Question about Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White
Frigidare Model No. FFU1464DW2 is leaking water on ground floor, can you tell me where to find the drain pan and what is causing this? Many thanks.
Most likely it is leaking because the drain in the back of the freezer is clogged. The most likely source of excessive water drainage is a bad door seal which causes frost to build up.
Posted on Jun 03, 2010
Why is water leaking on to hardwood floor and warping it.
Excessive water in the catch pan can be caused by a leak in the ice maker. Shut off the water supply and if the problem goes away it is caused by a small leak. If it continues it can be caused by high humidity in your home.
Jul 12, 2014 | Samsung RF220NCTASR 22 cu. ft. 30-Inch...
Water leak onto floor
There should be a drain pan that is deposited into, however some will crack or be moved out of place causing this.
Apr 29, 2014 | GE Profile : PSCS5RGXSS Refrigerator
Water on floor
Check your drain hose that leads to evaporator pan. The hose should be in the pan. If it is in pan, then check to see if all door gaskets are tight and no leaks or gaps. This likely is the problem assuming you don't have a leak in the water line leading to ice maker. Try these things first and then we wll move to the next possible solutions.
Mar 14, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Water is leaking out from the fridge floor onto the ground.
The drain pan in the back evaporates from the heat of the compressor. The freezer drain drains into this pan. If there is water under the bins it sounds like the drain is partially clogged and over flowing into the refrig section. But I need more info, like model , brand.
Nov 17, 2013 | Sub-Zero 700 Refrigerator Freezer...
I've had the refregerator for 10 months.. All of a sudden water is appearing on the floor next to the refrigerator. Where could it be leaking from?
Pull it forward and seei if the drain pan is either overflowing or empty. If it,s empty, check the drain isn't blocked, causing meltwater to leak from inside. If it's overflowing, check the door seals properly and the defrost settings are ok.
May 22, 2012 | Samsung RFG297HDRS 29.0 CuFt French Door...
JENN AIRE LEAKING WATER ON FLOOR. NOT SUPPLY LINE PROBLEM. HELP
Open freezer, remove lower crisper & look for solid ice on freezer floor & area at rear of freezer. If present, defrost drain is restricted. Depending on make & model remove ice, remove rear wall and clear defrost drain trough and drain path. Verify by removing kick panel, pour a cup of near boiling water through drain and watch as it drains into pan. Once clear, pour one ounce of bleach into drain tube. Also check as water is draining into pan that the pan is not leaking due to pan cracks. This solution is based on the fact that you are stating no hoses are bad.
Mar 27, 2012 | Freezers
Freezer door is leaking water on refrigirator model # frs20zshb5 the freezer side of the body where the magnetic strip touches the door is hot to the touch
You know, it's really normal to touch it hot on the door side.
Because it has heater to eliminate moist build up that can cause rust.
Check the drain pan (that is full of water) for clogged.
Unclog it using flexible solid wire and insert it on drain pan tube.
After that, those leak will be minimize.
Thanks for asking.
Jun 29, 2011 | Frigidaire Freezers
Model # FFU14F9GW.. water pooling under unit
Greetings,
If the water is pooling under the bottom drawer. I'd say your drain is clogged..the drain will freeze over from something getting into the drain i.e. food particle....The best thing to do. Is use a hair drier to defrost the drain pan and then make sure your drain runs free by pouring water into it....
if this is pooling under the refrigerator and out on the floor..There is a drain pan problem..and /or the drain hose going to pan is out of the pan , or has a hole in it...correct as needed
If this has been helpful in fixing your problem..please leave a testimonial.....thank you
Dec 12, 2010 | Frigidaire Freezers
Found water leaking from our maytag side by side model MSD2142ARW. Disconnected ice maker 4 weeks ago thinking it was that, and still leaking and has ruined my new laminate floors. Is the freezer gasket or...
The defrost drain hole in the freezer side is frozen closed.
Turn off the fridge.Remove the bottom bin and look on the back wall of the freezer for the drain pan. It will have a block of ice in it. Use a hair dryer to defrost the pan AND the drain hole inside the pan,until you can pour a cup of water through the drain hole.
Dec 28, 2009 | Maytag Freezers
Water leaking onto the floor from freezer drain...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. .
Sep 20, 2009 | Freezers
Frigidaire 20.3 Cu. Ft. Frost-Free Upright Freezer - White Logo
500 people viewed this question
Top Frigidaire Freezers Experts
AJMAL KHAN
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
