Question about Enodis ST-1 "Mini" Toaster 2400 Watts with Convection Cooking
I have a mini four KH1139 electric cooker, but instructions are in other languages but not english, is it possible to obtain one from anywhere. Thank you
Free instruction manuals for prima super chef
Why not just ask someone to print one out for you?
If your Fagor Pressure Cooker or Commercial Cookware needs to be repaired, or if you have any questions in regard to the use and care of the product, please call the Fagor Cookware Customer Service Department at # 1-800-207-0806 (Monday to Friday from 8:30am to 5:30pm EST), or email us your questions to info@fagoramerica.com SERVICE CENTER LOCATIONS
Aug 08, 2014 | Fagor 12 Quart Halogen Tabletop Oven
Where can i obtain a owners manuel for model #T0284? It has been mislaid. Thank you
You can download the manual here... http://www.manualslib.com/manual/49768/Euro-Pro-To284.html
Jul 03, 2014 | Euro-Pro EuroPro 6Slice Toaster Oven with...
I need the manual to counter top oven model #31197
People keep asking for this even though there are others (now mostly dead links) so I have posted it (3 language edition) here:
http://66.39.50.3/Manual.pdf
Nov 15, 2011 | Hamilton Beach 31197 120 Watts Toaster...
Where can I obtain a replacement timer knob for Model T0161 toaster oven
Euro-Pro TO161 has a 1 year warranty.
Warranty registration is HERE
FYI,you can buy a refurbish unit for $26 HERE
Jul 28, 2011 | Euro-Pro TO161 Toaster Oven with...
What is the electrical rating of the Convection Toaster Oven Mdl #169127/169140 as the manual states that the extension cord should be at least as great as the electrical rating of the appliance. I will be...
most appliances that have heating elements are rated between 1000 to 2000 watts, which will give you a current rating of between 5 to 10 amps, check at the back of the oven for the ratings. use
the formula P=VI, P(power(w) and V(voltage) and I is the current(amperes). the cord will have a
current rating, go for around 15 amp rating
Jun 17, 2011 | GE 168947 Toaster Oven with Convection...
I need a owners manual for wolfgang puck bristol toaster oven and bottom pizza cooker bdcorp10
Wolfgang Puck Instruction Manual for the BTOBR0040 is available here:
http://www.wpcookware.com/instructions/BTOBR0040.pdf
Other Wolfgang Puck Instruction Manuals are available here:
http://www.wpcookware.com/manuals.asp
If you do not see your model number for your product, suggest you contact their Customer service at 1-800-275-8273 to determine if the Instruction Manual for your model is available. Alternatively try making an inquiry via their webform:
http://www.wpcookware.com/contact.asp
Feb 06, 2011 | Wolfgang Puck BTOBR0040 Toaster Oven with...
How to change the lower element on a delonghi AD 699 toaster oven?
  • Preheat ovens only when necessary. With conventional ovens, keep the preheating time to a minimum. Unless you're baking breads or pastries, you may not need to preheat the oven at all.
  • Food cooks more quickly and efficiently in ovens when air can circulate freely. Don't lay foils on racks. If possible, stagger pans on upper and lower racks to improve air flow.
  • Use glass or ceramic pans in ovens. You can turn down the temperature about 25°F and cook foods just as quickly.
  • Do not open the oven door often to preview the food. Each time you open the door the oven temperature drops by 25°F. Watch the clock or use a timer instead.
  • Full-size ovens are not very efficient for cooking small- to medium-sized meals, it generally pays to use toaster ovens or microwave ovens.
  • Check to be sure the oven door gasket is tight. Adjust or replace gaskets as required.
  • If you have a self-cleaning oven, consider using the self-cleaning feature immediately after regular baking when the oven is still hot. Less energy will be required to reach the cleaning temperature. Try not to use the self-cleaning feature too often.
  • Keep range-top burners and reflectors clean; they will reflect the heat better and save energy.
  • Match the size of the pan to the heating element; more heat will get to the pan and less will be lost to the surrounding air. A 6-inch pan on a 8-inch burner will waste over 40% of the energy.
  • On electric stove-tops, use only flat-bottomed pans that make full contact with the element. A warped or rounded pan will waste most of the heat.
  • When cooking with a gas range-top burner, use moderate flame settings to conserve gas. Also make sure the pilot light is burning efficiently, with a blue flame. A yellowish flame indicates an adjustment is needed because the gas is burning inefficiently.
  • Whenever possible, use a pressure cooker. By cooking food at a higher temperature and pressure, cooking time is reduced dramatically and energy use is cut by 50-75%.
  • Hope this work ..........
    Jul 07, 2010 | DeLonghi AD699 Airstream Digital 1500...
    Instruction book for Euro Pro X toaster oven
    Euro-pro.com, select toaster, plug in your model and choose manual. Just printed mine.
    Mar 01, 2009 | Euro-Pro EuroPro 6Slice Toaster Oven with...
    Instruction Manual and Recipes
    Try manuals.com they may have what your looking for there . Good luck .
    Apr 24, 2017 | Black & Decker TRO6100CT Toast-R-Oven Plus...
    Enodis ST-1 "Mini" Toaster 2400 Watts with Convection Cooking Logo
    Top Enodis Toaster Ovens Experts
    Angel Joseph Jr.
    Angel Joseph Jr.
    Dave
    Dave
    Are you an Enodis Toaster Oven Expert? Answer questions, earn points and help others
