Question about Cell Phones
Need free unlock codes for white tmobile g1 for att or verzon
I have a sony ericsson tm506 tmobile cell phone that I want to use my att sim card. Is there a free unlock code?
Yes. You can be provided with an unlock code for free by calling tmobile and telling them you are going overseas and need an unlock code.
Have the following information ready for them: -your cell phone number -your tmobile account pin number -your phones IMEI (can usually be found on the box or the back of your phone)
Mar 15, 2011 | Sony Ericsson TM506 Cell Phone
Tmobile will not give me the unlock code to a g1 i purchased becaszue im not a tmobile customer.. imei 351680031162658 please help im without a phone till i get this one unlocked
To unlock the Mobile so many method available ....But they leads to Data lose....Unlock code is Best Method..they are safe method...I used the Code to Unlock my mobile,....You can get the unlock code here http://www.theunlockspot.com/htc-g1/rs10wp9/ to Unlock Your Mobile from the Network lock....
You check for your locked Network it's Country also.
Dec 17, 2010 | HTC G1
How do i get free unlock code for g1 google phone
Dear,
  • 1. Side out the Keyboard / Open Left Hand side Notch to unlock Battery Panel.
  • 2. Insert TMobile SIM Card and Battery.
  • 3. Press MENU Button Constantly and Switch the Phone using Red Talk End / Power Button but do not Release the Menu Key.
  • 4. This will put on the Phone in Safe Mode.
  • 5. Press to Emergency Dial Button, Windows dial *#06# and this will show IMEI Number: note it down and also Recheck IMEI with Box.
  • 6. Give IMEI to Unlock Code Provider www.unlock-tmobileg1.com and get the Unlock Code.
  • 7. Now Return to main Screen and Press MENU Button this Will popup APN Button, Just Press it.
  • 8. Go to APN Setting. There will be so many APN already Preset. Again Press MENU Button this will show NEW APN Popup Button again Press.
  • 9. Remember to put Right MCC (Mobile Country Code), and MNC Mobile Network Code, G1 Matches SIM card Data of MCC / MNC with these Setting and then try to use that. Settings.
    All World MCC / MNC codes is available here:
    http://en.wikipedia.org/wiki/Mobile_network_code
  • 10. Now Switch off the Phone and Wait for Unlock codes.
  • 11. Insert the Non T-Mobile SIM Card which you intend to use it with G1 and switch G1 on. (Your SIM must have
    Data plan / GPRS Activated so G1 will able to contact google.com for Activation)
  • 12. HTC G1 will ask for Unlock Codes. Type unlock code carefully, typing wrong code thrice may make Phone Hardware Locked.
  • 13. Once Unlocked your GPRS / EDGE / 3G Data Service will be active as per APN Setting we did before.
  • 14. Type Google User name / Password in Signing Window and this will Activate the Unlock G1 Device on your SIM Card.
  • 15. Make other remaining Data Setting like MMS / Home Page / Port to Active other Data Service
Thanks
Sep 14, 2010 | HTC Google G1/Dream Cell Phone Black...
How do I unlock my tmobile g1 sim card PUK lock?
You should fix this problem by inserting the PUK code that was given to you by your broadband provider/Sim Package. This is a security code.
Aug 16, 2010 | HTC Google G1/Dream Cell Phone Black...
I need free unlock codes for tmobile htc g1
As far as i know free unlock codes net work actully wrong code can damage you cell phone so do not use codes with out guide.i know the site from where i got my unlock code its not free but its as cheap as free so you should go there and i am sure you will find your code.click here to get unlock code.
hope it helps you..
Jul 28, 2010 | HTC NEW FOR TMOBILE WING HERALD P4350...
How to i unlock my htc g1 for free. i need a code.
You can unlock it for free if you or someone you know is an existing T-Mobile Customer. Simply call tmobile up and tell them you want to unlock your phone, typically the longer you've had your Tmobile service the more likely they will do it, also the persons account should be in good standing.
Jul 23, 2010 | HTC G1
I have a G1 but i forgot my pattern so i reset it ; i went to tmobile to buy a sim card but they told me i cant use prepaid , ive looked up how to unlock a G1 and every website saids i need the code to...
No you dont need to buy an unlock code if you simply forgot your password code, all you must do is do a hard reset on the phone. and yes you can use it prepaid or with whatever plan you want, all you do is insert your tmobile sim card, i have a flex account with tmobile and i just inserted the sim card, You dont have to contact tmobile.
Hold the Home and Power keys down at same time for about 25 seconds. You will see a yellow triangle screen with exclamation point in the middle.Now to wipe the device clean:
Press Alt+L. Press Alt+W for a factory reset.
Press the Home and Back keys again for about 25 seconds.
The device should then reset again and the hard reset is complete.
Jun 10, 2010 | T-Mobile G1 Android HTC Google Smartphone...
Need a free code to unlock my g1 phone please help
It's pretty darn simple: just insert your non-T-Mobile SIM card and then enter in your SIM unlock code. How to get one of those? Simple: T-Mobile has promised they'll continue their policy of offering free unlock codes to customers after 90 days with a phone. If you're in a hurry to get it done faster, there are plenty of places to buy them online. You can even use your G1 to start Googling for them.
for video info see this http://www.androidcentral.com/unlock-tmobile-g1/
Sep 28, 2009 | Cell Phones
Is anyone out there willing to hepl me unlock my G1? I am not a TMobile subscriber but bought a G1 phone at a thrift shop, unfortunately locked! I went and payed five places to give the unlock code, money...
you must master reset the device using the hardware buttons on the phone the phone will need to be powered off press and hold both the home key and the power key until a warning triangle appears flip the screen open and press alt and W the device will reset and you will be unlocked from the privacy pattern.. from a tmobile rep
Jul 04, 2009 | HTC G1
Unlock code
need to get info for unlocking bb from att so it can be used for tmobile,free preferably
May 27, 2008 | AT&T Blackberry Curve 8300 Smartphone
Cell Phones Logo
166 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
