Question about Sub-Zero 611 / O Bottom Freezer Refrigerator
Sub-Zero 611: Fridge control panel and light
Sub-Zero 611: The control panel and light in the refrigerator are not working. The compressor is running and sounds normal, and the compartment seems to be cool.
3 Suggested Answers
  • 71 Answers
SOURCE: Sub zero 611 refrigerator error code 40, freezer
code 40 compressor for the freezer side over runing. check the coils upper part of the unit. or condenser fan motor. easy things to check.
Posted on Apr 01, 2010
heatman101
  • 43501 Answers
As the weather is getting warmer for many people their freezer2_bing.gif and/or refrigerator do not work right because of a dirty condenser coil...
Check out this tip that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
http://www.fixya.com/support/r4024657-refrigerator_condenser_coil_cleaning
http://www.fixya.com/support/r3885294-refrigerator_troubleshooting
http://www.fixya.com/support/r4023749-refrigerator_compressor_start_capacitor
heatman101
Posted on May 27, 2010
My refrigerator is warm 72 and my freeze is 00. how to fix it.
You have to remember that sub zero has two independent compressors and evaporators so the freezer is fine. Focus on the fridge part. Here are some things you want to look at.
1) When you open the door, press the light switch and the fan switch, Does the fan run, it should.
2) Take the grate down that covers the compressors. The fridge is usually on the right as your looking at it. Is it running, hot or cold. If its running and hot, that's normal. If its hot and not running, you can tell by if its vibrating, you may have to turn the freezer off to prevent outside vibration. If its not running that means you more than likely have a bad compressor. If its cold and the fan inside didn't come on then the thermostat is bad inside the machine.
Jun 05, 2012 | Sub-Zero 611 / O Bottom Freezer...
Mine is an older (20 year old) built-in sub-zero with freezer on the bottom and fridge on the top and only one temperature control (in the fridge portion). The refrigerator is working fine, but the...
You might have a dirty condenser or possibly a freon leak. Check to see if the fans are running and lights are going off when the doors are closed. You didn't mention what the model number is, that might help.
Jan 18, 2011 | Sub-Zero Refrigerators
Sub zero 611 refrigerator error code 40, freezer will not get cold enough but refrigerator compartment working
Mar 18, 2010 | Sub-Zero Bottom Freezer Refrigerator
Recently moved into a new apartment that has a Subzero 611 Just put in 4 new light bulbs and none of them are working
try the light switch. located in the upper part of the fridge or freezer. is the white switch. the black an white is for the fan. REALLY EASY
Jan 30, 2010 | Sub-Zero 611 / O Bottom Freezer...
Fridge side light is off. fridge works
check if your bulb is busted, have it replace
Nov 14, 2009 | Sub-Zero 690 Side by Side Refrigerator
My Subzero Condenser fan runs constantly - but coils are clean
If it is similar to mine at home (Model 550) the condensor fan is designed to run continuously, even when both the freezer and refrigerator are shut off. There is no control or switch in the fan circuit, so it just runs whenever the fridge is plugged in to the wall. It uses about 56 watts.
Oct 19, 2009 | Sub-Zero 611 / O Bottom Freezer...
Fridge portion of my 611 is warm but freezer is still cold. Help.
The only other thing that seems could be wrong is that your freon lines are icing up and is cause you to not cool properly. Pull out your fridge and check the compressor on the bottom
Feb 07, 2009 | Sub-Zero 611 / O Bottom Freezer...
My Sub-Zero 611/O is not cooling enough. The temp is 0 in the freezer and 46 in the fridge. I vacuumed very well the condenser. I can't tell which compressor is running. There are two, one larger than the...
More than likely the fan inside the back of the unit freezer compartment is not working and causing the freezer to freeze up.need to pull pannel off inside back of freezer and replace fan
Jan 14, 2009 | Sub-Zero 611 / O Bottom Freezer...
COMPRESSOR ON FRIDGE SIDE IS NOT COMIMG ON IT RUN THEN TRIPS ON OVERLOAD EVERY FEW SECONDS
sounds like bad relay on compressor
needs 3 in 1 installed on it
can get at appliance parts place
Jul 20, 2008 | Sub-Zero 611 / O Bottom Freezer...
Subzero 611 Refrigerator not cooling, freezer fine
It sounds like a defective ref section evaporator. This is common, due to poor quality metal used in fabrication. If you call subzero, they will more than likely fix it as they are aware of this issue. It probably wont cost you anything if you get them involved.
Mar 12, 2008 | Sub-Zero 650 / O Bottom Freezer...
Refrigerators Logo
131 people viewed this question
Top Sub-Zero Refrigerators Experts
ACME Sub Zero...
ACME Sub Zero...
Sal DeAngelo
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
