warranty I would suggest you take it in before trying any of these steps and remove any off-brand batteries or accessories as some stores are really fussy about warranty repairs on camera's with non-brand accessories.
You can also have a look at THIS link.
Hope the advise is useful. please do not hesitate to let me know if you need any further assistance.
Regards
Andrea
Posted on Sep 29, 2010
L18 lens error
From Nikon site...
Why does my camera show "lens error" on the screen?
Having a "Lens error" message display on the camera's LCD display indicates a problem with the camera lens mechanism. This situation generally requires that the camera be sent to a Nikon Service Department for repair. Before doing this however, be sure to check these situations below:
One possible reason for this error is if the camera is switched on and the lens unit is prevented from extending. The camera will struggle for a second to extend the lens, then report the problem. Inspect the lens for any obvious obstruction, then turn the camera off, then on again. Usually, simply switching the camera Off then On again is enough to correct this problem.
Remove and recharge the battery. Retest.
If this does not help, then we regret the camera must be sent to our Nikon Service department as there are no user serviceable parts on Nikon Coolpix cameras.
Additionally, this link could helpfull: fixing-lens-error-on-digital-camera.html
Hope helps (remember to rate and commet this answer).
May 12, 2011 | Nikon COOLPIX L18 Digital Camera
My Nikon P60 won't download pictures. It transfered the first 5 pictures in memory and then stalled. Error message says it can't copy the next picture and it won't copy subsequent pics either. The only...
Try downloading from the memory card. You will have to purchase a card reader, usually less than $20. It will save the batteries, too, since the reader is powered by the computer.
Make sure the batteries have a good charge. The camera powers the download not the pc.
Dec 12, 2010 | Nikon COOLPIX P60 Digital Camera
Lens error comes up on the screen when I turn it on
Problem: dust in the gaps near lens which makes it jammed. Effect: the sceen shows blk color. Solution: just blow over it or vaccum it.
Apr 16, 2010 | Nikon COOLPIX P60 Digital Camera
Nikon P60-Screen is blank and lens doesn't retract.
Please remove the battery for few hrs and charge them after that replace the battery and try to power on if the problem persist then take to any service center the firmware needs to be updated or there is some short in the circuit board of the cam.
Feb 16, 2010 | Nikon COOLPIX P60 Digital Camera
Nikon d700 error message
Have you tried cleaning the contacts on the lens with alchoho and a cotton swab? The DX lens will have to tell the camera that it's not a full frame lens, and that happens through those contacts.
Post a comment if that won't work and we can go into more troubleshooting.
Oct 03, 2009 | Nikon D700 Digital Camera
Powers on Lens move in then out,Blank display
hi...The transmission system that moves the lens in and out has a problem with it's gears. There is most likely a gear or an actuator that has fallen out of alignment and is getting stuck at a certain point as the lens comes in/out.There is some disturbacnce of the lens arrangement that is preventing the lens from coming in/out.Any of these symptoms above could trigger the camera to shut itself off to protect itself from further damage. thank u rate me!!!
Jul 22, 2009 | Nikon COOLPIX P60 Digital Camera
No shutter release
It turns out that supporting the camera while taking a shot can impart a slight twist on the seated lens. This twist is just enough to cause the camera to think that there is no lens installed .. hence the error message. Solution (provided my Henry's Camera experts) was to reseat the lens by reversing the twist. It has since happenned twice and each time recovery was effective .... Keith
May 25, 2009 | Nikon D80 Digital Camera with 18-135mm...
Suggest the best brand in digital camers in 8-10 mega pixels
For the money, I think the Nikon Coolpix P60 is the best bang for your buck. I bought one myselft in August 2008 and dropped it in Feb 2009 so I must by a new camera - i am buying another P60 !
Jan 22, 2009 | Nikon COOLPIX P60 Digital Camera
Nikon COOLPIX P60 Digital Camera Logo
165 people viewed this question
Top Nikon Cameras Experts
Steve
Ric Donato
Are you a Nikon Camera Expert? Answer questions, earn points and help others
